Canon MP470 Pixma All in One Printer
Problem for Canon MP470 Pixma All in One Printer
MP470, Paper jam on one side
By mwanzia on Feb 01, 2008
I have just bought a new Canon Pixma MP470 after the serious adverts of it in the web. I only made 30 copies with it and paper started. Every time I give it a command to print or copy, the paper instead of going in evenly slides to one side where there is a roller and jams. The machine goes on as if printing job is on whereas it is not. I cannot do anything at the moment. I am so frustrated because I have imported this from America to Italy and now it cannot work. Any help out there? I wll be deeply grateful.
Mwanzia
Same Problem
May 11, 2009
-   I'll be....I found a nerf foam dart stuck in there.............. -   Guest
May 09, 2009
-   I had the same problem. Paper just kept jamming to one side when loading and I would get smearing. I did cleaning maintenance and still got smearing and the paper not loading straight. I googled and came across this page. I had no clue what else to do, so I just took the advice of turning my printer upside down AND OUT COMES A PIECE OF TOY PLASTIC! Everything works fine now. I never would have thought the cause was something so stupid like that. So it seems it's not really Canon's fault but something being jammed. -   bakadane
May 06, 2009
-   i had the same exact problem... paper jam on the right side. it was so frustrating! i came across this site, and sure enough... i had something stuck in it! i little piece of candy from a "pooping penguin" toy. who'd of thunk it?-   Guest
May 02, 2009
-   I had the same problem with the paper feeding to one side and then just jams. I turned it upside down and banged it and could not find an obstruction. So I decided to manually feed a thick piece of paper-the thin won't due through the printer and what pops out a rubberband! Thanks to all who have posted about this problem, I thought I was going to have to buy a new printer--Mj-   nimbusmj
Apr 26, 2009
-   I have the exact same problem. However, I can see an obstruction. There is a small, jagged piece of (what appears to be) plastic in the way.
My original problem came from a simple paper jam, and when I removed the paper, the printer ripped off a small (4cm x 4cm ish) corner of the paper. I thought this was causing the jam, but I have since found the paper and removed it, all to no avail.
I'm fairly sure that jagged piece of plastic should NOT be there!!
-   hobbit27
Best Solution
posted on May 29, 2008
Helpful)
gyjono
Rank: Apprentice
Rating: 83%, 9 votes
I have the same problem.The printer is five weeks old and has been used once. I talked on the phone to a Canon tech today and after going over a few things to no avail, he said they would send a new printer to replace the one I have now.
Was this helpful?
Yes
No
Solution #2
posted on Jul 19, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
We have the exact same problem. Great for few months then paper jams on right side. No obstructions. Feel like throwing it out the window, but we live on 1st floor, so the joy of watching turn into heap of plastic particles is lost!
Solution #3
posted on Jun 17, 2009
Very Helpful)
moishier
Rank: Apprentice
Rating: 100%, 2 votes
I did the same thing as many above - shook the printer, then fed a piece of card stock backwards and discovered a peice of plastic! Thank you!!
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Jun 12, 2009
Very Helpful)
jamesh536
Rank: Apprentice
Rating: 100%, 1 votes
I had the same problem. Worked for a long time trying to solve it. Cleaned the rollers, tried to back feed paper - even tried to take the printer apart to see if I could find something stuck in the roller. Found this site - didn't think it would work - but tried it and it worked. Didn't turn it upside down as much as on its back - a few pats and out comes a plastic hanging file label. Works fine now. Funny thing was - if you were lucky you could get the paper past the rollers - but now it works.
Thanks
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Apr 29, 2009
Very Helpful)
maxebygm
Rank: Apprentice
Thanks to everyone! My MP470 is working again..and yes, it was a jam. You couldn't see the jam because it was RIGHT under a center roller. I fixed it by reverse-feeding and then forward feeding some heavier cardstock paper through the rollers and pushing w/more force each time. Eventually, I saw a piece of I don't know what in there and was able to force it out. It was under the white plastic piece right between two of the white plastic rollers somehow..who knows how! Thanks everyone.
