Question about JVC AV-48WP30 48" Rear Projection Television
Flashing pic flashes blue after warm somtimes green
    President:
  • 4,402 Answers
Well you can tap the convergence board and the crt boards see if you can find a loose connection, however be careful there is high voltage
Posted on Feb 01, 2008
Flashing
i would get in back dust it all out cheak fans ok maby add fan in on it to help heat go down main bord hairline cracks that will cuse your issue have to solder back in or get new main bord ok cuse of power heat kills these tvs
Feb 01, 2008 | JVC AV-48WP30 48" Rear Projection...
How do I transfer pictures from my usb flash drive to my pc?
Create a New folder on your desktop and name it anything you want, "new pics" "Pic's from Camera" Whatever. Next.
plug the usb/gig stick/flash drive into one of your computer Usb slots,..
a window Should open up with an option of View Files, So View the files, Which should be your pics. .. Copy all and go to your folder on the desktop and paste all your pics..
"IF A WINDOW DON'T OPEN"
Click on my computer and you should see a E drive or F drive With files in that Which should be your pic's look and see if they are your pics and Copy them to the Desktop folder for you computer to have them...
Sep 26, 2014 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
My samsung 61in. Dlp screen flashes green/blue pic is viewable but everything is the two colors, also screen will flash icon check fan #1
You have 2 problems. Problem 1 either you main board or light engine is bad and needs to be replaced. Problem 2 is exactly what your TV says. Fan#1 isn't functioning properly so a heat sencor is being actiated to shut down your set. Make sure all the fans are free of debree and spinning. If one is not spinning, make sure it has voltage going to it. This will let you know if you have a bad fan, or a bad board.
Jun 05, 2012 | Samsung 61" Slim-Depth LED DLP HDTV
42C128135UA-52 Phillips Flat Screen TV. I switched it on and all i got was a clicking sound and flashing green LED light which continues 1 long flash 2 short flashes. No picture whatsoever.
On the lower right side of the psu, (clamped to a heatsink), i changed the 8.5v (L4940P85) voltage regulator and it worked. As a test to single out the fault i warmed this component with a fine blue flame, this would make also make the tv work perfectly.
Aug 29, 2011 | Televison & Video
In a not so bright area,if u take a picture without the flash it will be all blurred and if u use flash then it comes too dark.
#1: takin pic w/o flash, please make sure you are in a well-lit (sunlight lit is best) area. please make sure focus is not moving, and camera is not moving. when green box appears, please be very still to get clear pic. i donot use flash, flash does exactly wat u say. so i use "scene" w/o flash.
Apr 25, 2010 | Samsung S760 Digital Camera
I was getting nine flashes and know the green crt
Sounds like a bad green crt. These Sonys are bad about that.
Jul 06, 2009 | Sony KP-65WS500 65" Rear Projection...
Turns green and shuts off
I had an electrician come over. He pulled out the bulb that was dead (for me it was the color that was flashing before it would turn off) and now I have a blue and green TV with no red. He said that the only way to fix it is to replace the red lamp with a new one.
Jan 16, 2009 | Sony KP-65WS500 65" Rear Projection...
No Green Light and no flash
I got the same problem, I haven't find the solution. Did you?
Dec 27, 2007 | Canon SPEEDLITE 580EX TTL Flash
Camera only takes pics without flash
Same thing happened to me. Agreee with your conclusion. Hope someone can confirm, especially who/cost of repair. Thanks, tj
Dec 19, 2006 | Konica Minolta DiMAGE X50 Digital Camera
JVC AV-48WP30 48" Rear Projection Television Logo
51 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
