Double picture the picture on my tv is double..i have tried to fix with the control on the menu but have not been able to change the picture...what should i be looking at to change this
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Is the doubled picture side by side or top & bottom. What control were you trying to adjust in the menu? It sounds like something has gone out of tolerance. There may be an internal adjustment to compensate.
    - Jim
    Problem Solver:
  • 6 Answers
I would look for a lttle hrizontal potentiameter in the horizontal osc circuit.
or your getting hdtv signal now and it cant proscess it .
Posted on Feb 25, 2008
RCA 42 in Replaced the 42RE010C878LNA0-A1 Board now a good picture but upside down how do I fix it
from remote press menu and highlight contrast enter code 1950 and see the service menu comes up. if not try 9735 same way.and change product id in service menu. try different .ids. each time you change id unplug tv and plug in .see if picture change.or do same process each time until show good.
Jan 19, 2015 | RCA 42la45rq 42-inch 720p lcd tv
Screen looks like it was magnetized
From what you are describing it sounds like either the convergance board is trying to go out. you may be able to fix this by going into your menu and into your t.v. settings. and look usually under the picture settings. you should be able to set the t.v. to defaults and or if your t.v. has it you may be able to do a perfect picture reset. whitch if you have will also be under the same option.
Aug 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do I fix NO signal message and double picture?
Try changing the source with the remote..
Sep 13, 2014 | Televison & Video
How to change the channel my Sony Trinitron TV turns on to?
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Nov 10, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
My tv is almost 6yrs old and all of a sudden the picture is blury almost showing double images. The color is also of at the top and bottom of the screen.
this is typic old projection tv, some tecnical ajust parameters have reset, so if you can adjust,this settings on service menu on tv, or ask for help on local repair store, to calibrate scren.
Nov 29, 2009 | Televison & Video
Double Vision
Your convergence ic’s have failed, this is a common problem with most all projection tv’s, the repair is involved and requires electronic knowledge. If you want more info on how to fix this yourself let me know.
Sep 01, 2009 | Zenith D56W25 56" Rear Projection...
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
How to reset defaults Panasonic HD PT-47WX53G TV/picture
First of all are you sure you were in the factory menu this step requires alot of known how!!!!!! By using your hand unit only customer controls can be reached unless you know factory menu setup. Which starts like this ,make sure antenna to cable then go to menu set sleep timer to 30 mins exit out now enter ch 124 then press v- down on tv you should now see on top CHK ,also these sets have double convergence patterens.if you were in factory set up for more information look in www.freelists.org techassist/09-2005 .let me know if you still need help.
Nov 14, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Sony KP-61XBR48 Service Menu Item Keeps Changing
the only thing to do is pick which video mode you want (tv, vid1,2,3,etc) and then turn off and then immediately on for an hour or two and then the picture will come on. I,ve heard it's an internal transformer problem.
Sep 26, 2007 | Sony KP-61XBR48 61" Rear Projection...
Double Picture
Goto menu and look for convergence control and realign colors.
Sep 22, 2007 | Hitachi 57G500 57" TV
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
