Question about Jensen VM9510 Car DVD Player
Nothing I GOT THE PINK WIRE TO THE SWITCH AND I ALSO HAVE THE SWITCH GROUNDED, THE LIGHT COMES ON TO THE SWITH SO I KNOW POWER IS RUNNING TO THE SWITCH. I INSERT THE DVD AND CAN HEAR IT BUT THE BLUE SCREEN COME S UP. I FLIP THE SWITCH ON AND OFF NUMEROUS TIME AND WAIT BUT NOTHING HAPPENS
    Problem Solver:
  • 5 Answers
Please tell me your exact model number of Jensen TV, or what ever tv it is. Why does your switch have a light?
When you toggle the switch, you have to do it 3 times, waiting 2.5 seconds in between. There is also a way to overide the switch altogether in a progrmaming mode on some Jensens.
Posted on Feb 02, 2008
No power to coil
Check the pink wire. It goes from the ignition switch to two circuits in the under-hood fuse box and the ignition coil. One circuit goes to ENG-1, ECM-1, IGN-E. The other circuit goes to GAUGES, FUSE 4, AIRBAG FUSE 10 and TURN/BU FUSE 16.
If all those fuses do not have power when the ignition switch is turned to start or run check the pink wire as it comes from the firewall connection. If you don't have power on the hood side, there may be a bad connection between the two halves of the connector.
If you do have power on the pink wire on the hood side of the firewall then you may have to check it between the coil to the firewall connector and underneath the under-hood fuse box.
I would use a tone tracer on the pink wire while the ignition switch is in the off position. (turning the switch off makes the wire only go in one direction, to the engine compartment) The tool sends a tone signal through the wire (in this case it would be hooked up to the pink wire) and has a receiver that lets you follow the tone in the wire without having to open the wire harness. You can just follow the wire harness and hear the tone signal. if there is a break in the wire or the connection is terminated somewhere in the circuit the tone will stop. Makes it a lot easier to trace a wire.
Nov 17, 2017 | 2000 Chevrolet Blazer
1998 mazda protege running lights out
One of the light fixtures has a grounded power wire. Examine all light fixtures closely for bare or grounded wires. If you find nothing, trace the wiring harness to switch paying close attention to places where the wire harness passes through holes on the body for the harness. Any contact with the steel vehicle body from a power wire has the potential to cause a short, which will blow fuses faster than you can replace them. Start with the outside tail and marker lights. Also look for broken filaments inside the bulbs, as a broken filament touching another filament or wire inside the bulb can do the same thing. Good luck.
Mar 18, 2014 | Mazda Protege Cars & Trucks
1993 Ford Escort Blower Motor & AC Switch
I'm going to start from the beginning.
The blower motor gets power from the high blower relay and it is grounded thru the fan switch and the resistor. So you should have power on the pink white blower wire coming from the high relay to the blower motor. The orange black wire from the motor is ground going to the resistor and fan switch. The blue wires on the control panel are for the ac compressor.
The high blower relay gets power from fuse number 5 in the box. The blower motor is grounded thru the resistor and then thru the fan switch.
Photo courtesy of AutoZone.com
Jun 10, 2013 | 1993 Ford Explorer Limited
Replacing fan. Wires from ceiling are grey pink white & bare copper. Wired to light switch. What wire connects to what? Ok so we just bought the place. The painters removed the old fans that had no...
Sounds like you have two hot wires. Just need to find out which wire goes to the wall switch. Try gray to black from fan,pink to black/white wire.white to white & green to green. If this doesn't work swich the pink & gray wires.
Feb 03, 2013 | Dryers
94 explorer no crank but starts when bridged at relay. changed bat. starter, relay, ignition coil/ switch/ and ignition, terminals, ground cable, fuse, black relayZ?????
Check for power on the red with light blue wire at the ignition switch with the key in the crank position. If there is no power make sure there is power on the yellow wire at the ignition switch. Also check to make sure the key is making the full turn to the crank position. If there is power than check for power on the Pink wire at the neutral safety switch on the side of the automatic transmission. If there is not power I need to know if you have the anti-theft system or not. If there is power than check for power out of the neutral safety switch on the red with light blue wire. If there is power on that wire pull the starter relay and check to see if two pins are grounded all the time. One of the other two pins that are not grounded should have power all the time. The other pin should have power when the key is in the crank position. That should get you started. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Jan 11, 2012 | Cars & Trucks
The 3.3 engen overheats but the fan doesn't kick in. I have changed the thermostat but that didn't help the over heating. I hot wired the fan and it will run. ???? Is there a fuse some place i...
Try unplugging the temp sensor located on or near the thermostat housing. This will cause the fan to come on, if it works. If the fan does not come on then check for burnt wires near battery and fuse box. You may need to squeeze and manipulate these wires to find burnt area. I have seen coolant temp sensors, faulty fan motors, and burnt fuseible links cause this. When unpugging the CTS the check engine light will come on, don't worry about it.
Sep 01, 2011 | 1991 Dodge Caravan
No brake light or blinkers.
you've lost power to your rear wire harness.
use a test light.
1.check test light at battery first to make sure the test light works(test).
2.remove seat and find each wire going to the rear section of the bike.
it should be a plug in type connector, I believe its a 5 wire connector.
3.unplugg this connection and test the side coming from the front of the bike.
to test it, turn ignition on. hold tester to one wire at a time. When test light comes on, that
is your power wire. note the color.
this power wire is for your tail/tag/and or any running lights
turn left blinker on, then hold tester to other wires to see which one blinks. note the color.
turn right blinker on, then hold the tester to wires to see which one blinks.note the color.
step on brake pedal, then hold the tester to wires to see which one comes on and stays
on until you release the brake. this is your brake light wire only and comes from a brake
pressure switch.
the brake switch should have constant power to one side always. when you apply the brakes
the pressure in the switch make contact to other side of switch which sends power to your
brake light. note the color
the wires running under the fender make be broken from scrubbng the tire.
fix the wires or replace them.
4. if you had no power at all, then check your battery is fully charged
5. if no power with a good battery, check fuses.
6. if no power with a good battery and good fuses, then you'll have to trace the wires in the wire
harness to find where the break is.
7. to test any ground wires, simply reverse the connection on the test light.
hook the clamp to the positive side of the battery.
Now test any ground, by touching the tester to it, even the engine and frame should be
grounded and make the test light come on.
As a mechanic, i know time is important, and this test will only take approx and hour or less to perform.
i am color blind and i have to test every wire all the time to make sure i know which wire is which.
once i find it i label it.
works for me everytime.
takes longer to find it then to fix it.
Hope to be helpful.
Best Regards
Big Al
Jun 28, 2011 | 1979 Harley Davidson XLH 1000 Sportster
Jensens UV9 By pass the brake
hook up the ground with the pink and when you are in am/fm mode hit the dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure it beeps after every no. has been pressed. then it should bring up the hidden menu select the hammer option and turn on the brake bypass option. your done.
i took this from the uv8 brake bypass. it works on the uv9.
Nov 12, 2008 | Car Audio & Video
HELP
Hit Setup On Remote.
Select Language.
Get Remote And Hit 5,4,3,2,1,0.
Listen For Beeps. Touch “Hammer/Screwdriver” Logo.
Select Brake Override
Switch To Brake Override “ON”
Now Hit Setup On Remote.
And Now Watch Movies.
Feb 01, 2008 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