Was this helpful?
Yes
No
Solution #6
posted on Aug 30, 2008
Very Helpful)
bhavik100
Rank: Apprentice
Hello, I have the MP470 and 2 small kids, found that paper was constantly jamming during feed (to the right). Resolved issue by
unplugging printer and shaking it, this is when a "2 pensil falls out - this kids must have thrown in. Was ten able to print sucessfully without any issues
Was this helpful?
Yes
No
Solution #7
posted on Aug 24, 2008
Very Helpful)
cavanaughtim
Rank: Apprentice
I have the exact same problem. I don't know if it's related, but when I opened up the printer to look for the source of the jam, I found a tiny spring that had come loose. I couldn't get the spring back in place, and the printer is still totally broken, but I wonder if this might have something to do with it. So infuriating!
Was this helpful?
Yes
No
Solution #8
posted on Jan 02, 2009
Very Helpful)
rhythmark
Rank: Apprentice
Rating: 97%, 8 votes
There is something jammed in there....shake it upside down first.....if nothing then revese feed a paper through it manually......take left side off hold paper in front and roll wheel on the left side so the paper feeds back into the machine,,,,,,open top to see in there and when paper feeds under white rollers make sure it dosent jam where wite rollers are about an inch from the right there is a small rectangle hole with a black plastic piece in there pry it up carfullywith a paper clip and feed paper with the wheel under it at that point the paper push out a bobby pin into my back tray,,,,, now everything works great.......keep checking i didn't believe something was there either but there was..... also if your paper first starts to feed and stops pull out the paper and check for a bend or crinp in it mine kept doing that and that is exactly where the pin finally came out.....
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #9
posted on Mar 31, 2009
Helpful)
jeremyvnc
Rank: Apprentice
Rating: 88%, 2 votes
Yep, did the same as above. Shake it upside down. If nothing comes out, then reverse feed through back rollers. Shake upside down making sure to turn it over so that the object doesn't go back in. I found a screw in mine (from removing the blinds above it the other day).
Was this helpful?
Yes
No
Solution #10
posted on Jan 17, 2009
Helpful)
gavinbrooke
Rank: Apprentice
I came across this site after wrestling with the paper feed mechanism. The paper would go in at an angle and then jam and the screen would report a paper jam. I could not see any obstruction. However, I tried the recommendation regarding reverse feeding paper from the front, turning the gear with my thumbnail. I used thick stock matte photo paper. This helped. Voila, there was a small hair scrunchie! Make sure when you put it in, you get the paper under the small white rollers. Gotta love toddlers!
Was this helpful?
Yes
No
Solution #11
posted on Dec 08, 2008
Helpful)
oriqn
Rank: Apprentice
here is how i managed to solve the "output error" jam - first obviously check for any extra pieces of paper - i then turned the printer upside down and shook it - nothing came out - i then reverse fed a piece of paper into the rollers in the back and hand turned it a few inches through using the gear on the left hand side of the rollers. pulled the paper back out by hand and voila! no more paper jam. hope someone finds this post helpful.
Was this helpful?
Yes
No
Solution #12
posted on Nov 02, 2009
Not Rated)
petershar547
Rank: Apprentice
Rating: 0%, 0 votes
My daughter at uni has phoned to say her paper is jamming.
Following the above solutions, I told her to turn it upside down because she probably had something stuck.
Guess what!
A pen fell out!!!
Great solution people. Thanks!
Comments:
Nov 02, 2009
- Thanks people.
My daughter at uni phones to say printer not feeding.
I say turn it upside down.
She says what!
Turn it upside down
Bursts of laughter down the phone!
A great big pen has fallen out!!!
Thanks people for great solution.
Was this helpful?
Yes
No
Solution #13
posted on Sep 24, 2009
Not Rated)
rmillerbil
Rank: Apprentice
Rating: 0%, 0 votes
The suggestion below about shaking the machine does not always work, When I saw the instruction feed backward I wonder how?
First on the left side of machine there are arrows just under the silver plastic piece, insert a small screw driver 2 place, then on the back side at one place, then lift the silver piece out and up to unlatch the two front hooks.
