Question about Saitek Eclipse II
I can not get my Saitek Eclipse Keyboard to get my comp out of Stanby
I hit the key once the keyboard is in standby to pull it out and nothing happens. Everyone says there is a option under device manager to get it to get the comp out of standby but I do not see it. Can someone please help me with this?
  1. Open I can not get my Saitek Eclipse Keyboard to get my - shortcutcold.gifPower Options in Control Panel.
  2. On the Advanced tab, under When I press the power button on my computer, click Standby. If you are using a portable computer, click Standby under When I close the lid of my portable computer.
  3. Click OK or Apply, and then turn off the power or close the lid of your portable computer.
note.gif Notes
  • To open Power Options, click Start, point to Settings, click Control Panel, and then double-click Power Options.
  • You can also put your computer on standby by clicking Start and then clicking Shut Down. In the What do you want the computer to do drop-down list, click Stand by.
  • You might want to save your work before putting your computer on standby. While the computer is on standby, information in computer memory is not saved on your hard disk. If there is an interruption in power, information in memory is lost.
  • To put your computer on standby, you must have a computer that is set up by the manufacturer to support this option.
  • Using Power Options in Control Panel, you can adjust any power management option that your computer's unique hardware configuration supports. Because these options may vary widely from computer to computer, the options described may differ from what you see. Power Options automatically detects what is available on your computer and shows you only the options that you can control.
Posted on Mar 28, 2008
6ya staff
SOURCE:
On Saitek eclipse II illuminated keyboard: What is function of the 1 (above the f8), the A (aboveF9) and the down arrow between F10 and F11) Also the function of the dey on bottom row between the windows...
The 1, A and down arrow represent the usual Num Lock active, Caps Lock active and Scroll lock on option available on all keyboards out there.
The 'dey' key on the bottom between the Windows Key and the Ctrl acts as a right mouse button, as in opening the menu you would open with the right mouse click.
Hope it helps.
Dec 31, 2010 | Saitek Eclipse II Illuminated Keyboard
Ok when i hit the number 1 key i get `1 that and number 2 key brings a help manue three is ok and four is five and four and five is the same.
Your Keyboard keys is just dirty inside ; try opening it up and cleaning it up -- the circuits and touch detection underneath they key could just be misdetecting the "`" on the left of the "1" key and "2" key
Mar 06, 2010 | Saitek Eclipse II
Saitek Eclipse Keyboard Keys stopped working
this could very well be your OS as much as your keyboard. Try another board for a few days and see if it still happens. IF not...you found your culprit. Replace the keyboard or look for updated drivers if they exist.
Jun 02, 2009 | Saitek Eclipse II
Saitek Eclipse II keys are sticking
You can remove the screws on the back and clean the keyboard. It's very easy task to do. Just remember components locations inside so you can reassemble.
Jan 16, 2009 | Saitek Eclipse II
Keyboard is messed up
Try looking here to see if any of the keys are set wrong.
Normal 0 If you are then go to Control Panel.
1. Click on PRINTERS.
2. When the Printer Properties come up, CLICK on KEY SETTINGS.
3. Then set up the keys by selecting the key to be setup.
Hope this helps. Bud
Dec 14, 2008 | Saitek Eclipse (PZ30AUR) Keyboard
Saitek eclipse illuminated keyboard
Are the keys working?
If the keyboard is doing absoloutly nothing, then it may have drawn too much current from the USB port and shorted it out.
Try something else in the USB port and see if that is working correctly like a flash drive/mouse etc
Apr 13, 2008 | Saitek PZ30AU Keyboard
Keyboard has a mind of its own
HAHAHA. This is old but i found out what the problem is. Hope this helps some people. All you have to do is press the illumination button at the top right of your keyboard until the keyboard backlighting is turned off and now the keyboard no longer randomly types.
Feb 23, 2008 | Saitek PZ30AU Keyboard
Saitek Eclipse II: how to retain color choice after computer sleeps?
I think it is just the way it is. mine does that as well. b/c mine does the same thing on any computer i have it pluged into though.
Jan 16, 2008 | Saitek Eclipse II
Repeating key - cause unknown
No solution here, but I'd like to second that I have a Saitek 1st gen keyboard. One day it began exhibiting the same problems that you are having. When moved to another computer it seemed to work for a month or so but then started acting up again. For my keyboard, it repeats the letters "a" "s" "m" and others. Not sure what is causing it. No spills on the keyboard and it is fairly clean.
Oct 17, 2007 | Saitek Executive PZ18AU Keyboard
Saitek Eclipse II Logo
130 people viewed this question
Top Saitek Computers & Internet Experts
Vebble
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Saitek Computer and Internet Expert? Answer questions, earn points and help others
