Question about Pentax Optio S5i Digital Camera
Optio lense stuck
The lens to my camera seems to be stuck. I was wondering whether there is a quick fix to it.
  • 2 more comments
  • Robehgojeh Feb 01, 2008
    Thank you for your comment. Tried your solution, but it does not work. Any other ideas?
  • Anonymous May 03, 2008
    Pentax optio s 50 lens is stuck open, camea will turn on momentarily and then shut off, tried new batteries.
    Appreciate help, adamandcathy@mac.com
  • NVirginian Jun 17, 2008
    Mine is stuck,too. It only turns on for a second and then shuts off right away. The battery is fully charged. Thanx for any help.
  • Christin84 Sep 15, 2008
    The same thing happened to me. Unfortunatley "lens lock" is not covered under the manufact. warranty. The only way to avoid this in the future (apparently it is very common with all digital cameras, especially the small ones) is to purchase the extended warranty from the retail store. Make sure that warranty covers accidental damage though!
    Genius:
  • 1,067 Answers
Try new hi powered fully charged bateries see if it gets itto pop open
Posted on Feb 01, 2008
  • nick helpap
    nick helpap Feb 01, 2008
    try take out sd card also when u test
I have fully charged the battery. Sometimes I can turn camera on and lense operates but no vision on screen and not able to take a photograph. but other times the lense will immediately retract. If lense...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
Jan 14, 2011 | Pentax Optio SV Digital Camera
Lenses are out/won't turn on/off
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
Apr 13, 2010 | Pentax Optio P70 Digital Camera
Petax Optio E60 lens error of 0x15110000
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 13, 2009 | Pentax Optio E60 Digital Camera
M40 Pentax - re tracking lens problem
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I must say credit where credit is due, Pentax Head Office Customer service was fantastic, they contacted the repairer, whom confirmed that my camera was in excellent condition and they took full responsibility for the repair cost. WELL DONE PENTAX!! I shall recommend to any of my friends whom are looking to buy a camera and any future replacement camera, will be PENTAX from now on. Great customer service, quick response all in FANTASTIC
Jun 11, 2009 | Pentax Optio M40 Digital Camera
Lense error, restart camera
Nov 22, 2008 | Canon IXUS V2 Digital Camera
Camera wont turn on&lens wont move
Folks,
Try to assist the machine mechanism. Turn the lenses (force is no necessary) when turning on or off. This should unlock the mechanism.
Aug 24, 2008 | Pentax Optio E40 Digital Camera
Pentax optio s6
This is exactly how my problem started. Then after repeated attempts to turn it on or off the lense actually stuck in the on position. After GENTLY forcing it in the off position, it began turning on and would immediately turn back off. After reading every problem posted that had to do with the lense I figured that the lense had somehow worked it's way of the "track or gear" that moves it in and out. I don't recommend this solution unless you figure that the cost of having it repaired proffesionally would be more than to replace the camera (I am a trial and error type of repair person). On my camera, also an S6, when the lense came forward and began to retract, I GENTLY held the lense in place for just a second. I repeated this probably four or five times until it "worked itself" back into the proper position. It does make the clicking noise while doing this which made me a bit nervous but it worked. The camera actually even seems to be focusing better which leads me to believe that possibly it hadn't been quite right for a while. AGAIN... you have to decide if the cost of proffessional repair is worth it to you. I am not a pro but this worked GREAT for me. Hope it helps.
May 18, 2008 | Pentax Optio S6 Digital Camera
Lens error
If it is a new[ish] purchase send it back via the seller. It may be an issue with the particular model. Get onto Pentax Tech support Team- See what happens- if it is an issue then a replacement free or at moderate cost may be available. If the camera is older -there will be no economic repair option.
Jun 20, 2007 | Pentax Optio 50 Digital Camera
Optio 450 Lens Stuck Problem
the lens cover gets stuck sometimes. It just needs a gentle touch and it opens up. Only happened once to me. In my case it happened after my daughter held onto the camera with her finger on the lens cover.
Sep 08, 2005 | Pentax Optio 450 Digital Camera
Pentax Optio S5i Digital Camera Logo
127 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