Then you will find 4 screws 2 in the from are silver two in back are black remove and then remove black plastic
Then I turn printer on back with output slot up, place paper between output roller
Careful turn gears on left side counter clockwise and paper should be drawn into the machine.
As paper come out of the input side, guide it so that it does not get jammed in paper tray parts.
Put machine back together and hopefully you will have solved your problem
Was this helpful?
Yes
No
Solution #14
posted on Jun 28, 2009
Not Rated)
phoenixkirk
Rank: Apprentice
Rating: 0%, 0 votes
I had the exact same problem! But the card stock solution fixed it! Thanks for the help all!
Was this helpful?
Yes
No
Solution #15
posted on Oct 27, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i shouved my hand down the back and felt somthing ( a coin lol) and i then unscrwed the scres behind the side the screen is on, and took off the scanner, (had to unflug a thing form circuitboard, easy as) the i put a plastic bendy card through a unblocked bit, grabbed on on the other side, now holding bot sides moved it along untill the coin poped out
Solution #16
posted on Oct 17, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I threw mine on the floor and it worked after that...
Solution #17
posted on Aug 31, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hey. Found the problem with my canon. A lighter slipped into the paper feed. Found it by unplugging it and shaking the #$%* out of it until it fell out. Didn't even know it was in there. Hopes this helps some of you guys out.
Solution #18
posted on Aug 27, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My MP470 began doing this and I'd only had it for a couple days. It grabbed/pinched one edge of the paper and couldn't seem to feed the paper through. I'd been messing with it, trying to get it to print, for the last few hours. When I read the message posted on August 8th I recalled that I'd earlier lost track of a push pin.
I took the paper out of my printer, turned it off and held it upside down. Sure enough the push pin fell out... And now it's working again.
Popular Solutions for Canon MP470 Pixma All in One
Questions and Unsolved Problems for Canon MP470 Pixma All in One
Do you recommend Canon MP470 Pixma All in One Printer?
Answer
Answer
pictures look great on screen but print out too dark
Answer
our printer is not taking paper and claiming it is jammed. When it occasioanally takes paper, it... (More)
Answer
my printer says the paper is jammed, but it isnt. this notification wont go away and i am unable to... (More)
Answer
I have been printing on t-shirt transfer paper for about a year with my MP470. Lately the black ink... (More)
Answer
Canon MP470; "Paper output slot paper is jammed" but there is nothing visible in there?.... (More)
34 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Apr 21, 2009
thank you all - shook mine upside down to find a small #2 pencil had been dropped in by the kids - printer works fine now
Comment by cbreuerw, posted on Apr 05, 2009
I have similare problem. I go to print and as the paper gets fed it it goes to the right and jams and smears. I looked inside and it seems the left roller wont move. don't know how to solve the problem. Clean?
Cathy
Comment by Guest, posted on Mar 31, 2009
wont feed
Comment by rhythmark, posted on Jan 02, 2009
I too Have the cannon mp 470 ...I copied only 20 times and now the feeder does not work....I say RECALL!!,,,,,,I tried contacting Cannon to no avail!!
Comment by Guest, posted on Dec 05, 2008
Had the same frustration described by others....only had the printer a few weeks, and it pulled paper to the right, jammed, and continued to run the cartridge as if printing. Read the cures offered by others about having something dropped into the back. Thought they were joking when they said they turned it upside down and shook loose (foreign) items out What the heck, I'll try it. Sure enough! A leaf fm the ficus plant fell out of the printer. Now it works! Guess the plant will have to move. Problem solved, daughter now happy I can print her birthday materials on time.
Comment by dluster, posted on Nov 30, 2008
mwanzia describe it to a "T". Is there no help from Canon? If not it will be my last Canon!
Comment by coolhand34, posted on Nov 19, 2008
The paper jams and only one side gets sucked into the printer.
What do i need to do to fix this problem.
