Question about Toshiba Qosmio G25-AV513 Notebook
Shuts down completly off
Laptop will shut off at any time and will restart no problem. problem seems not to happen when unpluged.thank you rp869@aol.com
  • 689 Answers
There are many reasons for the shut off, Best thing is to perform diagnostic from most possible to the least possible option step by step.
  • Check if there is any application running in background which takes excessive memory and system resources (To see the active processes click Ctrl+Alt+Del)
  • If issue happened after a hardware or software installation you may use system restore option to revert the settings to the earlier date and check if issue still persists.
  • Make sure you have reliable updated anti-spyware and antivirus solution.
Please post after check the steps listed above and post the outcome.
Good Luck
Posted on Feb 07, 2008
Cq60 shut down and restarts itself
Common if backup, windows update, or defrag is scheduled to run at night. Other scheduled operations may use the restart function as well.
Feb 18, 2014 | Compaq Presario CQ60-204NR Notebook
I need to reboot my laptop but i don't know how
Reboot essentially means restarting the computer. This is two types
1. Warm Reboot: where you go to start on windows task bar and choose shut down but when prompted choose restart. This way computer shuts down momentarily and restarts!
2. Cold Reboot: By this means you choose to shut down and again when prompted choose shut down! This makes computer off completely until restart by pressing power button.
Booting is computer Lingo for above procedures!
Oct 02, 2011 | Compaq Presario CQ56-115DX Laptop
Hi, My Samsung R580 I3 JBB2-US keeps on shutting down. If I close the lid when I re-open it shuts down & I have to restart or it freezes and I have to force restart. Sometimes when I boot up it...
You can try go to Start - Control Panel - Power Options and check what you want computer do when you close the lid of your laptop. Fix that and restart laptop to apply the setting.
If the boot up not complete and restart by itself, in my opinon, there is something wrong on the start up process, could be hardware malfuctions, could be a software not compatible. Try check the start up process to see.(use Start- Run: msconfig)
If this happen often, you should call the Samsung customer services to find out. Laptop i3 should still under warranty.
Hope this will help.
Thanks for reading
Jul 20, 2011 | Samsung R580 Notebook
After shutting down my HP LAPTOP, it won't restart. If you push the "on" button, there's no response. I noticed that about 3 days before this happened, the system cannot...
- try to remove the battery of the laptop and unplug the power cord
- hold the power button for 20 seconds to drain the remaining power
- turn on the system
Jul 09, 2011 | Computers & Internet
Hp 6910p laptop wont turn off. Fan running. what gives?
Something is keeping it from shutting down. This could be caused by a faulty application or driver. My suggestion is to hold the power button down until the unit completely shuts down. Take out the battery, unplug the ac-adapter, attempt to power it on and then put the battery back in. Attempt to restart the computer.
Good Luck!
Mar 29, 2011 | HP Compaq Business Notebook 6910p - laptop...
Shutdown problems
I assume it is not shutting down. Do a complete reset, unplug computer from wall push power button in for 3-5 seconds, then plug it in and restart the machine. Then let it complete the boot up process then go to start and shut it down again see if it shuts down now. Thanks for the question hope this assists you. John
Jan 21, 2011 | Gateway DX482203 (PTGA002009) PC Desktop
I want to restart or reset my laptop. how?
Few steps to restart you laptop, I would suggest not to restart often since it will degrade the hardware resource.
  • Determine what operating system it uses. Finding out what operating system your laptop uses will let you know what key combo (such as "Ctrl+Alt+Delete") can exit you from usage and trigger a reboot or shutdown.
  • Try and reboot using the operating system. Attempt to use the key combination that will allow you to exit from the operating system and restart the laptop. Be patient, as it may take some time if it has locked up.
  • Hold down the power button. If the operating system's answer to the rebooting will not work, find and hold down the power button of the laptop. This should cause the device to shut itself off. You'll have to press the power button again to power it back on, completing the reboot.
  • Unplug from the wall and remove the battery. If restarting via the operating system and the power button do not work, unplug the laptop from the wall outlet, and remove the battery from the laptop. This will cause it to power off immediately.
  • Allow time to reboot. Give the laptop time to cool down before you power it back on if you had to do this manually.
Else Try:
Windows start > there's a small arrow(pointing RIGHT) in the left bottom > click it and u will get ALL the Power House Options there at your Click(sleep,hibernate,shut down,RESTART,....)
Oct 11, 2010 | Computers & Internet
It won't turn off
I would say,Yes you should be worry there a lot things can be affecting you laptop try ctrl + alt then delete then appear a windows task manager go to shut down it will appear stand by,turn off ,restart etc.hit on restart and wait what happens if doesn't restart could be your memory or many thing I alredy explain.Good luck
May 23, 2009 | Acer AOA150-1690 Aspire Notebook
Toshiba Qosmio G25-AV513 Notebook Logo
62 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
