Question about HP OfficeJet G85 All-In-One InkJet Printer
G85 all in one jamming
I ran labels at Christmas and some of them have glommed up at the rear rollers of the printer. It will print but it dents the front of the paper, sometimes sending the paper crooked. We have tried and tried to get them out, but they seem to be stuck on each other or something and all we can get with tweezers or tongs are small pieces.
Can someone tell me how to remove the rear roller bar so I can get to the darn things? I am ready to throw my printer out but I hate to waste a perfectly good machine...
Peg
    Problem Solver:
  • 9 Answers
Did you try to remove the rear cover. There are pinch rollers mounted on the rear cover which might be causing your difficulty.
Posted on Apr 15, 2008
On the screen it writes paper jam but there isn't any
the roller are stuck, check to see if the roller are moving when you turn it on.
also if you pulled the paper thewrong way you could have damaged the sensor that checks for paper jam, its a small arm, behind the roller.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Oct 29, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
Officejet G85
For the paper jam you remove the back cover and clean the 4 rubber rollers with alcohol, you can rotate the rollers forward while you clean. For carriage jam you start by cleaning the encoder strip that runs across behind the carriage unit, the clear strip with black bars on it, you can wipe with a Q-tip damp with alcohol. If no help you may need to take apart and clean dried ink off of the service station on the right.
Feb 01, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
The paper twists and causes a jam on every print
sounds like something jamed in the rollers like a pin etc
Jan 05, 2010 | Epson Stylus R265 InkJet Photo Printer
Labels only jam when printing from file
I cannnnoooooottt believe what I am reading! If you are going to use labels on a laserjet, you need to get thermal labels! The other cheap labels are made for inkjets, matric, or daisywheel printers. The laserjets have heat rollers that will melt plastic. It will melt the gum on the non thermal labels and get them everywhere!!
Master Rod
May 08, 2009 | HP Color LaserJet 8550dn Printer
HP G85 PAPER JAM ERROR ,but still prints from scanner fine
Remove the rear cover...clean the rubber rollers with alcohol
Feb 17, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
HP 3210 getting paper jam because label stuck on roller.
I ran heavy card stock through printer several times, it caught the label and pulled it out on the paper eventually.
Feb 04, 2009 | HP Photosmart 3210 All-In-One InkJet...
Label stuck on a roller?
Looks like label stuck on the toner cartridge. Easiest solution would be to replace toner cartridge or if you can slowly spin the OPC drum on toner cartridge till you find label NOTE: damage to the OPC drum with affect print quality as well as oil from fingers will affect PQ( print quality)
Jan 13, 2009 | HP LaserJet 5000n Printer
G85 series prints crooked
From HP's site:
Problem: The print on the paper is skewed.
Solutions: 1. Slide the paper-width adjuster against the left side of the paper stack, and 2. make sure that the rear access door in the back is fully “locked”.
Jun 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Labels jamming
Check the entire paper processing path as it sound like either the roller gear is not engaging properly to push the paper out of the top, or the output paper path is somehow blocked, like from a label or something else stuck at the top, the roller gear is damaged, or other obstruction.
Nov 16, 2007 | Konica Minolta magicolor 2300DL Laser...
Paper jam
if it picks up paper then say's jam you most likely have a very small piece of paper still jammed.look for a dent in the paper you pull out,if there is a dent then that's probably the problem.look where dent is on paper and that is where you should look for the piece that's causing the jam,if that does'nt solve problem i would need more info
Sep 22, 2007 | Brother MFC-3240C All-In-One InkJet...
HP OfficeJet G85 All-In-One InkJet Printer Logo
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