Comment by Guest, posted on Nov 17, 2008
Yes I ahve the same problem and not able to solve it with all the solutions suggested by CANON
Comment by osuzannnah7, posted on Oct 18, 2008
THis seems to be a BIG problem. What a piece of ****!!
Comment by iluvlucy1978, posted on Sep 03, 2008
i thought buying our own printer would be easier but in fact,it's more frustrating...when i go to make copies the paper goes in sideways and creates a jam...i don't know how to fix it,i mean,how do you get the paper out?
Comment by Guest, posted on Aug 10, 2008
iv thee same problem this sucks
Comment by Guest, posted on Aug 08, 2008
I had the exact same problem. I went through the same steps as many on this board (cleaning the rollers automatically and manually). Just when I was about to throw the printer out the window, I shined my flashlight in the input tray one more time and tilted it to a more extreme angle: voila! There was a PEN that had apparently fallen into the printer and been pushed up inside it by the rollers or a sheet of paper. Wow, did I feel stupid.
Prints great now! :)
Comment by jimboly, posted on Aug 07, 2008
Printer claims the paper is jammed yet there is no paper in the machine!!!!
Comment by Guest, posted on Aug 05, 2008
paper jamming
Comment by Guest, posted on Jul 27, 2008
I have the exact same problem! I printed maybe 30 pages over a couple of weeks of buying the unit and it stopped feeding the paper completely. Paper would get caught to the right, printer would keep on printing. I tried cleaning the rollers and everything else. Nothing worked. If I get a piece of paper to start feeding I get the ERROR jam message as well. Now I know I have a large paper weight. Terribly disappointed considering I love Canon camera products and have thrown thousands at their company. I had another problem with the only other Canon printer I ever bought 2 years ago. Right out of the box the $100 Selphi picture printer would not power up. I won't be buying another Canon printer.
Comment by irenabarnas, posted on Jul 14, 2008
I have the same problem with my printer!!!
Comment by Guest, posted on Jul 08, 2008
Our new printer (which has been used to print about 20 pages) is doing exactly the same thing. It is frustrating. And hearing that my best choice is to exchange the brand new unit for a factory refurbished one is not a great solution. There is an obvious problem with the unit design. Too bad I didn't know this before I plunked down money to purchase this lemon.
Comment by Guest, posted on Jun 11, 2008
same problem!
Comment by curruco, posted on Jun 10, 2008
It appears in the screen error that there is paper jammed in the output slot,
but I don't find nothing.
Comment by Guest, posted on Jun 09, 2008
Well, I have the same problem, worked nice for 4 months and all of a sudden
Comment by Guest, posted on May 18, 2008
My complaint is nearly the same as mwanzia's. I send the print to (from my mac) & it starts printing but pulls paper to one side & then the paper doesn't feed at all but print heads continue to move as if the paper were feeding. result, no print.
Comment by lizou80, posted on May 11, 2008
I have the same problem here. Did you guys find a solution? mine prints but it now makes strange noises and it comes out smudged.
Comment by cathyd73, posted on May 03, 2008
I have the same problem with paper dragging to the right and jamming. I dont have any problem printing photos, only on A4 paper
Comment by Guest, posted on Apr 25, 2008
Have the same problem. It jams on right side and then stops.
Comment by terri1192, posted on Apr 23, 2008
paper won't feed through - it takes it crooked on right side and then won't go any further - can't find my manual
Comment by muzznyc, posted on Apr 06, 2008
Paper is jamming on the right hand side. Occasionally prints one or maybe two pages but will not print more. This after apx. three months of near perfect performance.
Comment by banak, posted on Apr 03, 2008
Not sure what is going on, but mine is doing the exact same thing.
Comment by Brooklyn61, posted on Mar 23, 2008
Same problem.. which is too bad, because I loved my last Canon printer and liked this one too for the first 3-4 months.  When facing the printer (output comes toward me), the feed problems seems to be on the right side, as if the roller is slow or not working. The paper feeds quickly on the left side, pulling the paper unevenly, causing a jam.
Comment by BillWh, posted on Mar 20, 2008
How does one get access to the paper entrance slot to clear any obstruction?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repairmen
in , AR
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
