Question about Pentax Optio S Digital Camera
Peugeot 106 temperature light comes on, changed thermostat, no difference, radiator not heating up, heater is working ok in cab, also retightened fan belt. can you help [please.
    Genius:
  • 1,067 Answers
Cheak oil status and anti freeze levels and quilty overheating sumware erther that or borke sensor
Posted on Feb 01, 2008
I have a T reg Peugeot 106, the temperature light keeps coming on even thou I've topped the oil up. Any info plz
Topping up the oil has very little bearing on engines overheating.
You need to remove the radiator cap and top up the cooling system with anti-freeze and water mixed to specifications. Note that I mention RADIATOR CAP and not the expansion reservoir cap. Remove the radiator cap with the engine COLD. Once you have filled the radiator, you need to run the engine until it gets to full operating temperature. Some of the water will overflow out until the thermostat opens, then the water level will rise and fall. When it has settled, bubbles have stopped, turn the engine off, top up one last time. Replace the radiator cap and then top up the reservoir tank.
There are videos online, Google 'burping cooling system', and look at the images tab. Here you go.
http://www.bing.com/videos/search?q=%27burping+cooling+system%27&FORM=HDRSC3
burping cooling system Bing video
Jun 02, 2016 | Peugeot Cars & Trucks
Overheating and heater blows cold air i changed the thermostat..
probably you changed thermostat with different temperature value... so change it to thermostat with same value like the old one
Feb 25, 2016 | 2001 Isuzu Rodeo
Water level is ok but light comes on 2002 impala
Friend,
If it is the temperature light ( not the check engine light) you may wish to check and see if the engine is actually hot.
(Be advisesd. An overheated engine is really serious! )
With the engine not running and cold, and the car level, take off the radiator cap very slowly to relieve the pressure, be certain the radiator is full, and then start the car.
Stand back in case the radiator blows antifreeze out.
Now start he car, and with the engine running, and when the temperature light is on, very carefully feel or smell the radiator and top radiator hose. If these are not hot, you problem may be a stuck thermostat. If the thermostat is stuck, you should sense the heat by smelling and listening to the motor.
If you have an overheating issue, please refrain from driving the car until it is fixed, or you could totally destroy the motor.
Also, there are 2 electric blower fans behind your radiator. One is for engine temperature, one is for the air conditioning circuit.
If the temperature light comes on, one of the blower fans should be running. If neither is, that may be your problem.
Be sure to leave your heater/air conditioner off during this test.
The most common problem is a bad temperature sensor for the fan, then a bad fan itself. After that, a stuck thermostat.
Blessings on your figuring this out.
Apr 13, 2015 | 2002 Chevrolet Impala
Freightliner columbia wont blow heat into cab have replaced thermostats and heater core blend doors work heater core gets hot and blower works but air from vents only gets to 80 deg
The air from the heater core will be as hot as the coolant temperature of the engine. 80 Degrees is the opening temperature of the thermostat and that will be where it remains until the engine starts to work or the ambient temperature rises.
Thermostats come in a couple of different opening temperatures so check around for one that opens around 85 degrees if you want hotter air in the cab
Another point is to close the recirculating vent door to the cabin as the heater core is trying to heat fresh freezing air if it is open
Jan 09, 2015 | Cars & Trucks
Peurgot 206LX--1.4 petrol. X REG...31.10.2000 .engine overheating? Worse when standing ( coolant Ok )
Some things to check - make sure that the radiator fan is coming on at the right temperature. It might not be turning on at all due to a blown fuse or a bad fan relay. Also, when the engine is up to temperature make sure the thermostat is opening up properly and be sure the radiator itself is not clogged. When the engine begins to overheat, turn the heater on (full heat, highest blower speed) and see if you get hot air and the engine temp begins to come down. This will tell you of the coolant is circulating properly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 01, 2014 | Peugeot Cars & Trucks
Drained radiator added prestone Radiator flush refilled and started overheating, drained radiator replaced thermostat and now I get no heat from heater,Radiator water is hot
disconnect the heat hoses going into fire wall , put hose into one with pressure and flush as it sounds like it could be bloked in the heater core,the other thing that could be the problem be the hot ,cold switch as it restricts the flow to makes the heater hoter or colder , it might need tlc or replacing as it is manaul not elec
May 08, 2012 | 1995 Toyota 4Runner
Why does my temperature light keep coming on and off and my fan keep coming on
Could very well be from over heating, or maybe a faulty temperature sensor, or thermostat, but the first thing to do is check radiator and coolant return bottle levels to make sure your not just low on coolant. Let me know what you find out after you check that. Note: remove cap(s) when engine has cooled down to avoid scalding. Then start engine, turn heater on, and add as needed. Is your heater working ok, as in putting out lots of heat?
Dec 31, 2009 | 1995 Audi 90
Peugeot 106 1.0 litre, temperature warning light on dash comes on one or two minutes after starting engine, sometimes stays on or intermittently goes off and on whilst driving. Also the radiator cooling...
hi, if the collant level is ok and the car isnt over heating then check the heater works in the car and make sure it gives of heat when hot is selected if it dont then the chances are the thermostat has gone and needs replacing.
If on the other hand you have heat then the chances are its just a faulty temp sensot these are cheap to buy and easy to replace.
Let me know how you get on or if you need further assistance ok
Dec 28, 2009 | 1991 Peugeot 405
Engine overheating
take one of you heater hoses off then start engine
Nov 19, 2008 | 2005 Peugeot 405
Pentax Optio S Digital Camera Logo
91 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
