Question about Nintendo Wii Console
A coin inside it
My litle brother had the smart idea to put a small coin inside his Wii and I cant seem to get the coin out and when ever I insert a disc it ejects it straight away
    Genius:
  • 1,067 Answers
Take it all apart u will ne small torx screw drivers from sears ok to get to it take it apart then lid off u can get coin out ok
Posted on Feb 01, 2008
6ya staff
SOURCE:
Wii grinding noise when disc inserted
You have damaged the player, have it repaired or replace it.
Feb 13, 2012 | Nintendo Wii Console
Please help me 4 problems concerning super mario bros star coins world 5-4 the last coin cant get world 6-5 cant find last coin world 7-6 cant...
Here try this one.
WORLD 5-4
You can find the Star Coin at this stage of this world. Look at the photo. heifentrixx_22.jpg
  • At this stage, you should pick up a Bob-Bomb and then quickly jump to the ledge.
  • Drop the Bob-Bomb in the white blocks to get rid of some of it and then drop down to the raft.
  • The Star Coin should now appear.
  • pick it up and then enter the pipe above.
WORLD 6-5
You can find the last Star Coin in a Secret Area with a Secret Goal.
  • Look for the four item box in the water. like in this photo. heifentrixx_23.jpg
  • You will need to jump or swim in the middle of the four boxes to reveal a hidden box that contains a beanstalk.
  • Climb up the beanstalk to reach the other area.
  • In the Other Area, you will need to pick up a propeller block.
  • Get the coins and the go right to the second floating box.
  • From this box, you will need to spin to reach the Star Coin and the Secret Goal.
WORLD 7-6
  • After you came across some small parabeetles,then you should come to a line of big parabeetles.like in this photo. heifentrixx_24.jpg
  • Look down low and you should see the Star Coin poking above the low clouds.
  • Ride down to the Star Coin using the Last Big Parabeetle.
  • Then wait for the small parabeetles. and then Jump down to get the coin and step on the small parabeetle. (Be careful in this part, you should jump at the right timing so that you wont fall off the clouds.)
WORLD 8-7
  • You should ride the next platform down as you jump a geyser like in the photo. heifentrixx_25.jpg
  • Stay near the front of the the platform so that you can grab the Star Coin before hitting the geyser.
  • After getting the Star Coin, quickly jump to the platform above you to avoid the geyser.
Thats it. Goodluck, Hope my solution helped. Please give some feedback regarding my solution.
Thank you for using Fixya! Have a Great Day!
Jul 13, 2011 | Nintendo New Super Mario Bros for Wii
Either my 2yr old brother or my 2 cousins put coins in my nintendo wii. This is the third time they have done it.The first 2 times, i shook my nintendo wii and the coins popped out but now i tried shaking...
If your Nintendo is under warranty, my advice is to take it to Nintendo service center..
If not you try removing the outer cover and remove the Coin...It should be poping out easil\y..
Dont try to shake it heavily, if the coim hits the Lens then your device eould be spoiled and you cant avail warranty..
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this sollution.
Thanks For using FixYa!
Vinod Kumar J
Dec 03, 2010 | Nintendo Wii Console
Pls help me... my dvd rom have coins inside.i didnt know.i put cd and then it cant open and i cant take out the cd aswell. my laptop is dell studio 1435... pls help me...
Look at the cover near the cd slot - it should still have the hole. You mention coins inside - kids? It seems probable that the cd was installed with power on, but you will still have the hole - it's small so that a paper clip will just fit into it. Since you have the coins probably still in there, I would disconnect power, remove the cover and pull the cd driver from the tower case. More than likely the cd and cdrom drive will be damaged beyond repair, but if you remove the drive from the computer you'd be able to shake the coins out of it and also to be sure the coins aren't going to short out *********** board. If you can do that then you might as well reinstall everything and put it back together, then power it up to check it. Who knows you might get lucky...
Sep 23, 2010 | Dell (JP-03G005-26401-16R-H324)...
My Whirlpool Cabrio washer has some coins trapped in the inside of the machine. I need to find out how to remove the agitator to check inside for more coins.
They are not in your agitator. they are in the pump on the bottom left if you are standing behind the machine. Be VERY careful. That litle pump seems to be the beginnig of many leaking problems.
May 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
How to remove coins from a nintendo wii
kids inserting coins in the video game??? is this? disassemble the wii and remove the coins...take a look in youtube and you will see many videos tutorials to disassemble it...
Good Luck!!!
Sep 09, 2009 | Nintendo Wii Console
My daughter has put a coin into the wii thru the disc slot an now i cant get it out can u help
That will be very difficult, the Wii requires a special screw driver to get the face plate off. It is called a Tri-Wing screwdriver, you can google for it if you'd like to attempt to fix it yourself.
There are two other ways you could try to rectify this. Unplug all cables from the back of the wii, turn it upside down so that the cd-rom slot is facing the floor, and shimmy it around a bit to see if you can get to the point where you are sure the coin is agains the cd drive. Then you could carefully attempt to stick in some small tweezers and try to grab out the coin. Just don't stick the tweezers in more than an inch or so, that way you avoid doing any damage. If you still can't get the coin out you should probably call Nintendo, they can fix it for you, and probably for free. Their number is: 1-800-255-3700
Jul 07, 2009 | Nintendo Wii Console
Remotes don't seem to register with gaming system
Before Pressing the Red Button inside the Battery Compartment. Make sure to open the Small "Door" on the Front of the Wii and press the Small Red "Sync" Button first and then Press the Small Red Button inside the Battery Compartment. You should hear a "beep" to confirm that your Wii Remote has been reconnected.
I hope this helps. Take care =)
Dec 08, 2008 | Nintendo Wii Console
Wii console
try or here
do not run the Wii till you get the coins out, you will cause more damage
you do need a special screw driver.
you can send it in to Wii or me!
Oct 24, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
274 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
