Question about Nokia N70 Cellular Phone
On my hand set I am not able to listen redio after connecting headset cable. Please sujest solution. Further I can not eccess gmail through gmail 1.5 version software.
6070 radio not connected
Posted on Feb 09, 2008
    President:
  • 1,017 Answers
The headset is used as an aerial for the radio, so if you hide it under clothing the signal might be bad. It's never very good anyway. You have to be 'online' for the radio to work.
To access Gmail you need the Internet settings on your phone. You get them sent to you via your service provider, in the form of a txt msg.
I'm not patronizing you. I don't know if you can surf the net on your N70 or not! I'm just trying to find a solution to your problem.
If you have already been on the net with your phone, then I can only suggest two things.
  1. Delete Gmail from your N70. Then reload it from Google after you've done that>>
  2. Do an update of your phone software.
Before updating software you should check that there's a newer version of software.
Go to: http://www.nokia.co.uk/A4777089 to check your present software. (UK)
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don't unplug the phone from the PC.
Press: Menu button for 3 seconds, close all applications that are open (press c for each one)
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again. But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you're up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
Posted on Feb 01, 2008
Just brought a HTC wildfire and I cant find bluetooth to turn it on .
Bell;
Important:
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so HTC Wildfire S can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press howtoimage.aspx?id=106492, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. HTC Wildfire S will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. HTC Wildfire S then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to HTC Wildfire S, the Bluetooth connected icon howtoimage.aspx?id=106796 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Mar 28, 2012 | HTC Wildfire Cell Phone
Tip
Jabra Bluetooth Headset Pairing Instructions
<span><span>Connecting a Bluetooth headset or car kit</span> <span> You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free. <ul> <li>For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile. </li> <li>Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual. </li></ul> <ol> <li> <span>From the Home screen, press <span>MENU</span>, and then tap <span><span>Settings</span> &gt; <span>Wireless & networks</span></span>. </span> </li> <li> <span>Tap <span>Bluetooth settings</span>. </span> </li> <li> <span>If the <span>Bluetooth</span> check box is not selected, select it to turn Bluetooth on. </span> </li> <li> <span>Make sure that the headset is discoverable. </span> </li> <li> <span>Tap <span>Scan for devices</span>. </span> Your phone will start to scan for Bluetooth devices within range. </li> <li> <span>When you see the name of your headset displayed in the <span>Bluetooth devices </span>section, tap the name. </span> Your phone then automatically tries to pair with the headset. </li> <li> <span>If automatic pairing fails, enter the passcode supplied with your headset. </span> </li></ol> The pairing and connection status is displayed below the hands-free headset or car kit name in the <span>Bluetooth devices</span> section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls. </span></span>
on May 23, 2011 | Cell Phones
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
How do i pair my jabra bt250 to my htc desire hd
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon howtoimage.aspx?id=12046 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
May 23, 2011 | Jabra BT250 Consumer Headset
I want to connect my nokia BH-104 headset tp my blackberry bold 9700 phone. Please guide
  • 1
    Turn on Bluetooth headset and Blackberry hand-held.2
  • Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.3)Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.4)Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.5)Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
  • Mar 20, 2011 | Nokia BH-104 Bluetooth Headset
    Eiroga E71 Aircel GPRS Setting?
    sir please call to the aircel simcard customer care and say the cellphone model number.and the phonenumber then they will send the gprs settings to your cellphone save the settings and switch off your cellphone and again switch on.then connect the data cable from phone to the computer for connecting the internet...........
    Dec 30, 2010 | Siemens M56 Earbud Hands Free Headset
    Jabra 2080 won't connect. Blue light flashes constantly.
    I apologize you having trouble with your Jabra Blue tooth Headset.
    The reason why its flashing is because it has not paired with a device or the battery may be low.
    1. Take the battery out of the unit to fully reset the unit.
    2. Put the battery back in the unit "turn the unit on"
    3. Try using the code 0000 this is the default code to pair the headset with your hand set.
    If the above steps does not work it might be because of a low battery, Thus I would recommend purchasing a new battery for it then try the steps above again.
    Again we apologize your having issues with your headset, if you have any further questions please get back with me.
    Thanks for using Fixya.com
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
    Oct 28, 2010 | Jabra Bluetooth Headset with Adjustable...
    I have a Bluetooth headset VMX 100. I paired it with my iPhone, I can make phones, but I cannot listen to the music from my iPhone, or the VMX100 designed to not to listen any music. Thanks
    In order to have music streamed to a bluetooth headset, it must bear A2DP (Avanced Audio Distribution Profile). You see, all stereo bluetooth headsets available on the market do support that profile. Nevertheless, the VMX100 is a monaural headset, thus bearing both HFP (Hands Free Profile) and HSP (HeadSet Profile) only, which are suitable for phone calls only.
    Well, depeniding on your phone platform, you might find applications around which route all audio to a monaural bluetooth headset. However, you would, most probably, find the sound quality to be pretty poor.
    Please, let me know if I can help you any further.
    Regards, Carlos
    Aug 31, 2010 | Sennheiser VMX100 Bluetooth Headset...
    How do i connect my HBH-600 bluetooth headset to my phone?
    hi thanks for using fixya!
    Connecting a Bluetooth headset or hands-free speaker unit to your phone involves setting the headset to “discoverable” mode; check the headset manual for how this is done, as it varies by type and model. You’ll also need to find the headset PIN code in its manual – this is usually 0000 or 1234, but again it varies.
    Go to Bluetooth menu – from the main menu highlight Settings (Figure 1), click Select, and scroll right to highlight the Connectivity tab. Highlight Bluetooth (Figure 2), click Select and then highlight Handsfree (Figure 3) and click Select.
    When prompted to ‘Add a handsfree device’, choose Yes (Figure 4), and your phone will look for all discoverable hands-free units (Figire 5). Select the one that you want from the list that appears and enter the hands-free unit’s PIN code when prompted. The pairing will now be complete.
    Once paired, you’ll find the headset listed under the My devices menu in the Bluetooth settings area, from where you can connect and disconnect it.
    Hope it will help you. If you need further assistance, let me know!
    Regards!
    Apr 30, 2009 | Sony Ericsson Akono HBH-600 Consumer...
    Getting my head set to pair
    1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
    3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
    4.Select your bluetooth (i dont know your bluetooth model no.) once a connection is detected.
    5.The passkey "0000" is now entered to confirm the connection has been made.
    6.The cell phone screen will now read "Bluetooth Connection".
    Tips:
    1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
    2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
    3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
    please give good rating if the solution works.
    Thanks for using FixYa.
    Nov 09, 2008 | Motorola Mobility Bluetooth Hands Free...
    Nokia N70 Cellular Phone Logo
    Top Nokia Cell Phones Experts
    270rexton
    270rexton
