I need a driver for the hp cp1700 printer to work under Vista (the driver supplied from Microsoft does not allow A3 or duplex printong)
Down load my printer and fax its not working
Posted on Feb 01, 2008
6ya staff
SOURCE:
HP Color Inkjet cp1700 Printer Driver Download
** Fixed **
I got my problem solved by followed below article steps.
http://printer-driver-download.us/hp-color-inkjet-cp1700-driver-download/
Thanks
Apr 08, 2013 | HP InkJet Office Equipment & Supplies
I'm not sure if this is a printer driver problem or a network problem. I have 3 computers networked (1 Vista, 2 XP)all using a CP1700 through a jetdirect print server. The vista computer works more or less...
So your printing to a network IP port? I don't this the setup is the problem if the computers see this printer as a network printer. I believe this to be a driver problem. I would try either a 5e or genric driver of some type. I'm not sure what type of printer this is so...
Sep 29, 2009 | HP cp1700 Color Inkjet Printer
HP Bus Inkjet 2800 won't print 11x17 with Vista
Many people had a similar problem with the Color Inkjet cp1700 B-size printer.
Vista Patch for cp1700 Printer - Fixes Duplex and Large Format Printing
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=2916&
General page with links to the cp1700 and other printers as well.
Vista Duplex Solution - Back Page Upside Down
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=43
and
http://www.vistax64.com/vista-print-fax-scan/172813-cannot-print-wide-format-hp-cp1700-2.html
Another solution that worked for some people was installing the hp deskjet 9800 printer driver.
It appears what you need is a patched .gpd file for the BI 2800.
Try emailing Bob Headrick, who has done these patches. (Thanks Bob)!
Be sure to put Vista and Large Format Printing 11x17 in the subject line.
[email protected] (or see his profile for email address)
Bob Headrick, Microsoft MVP Printing/Imaging
You'd think between HP and MS, they'd have this working right out of the box.
Did they think people would buy a B-size printer so they could hook it up to Vista and then not want to print mainly B-size documents?
They would have had happier customers if they would have included B-size support but left out A-size!
Amazing!
Good Luck
Jun 05, 2009 | HP Business InkJet 2800 Printer
Duplexer not working with my new vista 64 bit system, can't find drivers...the standard vista drivers don't work.
You could load the 32bit version of XP in to a VM and share the printer.  You would then print via the VM.
Why are you using 64 bit Vista?
May 28, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP laserjet 1300n won't print duplex from vista
in the printer driver setting there is option to turn on manual duplex printing.
Go to printer driver properties go to printing default under printing default there is a option called finishing in finishing print on both sides is mentioned select that option and i m sure it should work
May 03, 2009 | HP LaserJet 1300n Printer
Can't print A3 on an A3 Printer (Hp colour inkjet cp 1700)
There is a patch available to print A3/B size in Vista. Click here for details.
Regards,
Bob Headrick, MS MVP Printing/imaging
Jan 13, 2009 | HP cp1700 Color Inkjet Printer
Getting the Duplex Attachment to Work with Vista
what printer do you have?
brand and model?
do you has installed the newest driver and utility for vista operating system?
do you know that Vista and XP are incompatible in terms of drivers?
Vista has many drivers for a lots of printers, but these drivers are "generic driver". The generic driver is a small driver, an incomplete driver, and has a limited functions.
Sep 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Duplex printing
Greetings...
From the HP site...
This download includes a Print Driver only. This driver makes it possible to use the basic functions for the printer. HP will not be providing a Full Featured Vista Software and Driver for this product; therefore, some functionality may be lost when you use this product with Windows Vista.
What you can try to do is...
Uninstall the Vista driver and install the XP driver... this has worked for some HP printers...
Ed
May 26, 2008 | HP DeskJet 5150 InkJet Printer
5652 and Vista - duplex print not working
In Vista the default s the duplexer is "not installed". Go to Start, Settings, Control Panel, Printers, double-click on the Deskjet, Printers, Properties, Device Settings and set the duplexer to "Installed".
If the duplexer prints the back side upside down in Vista once it is enabled you can get a patch as described here.
Regards,
Feb 19, 2008 | HP DeskJet 5652 InkJet Printer
Auto Duplexing lost with Vista drivers
The in-OS and the Full Feature release drivers for some of our products have a problem with doing duplex jobs.
Start a command window as an Administrator
Hit Windows Key (or CTRL and Esc Keys Together) Choose All ProgramsAccessories CMD Prompt – Right Click and Choose RUN AS ADMINISTRATOR When to prompt comes up click CONTINUE to allow the Command Prompt to run as an Administrator.
Stop the Spooler service - Type net stop spooler
Change current directory
Type cd %windir%\system32\spool\drivers\w32x86\3
Backup the old gpd files – Type copy hp*.gpd *.bak
Extract the files from the zip file to correct location
extract files to %windir%\system32\spool\drivers\w32x86\3 directory
Remove old BUD file Type - del HP*.bud file
Restart to spooler service - Type net start spooler
Print something duplex to test.
Thanks
Mac
Jan 03, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Open Questions:
Computers & Internet Logo
51 people viewed this question
Ekse
Marvin
Marvin
