My problem is a simple cosmetic issue. The outer "plastic" protective coating on my JBL speakers has been chipped off and worn down. Is there a way to fix the spots that are now unprotected? Is there some sort of appoxy or other material that would work best???
    Problem Solver:
  • 8 Answers
If the finish is wood veneer, there are patches you can buy from a hardware store. Experienced woodworkers offer service for refinishing jobs like this.
Posted on Feb 02, 2008
I need a operating manual for jbl flip 2 stereo speaker
JBL has the Quick Start Manual for the Flip 2 on the product site: http://www.jbl.com/bluetooth-speakers/JBL+FLIP+II.html . Scroll down and expand the Manuals & Downloads section. The link to the manual is the one on the right. The direct link is http://demandware.edgesuite.net/aauj_prd/on/demandware.static/-/Sites-masterCatalog_Harman/default/dw3064f0fb/pdfs/Flip2_QSG_EN.pdf . The pairing feature should be as simple as tapping the Bluetooth icon on the speaker. Then set your laptop to search for a new Bluetooth signal.
I hope this helps.
Sep 04, 2016 | JBL Audio Players & Recorders
Harmon Kardon Receiver "Protect" Mode issue
If your receiver enters protect mode with no speakers connected, it is an indication that you will have to start troubleshooting inside.This will involve visual checking and checking with a multimeter to isolate the problem. A further issue is finding out why your JBL woofer keeps blowing fuses. It could be shorted.
Dec 12, 2013 | Audio Players & Recorders
How to remove screen protector from a hitachi 50ux52b
The entire screen comes off from the front.
Remove front speaker grill (should pull off)
Behind it at the bottom of the screen are a row of screws that secure the screen with frame to the cabinet.
the entire unit pulls out (bottom right and left first) and when free lifts up to pull off.
With the entire frame and screens off--you have to take the inner screens out first---careful to note which is facing forward and upwards---you can put them in backwards or upside down--will not work right.
Most of the Hitachi's the two inner screens are taped together along the edges but if not you have to be real CAREFUL- THE thin outer one is easily shattered or damaged.
You may have to take the frame apart to get the other (outer one) out as it is usually in a slot or track.
Screens have to go back in at exactly same direction and position as when you started.
The inner ones usually are held in place with strips of plastic or metal secured with screws--careful not to strip the holes out with a screw gun.
Clear one is (outer) only protective but does have an anti-glare coating so that can be an issue--picture will be brighter.
for questions or information press the "make a comment button" on this page.
Mar 25, 2012 | Hitachi Televison & Video
Loud buzz/hum started on jbl eon 1500 powered speaker one side only after power cut off and sudden power back on makes same noise on it`s own as well as with mixer etc could this be a transformer...
For some reason the soft on protection circuit has failed. it is not a simple fix and would require the amplifier module to be removed from the speaker to assess the damage.
Mar 10, 2012 | Jbl Eon 515 Eon515 15 Powered Portable...
Hi, I recently bought a bottle of Salley Hansen "No More Breaks". Found that the polish chipped off as soon as my hands came into contact with any form of soap. Be it shampoo or dishwashing...
Well, if you have this problem with all nail polish, then you can safely assume that the problem may be that you have oily nails - in which case your nails will secrete oils that lift the nail polish off your nail, causing it to chip.
BUT
If you are only experiencing this problem with this particular bottle of Salley Hansen, then it is likely that it may be a formula problem.
For both instances, try using a primer and a base coat polish BEFORE applying the Sally Hansen. This will improve the adhering of the polish to your nail no matter what the problem is.
Sep 19, 2011 | Health & Beauty
What are the differences between lenses? I know some are made of plastic and some from glass..Thanks!
There are couple of materials in which sunglassess are made of. 1. Glass Lenses
- it's has number of advantages: -Exceptional scratch resistance (don't need scratch resistant coating).
-Excellent optical clarity.
-Anti-reflective (AR) coating adheres to glass very well.Disadvantages are:-At least twice the weight of plastic or polycarbonate lenses.
-About 25 to 40 percent thicker than polycarbonate and high index plastic lenses.
-Can shatter or chip easier than lenses made of other materials.
-Require a special coating to provide 100% UV protection Second type is Plastic Lenses:Advantages:
Lightweight - About half the weight of glass lenses.
Plastic lenses accept tints easily.
More shatter - resistant than glass lenses.
Disadvantages:
About 20 to 35 percent thicker than polycarbonate or high index plastic lenses.
Require scratch-resistant coating for added durability.
Require a special coating to provide 100% UV protection.
Another type is Polycarbonate Lenses:Advantages:
Safest lens material - 10 times more impact resistant than other lenses.
Thin - About 20 to 25 percent thinner than plastic or glass lenses.
Lightweight - About 20 percent lighter than plastic lenses.
Blocks 100 percent UV rays without needing a special coating.
Disadvantages:
Requires scratch-resistant coating for durability.
Peripheral vision may be slightly less clear in strong prescription powers.
More lens reflections than glass or plastic lenses (AR coating recommended). High Index Plastic Lenses-Advantages:
Lightweight - Between plastic and polycarbonate lenses in weight.
Thin - About 15 to 30 percent thinner than plastic lenses.
Better peripheral optics than polycarbonate lenses (for prescription sunglasses).
Disadvantages:
Nov 07, 2010 | Clothing Accessories
Does onkyo HT-s3100 supports 4 Ohms speakers from JBL(control 1)
Palaboy is incorrect. JBL Control 1 speakers are 4 Ohm 150 watt speakers. He's probably thinking of the Control 1x speakers which are 8 ohm 80 watt speakers.
If you hook your Control 1s to that Onkyo, it won't sound great and could cause the receiver to overheat and trip the protection circuit if played at high volume.
Aug 11, 2009 | Onkyo HT-S3100 Receiver
When i connect both subs(jbl gt 1041d) my amp goes to protection and when i ony hook one up it doesnt go to protection
Hello lilcylentsur,
It sounds like when you connect both subs, the impedance match is too low for the amp to handle. 2 4-ohm DVC subs with both the coils and subs wired in parallel will present a 1-ohm load which is too low for most amps.
The solution is to wire the voice coils in series, (connect a short jumper from one positive to the other negative on each sub). and then wire the remaining terminals to your amp. This will result in a 4-ohm load which most amps can handle.
Here's a "wiring wizard" which allows you to see the ohm loads of different wiring configurations.
Hope this helps.
May 07, 2009 | JBL GT1041D Car Speaker
JBL Prius Radio Tuning Knob Broke
Search for your model number on eBay. You should be able to find used radios taken from a totaled Prius much cheaper than buying a replacement from Toyota.
Apr 17, 2009 | Car Audio & Video
37 people viewed this question
 Grubhead
Grubhead
