Question about Nikon Coolpix P1 Digital Camera
Shutter guard won't close completely
I just noticed that the lens guard on my P1 isn't closing completely when I turn off the camera. All else seems to be working fine. Any ideas?
  • Anonymous Apr 08, 2008
    me too have the same problem any solution
    DSC-S650
  • Anonymous May 16, 2008
    You problably have your CARD Locked, try to unlock the card!! and this will problably work!!
Buy another camera. Nikon sucks in my opinion. 2 years and the same issue.
Posted on Apr 21, 2008
6ya staff
SOURCE:
I have a hasselblad 503cx. when i hit the shutter button, the back part of the lens opens (where the film is) but the lens shutter is closed. when i let go, the lens opens and the back closes.
The proper order of exposure should be:
Curtain opens/Lense stops down (unless wide open)
Lense shutter closes
When releasing button, curtain closes
When winding, lense shutter opens
If this isn't what's happening, something is wrong. There is only a simple mechanical screw connection between body and lense, so it'd have to be an issue with the gears in the body.
May 21, 2011 | Hasselblad 503CX Medium Format Camera
When i turn the camera on and switch to picture mode the screen is completely black, and if i take a picture, the picture turns out completely black
Very easy to fix for your camera. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Recommend Fix 5A in the link, by gently flicking with your fingertip as described in the article.
Dec 22, 2010 | Canon PowerShot SD1000 Digital Camera
When I turn the camera on, the lens doesn't open to allow me to see the subject I want to photograph.
Hello :
That's a common problem on these cameras. A moving coil actuator melts down inside and locks up an internal shutter closed permanently. You will need to open the camera and remove the shutter completely; no way to fix it.
Jan 15, 2010 | Argus QuickClix 5150 Digital Camera
Viewing screen is completely blank and will not take pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Dec 26, 2009 | Canon PowerShot A620 Digital Camera
My Canon PowerShot SD1000 shoots completely black pictures. The lens is open and there is no damage to the lens or the screen. The battery is fully charged and I've even tried a different memory card. It...
Nov 06, 2009 | Canon PowerShot SD1000 Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
Lens cover stays open
hello lmsmith, the reason the lens protection shutter does not close, is that it is either jammed by sand, dirt or sticky substance. it is going to need cleaning by a qualified technician.
Jun 04, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Shutter will not close!
very small dust particals are the reason of this problem.I m suggesting an idea but apply it on your own risk.Keep camera in off position then slightly strick with ur fingernale around the lens ring evenly.This can make the lens shutter contrct.Once the shutter closed,clean gently with a painting brush over the edges where shutter slides from.do this for several times so that any hard dust partical causing may removed.do not insert anything inside.
Aug 12, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Nikon Coolpix P1 Digital Camera Logo
61 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
