Tv red screen
This is a JVC Pro logic
the screen is all red - it looks like it has lost all black/dark colour
+ there are diagonal lines accross the screen
can this be repaired?
do I need to change the tube?
if so how easy is it to do this?
  • helenef Feb 01, 2008
    thanks a lot for responding so quickly - unfortunately, I cannot see the model number anywhere - is the crt board the back of the tv? sorry I am just useless!
    President:
  • 4,402 Answers
Nice to have model number.
tap on crt board with a plastic handle see if it goes away.
otherwise it sounds like the tube is bad, you could also try to adjust the red brightness screen
Posted on Feb 01, 2008
  • Cary Farah
    Cary Farah Feb 01, 2008
    usually in front, if you don't know what your doing i recommend having a service tech look at it. there is high voltage inside.
Jvc hd projection tv screen is tinted pink/red PLEASE HELP!!
not so sure if warped lines about it not being convergence, if the lines are diagonal and light red etc it may be a screen circuit issue. Hard to tell from description----take a few good photos and post them on a free photo sharing site and provide a link here---expert who sees what it looks like may be able to help...............
Sep 02, 2012 | JVC Televison & Video
I have a red line going accross my tv screen. Its
Do you have speakers next to your tv sometimes the line on your tv will be from your sound to close to your tv also the red line could mean your tv tube is going out there about 300 to replace but i ould check frist on your sound are something close to you tv that is maken the red line in the middle of your tv
Dec 09, 2009 | Sony KP-51WS510 51" Rear Projection...
Red arching lines showing up on screen promident when a dark background is present
Red picture tube needs screen voltage adjust. Open fornt or back of TV and look for a black square looking box with adjustment knobs. Look for red screen adj and slowly turn rt or lft until lines just disappear. If screen goes too bright tv will shut down, just turn back on again and retry
Dec 04, 2009 | Sony Televison & Video
Red and green curved lines when the screen is dark
Your convergence board is going out. this will have to be replaced. i would take a look at the main logic board as well. it could have minor point breakage.
Feb 09, 2009 | Sony KP-57HW40 57" Rear Projection...
LOST RED COLOUR
Good day.
Please check capacitors along the flyback section for leakage. Also, please consider loose contacts along the circuitry.
regards,
chris
Aug 16, 2008 | Televison & Video
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
regards,
Jul 31, 2008 | JVC AV-32120 32" TV
Blue screen
no sounds on tv
Feb 25, 2008 | JVC AV-27260 27" TV
JVC tv AV-27D304
Roger, if your contrast (sometimes called picture) and brightness controls are at max you can increase the tubes brightness by turning the "screen control" clockwise, be advised a little turn goes a long ways, don`t crank it too far or you will get retrace lines, you will have to remove the back from the set and follow the red wire down from the tube to the "flyback transformer" on the front of the flyback are 2 controls, focus and screen, do not move the focus control, this should fix your problem.
Nov 20, 2007 | JVC AV-48WP30 48" Rear Projection...
Color messed up
Most likely your visitor turned one of the controls located on the back of the TV. There are only two controls they are the right side of the set in the back. The top one is the focus and the bottom one is the SCREEN control. You can carefully rotate clockwise the screen control until the brightness is back to normal. If you go to high with it you will see faint diagonal lines going accross the picture.
May 02, 2007 | RCA F19207BC TV
Try # 2... Green Fog
The green gun in your picture tube is set a little too high. If you are experienced in removing the back cover of TV's,etc., you may try to find the drive and/or bias controls either on the circuit board that plugs on to the neck of the picture tube or mounted on the main circuit board of your TV. These controls are usually labeled. If you can find them, locate the green bias or drive control and back it down a little while watching the picture through a mirror. A slight adjustment may correct your problem.tJIS IS CALLED GRAY SCALE ADJUSTMENT. BE CAREFUL THERE ARE SOME HIGH VOLTAGE CIRCUITS NEARBY. WORK WITH ONE HAND AND USE AN INSULATED TOOL TO MAKE ADJUSTMENTS I hope this may help you.AGAIN BE CAREFUL!! Stargazer
Feb 26, 2007 | Toshiba 32HFX71 32" TV
Televison & Video Logo
159 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
