Question about Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black
My bunn coffee maker CWTF-15 21604-0001
It doesn't make coffee as strong as it used to. We thought that the brand of coffee was the issue but that is not the issue. We switched brands and that was not it. Have you heard of this issue before?
  • debs248 Feb 01, 2008
    thanks it was the sprayhead!. Everyone here thanks you. The part was only $5.91
  • Anonymous Mar 18, 2014
    Already ran the spring of into the sprayhead tube. Still not running correct. To slow. Are there other places that need to be delimed and are there instructions on how to do this?
  • 60 Answers
It sound like you are either missing the sprayhead or the temperature isn't hot enough. Check first to see if the sprayhead is there. It fits under the brew basket and looks like a little shower head - it's round and has usually five or six little holes in it. If it is missing your coffee will be weak due to the water not being spread across all of the grounds evenly.
The other thing to check is the temperature. Depending upon where you live the water should be between 185F - 200F. If the water is below that temperature the coffee may look like tea.
Posted on Feb 01, 2008
Bunn cwtf adjust temperature
u must locate the lock bottom to open and re- programs ur temp. settings...
Jun 27, 2014 | Bunn CWTF 15-APS Coffee Maker
How much coffee do I use? I don't have a manual
The amount of powder required depends upon how strong or weak you like your coffee. I would suggest you start with around two thirds of a basket for a full brew and see how you find the flavour. Adjust the amount of powder used according to your taste. More powder = stronger coffee.
I can supply a manual if you need it but it doesnt specify an amount of powder to use.
Oct 04, 2013 | Bunn CWTF 15-TS Coffee Maker
I need to ship a 3 burner BUNN CWTF 15-3. How do I drain the water out?
You can take the lid off and unscrew the nut that holds the water tray. Then take a 3/8 hose to siphon the water out of the machine.
Apr 17, 2013 | Bunn CWTF 15-3 Coffee Maker
Bunn coffee maker heating element wont turn off
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Apr 13, 2013 | Bunn CWTF 15-3 Coffee Maker
Installation of grommet on model cwtf 15 ( 1 lwr/2 upr pf
Which grommet, there are several on the bunn models, but the most commonly replaced one is the one for the P. stat. Remove the top panel there are 2 screws one in front and one in back, then lift the top 2 burners off machine that will give you access to the tank.
Apr 30, 2010 | Bunn CWTF 15-2 (1 Top Warmer) Coffee Maker
Bunn CWTF 15 Coffee Maker Overflowing drastically
Have you tried resetting the brew volume(make sure board is not set to lock).
The only other thing I can think of is replacing the timer board, because its not telling the solenoid to stop brewing.
Apr 26, 2009 | Bunn CWTF 15-TS Coffee Maker
Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black Logo
123 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
Marvin
Marvin
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
