Question about JVC AV-48WP30 48" Rear Projection Television
Flashing flashes blue after warm somtimes green
  • roystv Feb 02, 2008
    I am a tech I changed the convergence amps . there are no bad connections on the crt boards
    Scholar:
  • 110 Answers
Hiya Roy!
I'd recommend running a diagnostic and seeing what codes pop up. To run a diagnostic you need to enter the service menu:
Access the service mode: set SLEEP TIMER to 0 MIN.
While this is still displayed, simultaneously push DISPLAY and
VIDEO STATUS.
If you're successful in this, please report back with any codes that it turns up.
Posted on Feb 22, 2008
    Genius:
  • 3,422 Answers
The problem is with the horizontal circuit and you have to replace.I suggest you to call a tecnician the charges will be over $150 plus extra service charge for coming home and fixing it.
Goodluck,
please Don't forget to rate me as fixya..
Posted on Feb 01, 2008
    Genius:
  • 1,067 Answers
I would get in back dust it all out cheak fans ok maby add fan in on it to help heat go down main bord hairline cracks that will cuse your issue have to solder back in or get new main bord ok cuse of power heat kills these tvs
6ya staff
SOURCE:
My kobo wont turn on
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Dec 05, 2017 | iPhone Apps
42C128135UA-52 Phillips Flat Screen TV. I switched it on and all i got was a clicking sound and flashing green LED light which continues 1 long flash 2 short flashes. No picture whatsoever.
On the lower right side of the psu, (clamped to a heatsink), i changed the 8.5v (L4940P85) voltage regulator and it worked. As a test to single out the fault i warmed this component with a fine blue flame, this would make also make the tv work perfectly.
Aug 29, 2011 | Televison & Video
I was getting nine flashes and know the green crt
Sounds like a bad green crt. These Sonys are bad about that.
Jul 06, 2009 | Sony KP-65WS500 65" Rear Projection...
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Apr 22, 2009 | Televison & Video
Kyocera Ecosys FS 920
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Sony 61" Projection (KP-61HS10)
Your TV requires Geomatirc Adjustments in proper manner by qualified servcie person.
Jul 19, 2008 | Sony KP-57WV600 57" Rear Projection...
Hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Jul 16, 2008 | HP Pavilion a1250n (EG194AA) PC Desktop
Sony kp41s3u - blue screen
Convergence amp ic bad or loose connection on ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Feb 26, 2008 | Televison & Video
Flashing
well you can tap the convergence board and the crt boards see if you can find a loose connection, however be careful there is high voltage
Feb 01, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
