By any chance is your printer a Lexmark?
1203 Error Message indicates a problem with an ink cartridge. Can be a communication failure between the printheads (cartridges) and the printer or a short in one of the printheads.
Commonly occurrs with refilled ink cartridges and indicates the cartridge has been overfilled.
If powering off and restarting the printer does not correct the problem, to remedy, remove the ink cartridges, check for leaking or excess ink on the cartridge contacts; clean the cartridge contacts using a water dampened q-tip. See for illustrated instructions:
http://support.lexmark.com/index?page=content&id=HO2322&locale=EN&userlocale=EN_US
If the problem is with over-filled cartridges, to avoid a repeat, you may need to wick out some excess ink by placing cartridge on a damp paper towel.
If these steps do not resolve your issue or your problem is not with a Lexmark printer, please reply with the make and model number of your printer for an alternate solution.
Thank you for using FixYa!
I'm not sure I understand the question are you using refilled cartridges and the printer wont accept them or are you using new cartridges and the printer is mistakenly seeing them as refilled. A little more info will help
Thanks
Carl
