Question about Hoover Refrigerators
Hoover Contour Refrigerator - not holding temperature
Hello. I have a Hoover Contour refrigerator/freezer (around 360L). Approx. 12yrs since purchase. I have noticed food in the freezer is not freezing, eg. softened ice cream, and food that was already in the freezer has thawed out. The compartment is still cool. I have adjusted the internal thermostat to the coldest setting but this has not altered performance. The fan also appears to be continually running.
Does it sound as though this problem can be easily rectified?
Thanks
Dino
    Top Expert:
  • Hoover Master
  • 25,306 Answers
Possibly a re-gass after repair may solve the issue.
Posted on May 13, 2017
5 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
Posted on Oct 14, 2007
turbo5280
SOURCE: Kenmore refrigerator freezer not freezing
The problem is in the defrost system.. You have a defrost heater in your freezer that comes on 3 times a day & melts the frost to keep your freezer frost free. That frost turns to water & runs down a drain & eventually goes to a drain pan located under the unit. On these models the hole for the drain is located directly under the evaparator fan. The drain hole is to far from the heater so the water settles & then freezes around the fan blades causing it to stop spinning. Its that fans job to circulate cold air from the freezer to the fridge, so now all the cold air is staying in your freezer. Last I knew they were workin on a solution to this but you need to contact the manufacturer. A temporary fix would be to unplug & then defrost the freezer by taking out the freezer panel & melting all the ice. Boiling water is effective. When you get the ice gone from around the fan you should be able to see the drain hole & be sure water runs freely down the hole. Put it back together then adjust the front legs of the fridge so the whole unit slopes back slightly causing the water to run back to that drain hole without settling.
Posted on Apr 27, 2009
heatman101
  • 43501 Answers
SOURCE: Hear fridge/freezer running but not freezing & not cooling @ 9.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 23, 2010
SOURCE: Everything in the freezer is
loss of freon
Posted on Jul 31, 2011
Freezer digital temperature does not default back to 0. It slowly goes back up to 29.
Hello Terry, thanks for your inquiry!
From the information you have provided the temperature is not holding at 0°F inside of your Frigidaire refrigerator. Is your freezer currently cold? Does anything display on the front of the refrigerator? You may need to perform a reset on your refrigerator and you can do that by disconnecting the power cord for at least ten minutes. If this does not help resolve your issue I would recommend seeking help from a professional technician for proper diagnosis. This will help you avoid any unnecessary part purchases. -Matt
Apr 19, 2016 | Frigidaire FPHF2399MF Professional Series...
Where can I get a replacement for the cover of the vegetable tray for a Hoover Contour HE 423UF refrigerator/freezer?
If you are uk you could try partmaster.co.uk . I assume you have tried eBay , sometimes parts are available from there.
Jan 19, 2015 | Hoover Refrigerators
Why is my refrigerator not working properly? well , since I got it I have problems because it never seems to get cold or work properly. I think it might be cause it is digital.
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. "d" and "F" will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Nov 26, 2010 | Frigidaire Microwave Ovens
We have a Hoover No frost refrigerator/freezer. There is no control for the fridge temperature which is now running very cold (it freezes drinks, etc.). What can I do to increase the temperature of the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 16, 2010 | Hoover HCA391FFK Bottom Freezer...
My frost free fridge freezer is too cold and freezing the food in the bottom drawer there is some ice around the bottom drawer
You may have an issue with the temperature control assembly. Check the temperature settings (ideally at "one-half way" for both fresh food and freezer compartments).
Contact an appliance service company.
Feb 19, 2010 | Hoover HCA390FFK Bottom Freezer...
Hello, I have a Whirlpool refrigerator that is just over a year old (Model #ER8YHMXSB00). The freezer seems to be working fine but the refrigerator will not cool below approx. 50 deg F. This just started...
Refrigerators and Freezer combination units have one common compressor and coolant for both units. If the refrigerator section is not getting cold I would check the following.
The cold zone is not blocked by a bag or box? The cold zone would be the coldest part of the refrigerator which vents the cold air from the freezer to the refrigerator.
Is the fan working on the refrigerator to vent the cold air to the refrigerator? You should be able to hear it when you hold the door switch.
The thermostat is not working which I have found most common is the thermistor is not registering the correct temperature causing the fan not to turn on.
Thank You for using Fixya.com
Jul 31, 2009 | Whirlpool Refrigerators
Hoover frost free fridge is freezing every thing in fridge department
Sounds like a defective refrigerator control. Refrigerator temperature is what turns the whole system on and off. First check the settings. a starting point is midway on the scale for both the refrigerator and freezer controls. If you already have the refrigerator temperature set at its minimum setting then it is that control which is causing the problem.
May 28, 2008 | Hoover Refrigerators
Refrigerators Logo
52 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
tom wright
tom wright
Jim Goldsmith
Jim Goldsmith
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
