Question about Hitachi 50UX57B 50" Rear Projection Television
Blue digital array
My tv was working fine and then there was a click and the blue digital array went off and when I try to fix it it won't move and now I have this swoop on the top of the screen which is very annoying as you can see in the pics. Is there a way I could fix this alone or have someone do it for me? What happened? The red works fine but most of the blue won't move up or down. The Tv is about 5 years old and we never had a problem until now. Is this fixable or is it time to buy a new tv?
    Genius:
  • 1,067 Answers
Bad convernce bord chage it
Posted on Feb 01, 2008
Can't get digital array ligned up,I went by the operating guide got the blue to line up but the red won't move.
Please replace convergence output chips in tv to solve the problem. It requires good soldering skills/ expertise and click to buy convergence repair kit for this tv that has all required parts and instructions.
Hope this will help.
Thanks.
Jun 11, 2011 | Hitachi 60FX20B 60" Rear Projection...
50FX20B- I am trying to allign the digital array and cant get the red to move,how do I move it? (the blue WILL move)
Thanks.
Jun 11, 2011 | Hitachi 50FX20B 50" Rear Projection...
Blue shadow around picture. tried digital array blue won't converge. red and green work
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dul
Dec 02, 2010 | Hitachi 43GX10B 43" Rear Projection...
I have a Hatachi 43gx10b anf have a blue shadow that is warped, not straight, around the picture. I've tried the digital array but it won't converge the blue but the green and the red work. What can I...
Dec 02, 2010 | Hitachi 61SWX10B 61" Rear Projection...
Colors do not line up on my tv ( left side of sreen looks like 3D) digital array "+" are only white on right side.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 11, 2010 | Hitachi 50FX20B 50" Rear Projection...
Blue won't line up at the top in digital array
you need to replace both convergence ICs and the six 1 watt feed resistors. The ICs are both STK392-110 and the resistors you need one of each RK42 3.3 ohm 1watt, RK46 1.8 ohm 1watt, RK50 2.7 ohm 1watt, RK54 1.5 ohm 1watt, RK58 3.9 ohm 1watt and RK62 2.2 ohm 1 watt.
You can get replacement ICs and resistors at the following link with free instalation instructions.
http://servicemanuals.vstore.ca/
Jul 15, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Olevia 30 HVS
I had the same problem. I unplugged my tv to move to another room and it will not cut on at all. I have only had the tv for three years
Dec 12, 2007 | Syntax LT30HV 30 in. HD-Ready LCD...
Digital Array?
Replace IK04 and IK05, both STK392-110, but use instead STK392-150's for greater reliability. And don't get some Chineese knock-offs - use original Sanyo replacements. If you don't know where to get those try ACME Enterprises in Florida,
http://www.acme-sales.net/index.shtml
Also measure the low ohm feed resistors in that circuit. However usually just replacing the convergence amps will restore normal video...
Bill
Nov 17, 2007 | Hitachi 43FDX01B TV
Color Allignment
press menu on the remote and then u will be able to align the blue
Oct 30, 2007 | Hitachi 50GX30B 50". Rear Projection...
Digital Array?
I have the very same problem. Was there a solution to landfill2004?
Nov 13, 2006 | Hitachi 50GX30B 50". Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
61 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
