Question about LG DLG2524 Gas Dryer
Remove front of Dryer
How do you remove the front of dryer so I can switch orifice for LP?
  • lpucci251 Jul 25, 2008
    Remove the front of dryer LG Model # DLEX7188RM
Go to appliancejunk.com and you can download the service manual. also make sure you don't move the set nut on the change screw.when you turn it in it take a little muscle. stubby screwdrivers are a must. we also removed the tube(2 scews)that was in the way of the oriface.if i had to do it again i could do it again it would be a snap
Posted on Feb 06, 2008
How do i convert from natural gas to LP or Propane?
You need the LP gas conversion kit: http://www.appliancepartspros.com/Appliance-Parts/whirlpool-lp-gas-con-item-number-ap4300853.aspx . Other sources may exist. This includes a replacement orifice and a spring and the installation instructions. The orifices are swapped with a small wrench. The spring fits inside the regulator inside the blocking plug.
You will also need to remove the cap from the regulator and turn it over. This makes the regulator compatible with LP gas. It's easy to tell which side is which - each side is labeled.
However, the conversion kit should be installed by a professional trained for the job. Your local LP dealer should be able to help you find a repair person with the skill. (Improper installation could result in a gas leak.)
I hope this helps.
Dec 09, 2010 | Amana NDG7800AW Gas Dryer
How to check gas valve orifice to insure its correct for a LP install. VDSC5304bwh. It was ordered LP but box has been written over many times nat/LP/Nat.. Searched the web ..no help..I am a HVAC...
What is the BTU rating of the dryer. If you open the dryer door, it is listed on the dryer behind the door. Most are 20,000 or 22,000 btu. The orifice # should either br 54 or 55 if it's LP.
May 16, 2010 | Viking VDSC305-4B Dual Fuel (Electric and...
How do I change the orifice on my kenmore dryer from natural to a LP orifice?
More and more, you have to change the gas valve AND the orifice due to the liability issue of changing only the orifice and not doing a complete conversion. If, and this might be a big if, a conversion kit is available, you will need the model # of your dryer to order it. The kit will come with a spring and a tension nut for the gas valve and the orifice you need. Instructions will come with the kit. Follow them to the letter. An improperly installed conversion kit, or just changing the orifice, can be very dangerous. LP operates at a higher pressure than the natural gas the dryer was built to use, and an improper conversion presents a significant fire hazard.
Mar 02, 2010 | Kenmore Dryers
Amana NDG2335AWW Gas dryer LP or Natural?
If there are no stickers indicating so, you will need to open up the dryer and measure the gas orifice. A propane orifice should be either a #54 or #58.
Jan 13, 2010 | Amana NDG7800AW Gas Dryer
I have Natural gas and am moving where it will be hooked up to lP instead. What do I need to convert to LP from Natural Gas
you will need an L.P. conversion kit. the kit contains a small spring, a new brass orifice and a new brass cap that fits on the gas valve. some kits are minus the spring. you will most likely have to remove the burner to put the new orifice in. any appliance repair store will be able to order you the kit. have model and serial number handy. good luck with your move into the country.
Oct 20, 2009 | Kenmore Elite HE4 Electric Dryer
How do I remove the front panel?
Hello, maytag makes it very hard to get to the lint.
You need to first take off the door, then the outer frame. The door has 4 philips screws and the frame should have 4 also. Good luck :)
Sep 15, 2009 | Maytag Atlantis MDG8400AW Gas Dryer
LG Dryer DLG7188RM LP conversion back to NG
Disconnect power. Open dryer door and remove 2 phillips screws near lint filter. Remove three phillips screws at very back of dryer top which go through an L shaped part into the back of the dryer. (the L shaped part remains attached to the dryer top) Push the dryer top back about 2 inches and lift off. Remove one screw at each top front corner holding front control panel on to dryer. Remove control panel by carefully releasing plastic tabs which are holding front control panel onto metal support. (Watch out for sharp edges !) You can unplug all electrical plugs, or just swing it up on top of the dryer. (careful not to scratch the plastic control panel) Remove the four phillip screws now assessable at the top of the dryer's front panel / door panel. Tilt forward, unplug door switch and drum light, and lift front panel off . Now set the panel aside. At this point, you may be able to continue with the conversion, but it is easier to do and see if you remove the drum.
To remove drum, Unplug the sensor wire at the bottom of the drum support and remove four phillips screws (going into sides of dryer) holding front drum support and lift up and remove front drum support. Reach in under the drum to unhook the belt. Take drum out.
Take two phillip screws out of flame spreader and push flame spreader back off brass orifice into the burner cone a bit to remove it. Unscrew brass orifice and replace with the Natural Gas orifice. Turn the brass slot headed regulator blocker screw on the front top of the gas valve all the way up. Reassemble.
Sounds complicated but it's not real bad.
A FixYa rating is expected with this much help. Thanks.
Nov 20, 2008 | LG DLG5932W Gas Dryer
Access to gas valve
I have the same problem ... please help me
Jul 04, 2008 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Lp conversion
You guys like things that go boom. My advice is to get a certified gas tech. To change the orfice to LP you have to take apart the unit from the front.
Sgt 48
Jan 30, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Lg conversion to lp
remove the top, and than the control panel, and than the front will come off to expose the gas burner on the bottom right side...
Oct 25, 2007 | LG DLE5977 Electric Dryer
LG DLG2524 Gas Dryer Logo
181 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
