Question about Splendide 2000S Front Load Washer / Dryer
Where can I order parts for splendide 2000S?
Specific part is P/N 082299 door handle assembly, white
    President:
  • 670 Answers
You could try repairclinic.com.
Posted on Jan 03, 2010
  • hatefools Sep 21, 2010
    They DO NOT HAVE Splendide parts! Try checking before shilling for some business!
    Top Expert:
  • Splendide Master
  • 10,033 Answers
Parts ordering from distributor or RV service
Posted on Nov 25, 2017
    Problem Solver:
  • 19 Answers
Http://www.splendide.com/wd2000s.htm
Also try Westmorland Sales.
Posted on Oct 23, 2010
  • Ixa Rodriguez Oct 24, 2010
    service@westlandsales.com or www.splendide.com
    New Friend:
Can anyone help me figure out was is wrong with my 2000s? It started out by having water in the drum a couple of days after using the machine. It was not a cup of water. It was half way up on the door glass. I would put it on spin and get rid of the water so I could load it and use it. Now it will not fill with water when I set it to wash a load of,clothes.
Posted on Jul 09, 2013
  • Johnny Waggoner Sr
    Johnny Waggoner Sr Nov 07, 2017
    Unscrew the small drain at the bottom right on the front, clean it out. Change gets in there and clogs the drain. After you clean it out run another cycle on spin and clean it out again. Had a lot of change in my sons.
SOURCE:
14802042 splendine 2000s door handle - Splendide 2000S Vented Washer/Dryer
that model number doesn't show up go here and look it up with the full model number off of machine
https://www.searspartsdirect.com/model/search.html?q=14802042
Nov 10, 2017 | Splendide Washing Machines
I need a door handle for a Splendide Combo washer/dryer. %036552563
I may be able to help as I just removed a washer from a motorhome -- in pieces-- contact me if you'd like Dwight 209-531-6943. - Presently in Calif.
Feb 25, 2015 | Splendide 2000S Front Load Washer / Dryer
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Door handle broke on splendid 2000s
Try looking at the link at the bottom. There is a phone # on page 1 and the parts for your machine is on pages 4-19. I hope this helps.
http://www.beamalarm.com/foretravel-links/PDF/Splendide_Combo_Parts_Break_Down.pdf
Jul 22, 2011 | Splendide 2000S Vented Washer/Dryer
Oven door handle is loose on Model RF366BXD self cleaning range, how do we tighten the door handle?
Extend your door hinges and remove entirely over to a table or other flat surface where you can do a step-by-step dis-assembly. Unfortunately, to get at the interior of the handle unit, it's the final stage of the taking apart. Begin by removing the bolts at the bottom of the door, then the main panel and side flanges can be removed. (You can give your glass a good cleaning at this point also.) There are 2 bolts to remove to free up the handle unit, and now you can easily tighten (or replace as needed) the 2 pairs of handle bolts. Reverse your order to re-assemble, and put your door back on the oven. It's not as bad an exercise as it would appear. Just take your time and watch what you're doing. I used the hinges as a shim, and had it laid out on a pool table for easy, elevated examination.
Dec 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My handle door is broken.
Hi and welcome to FixYa, I am Kelly. There are 4 different doors for this microwave see this link:
http://specsserver.com/CACHE/FRJVHRUTDMYQ.PDF
Item 58 is the door handle
Part numbers are:
5304440323 - - - - Handle, door, black
5304440325 - - - - Handle, door, bisque
5304440324 - - - - Handle, door, white
Stainless handle not listed.. I assume it is a black handle
This has to be one of the more expensive microwave door handles I have ever experienced.
The least expensive source I found was at sears parts direct.
5304440324 Handle door white Price $88.80
http://www.searspartsdirect.com/partsdirect/part-number/5304440324/0022/628?pathTaken=partSearch&filterPart=&pop=flush
5304440323 Handle door black Price $98.97
http://www.searspartsdirect.com/partsdirect/part-number/5304440323/0022/628?pathTaken=partSearch&filterPart=&pop=flush
5304440325 Handle door bisque Price $88.80
http://www.searspartsdirect.com/partsdirect/part-number/5304440325/0022/628?pathTaken=partSearch&filterPart=&pop=flush
Note that Item 51 of the first link (top one) is the complete door assy. Also Item 60 is the door HANDLE screws (2 ea)
Just from looking at the diagrams in the first link, it appears item 56
Frame, choke cover, inner door
must be removed to gain access to the handle screws.
I looked up many sources for the handle assembly because I had a hard time believeing the handle was so expensive. Sears was by far the cheapest source.
Thanks for choosing FixYa,
Kelly
Nov 13, 2010 | Frigidaire FMV156D Microwave Oven
Need a new door opening handle?? the handle broke
You should be able to order one from Splendide. In the meantime, try using a screw driver to manually push the door release button.
Michael Lee
Thor Appliance Company
www.thorappliances.com
Sep 22, 2010 | Splendide 2000S Front Load Washer / Dryer
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Splendide 2000S Front Load Washer / Dryer Logo
7,567 people viewed this question
Top Splendide Washing Machines Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
