GE washing machine WWA8829
Machine looks like new!! Even Clean inside bottom, belt is like new. The back Ply board cover looks brand new!!!
Started with a small LEAK!! I pulled inter drum to look at the Trans to outer tub and boot is in great shape. AS Iam looking inside tub I see a white spot and put my finger to it and found it is light shinning throw a rusted "HOLE"!!! there is more rust so I taped the rust and got a total OF
" ( 9 ) RUST HOLE!!!!!!! But now i can not find a new or used TUB. GE. Engineners Need to see how BAD the tub is. tub=ps1088347
Can Any One Help??? To find replacement TUB ?? Have a GREAT DAY!!! Mike 586-489-4548
  • Trishee Jul 09, 2008
    Hello, My washing won't spin, but the motor is still running. If I leave it on, it created this burning rubber smell. Do I need to buy a new washer?
Wire brush the rust away as much as possible, then vacuum out the crud. Go to an auto parts store and get a quart of Bondo auto body filler. (paintable silicon-latex caulk will work for awhile if you are lazy). Read the directions and use it, make sure a little squeezes through the holes. Leave as smooth a surface as possible, make sure to slope putty towards drain. Don't bother sanding after it hardens, no one will see it. Don't get any in the holes that are supposed to be there, as it could kill the water pump. Paint the Bondo and entire inside of tub with oil based paint like Rustoleum. You may also want to wire brush and paint the transmission shaft, as it is probably pretty rusty too. Let it dry until it doesn't smell anymore, then wash a load of your own clothes before you let your wife wash anything she cares about, just in case, cya, etc.
Now, start saving for that new washer you're going to need in about a year.
Posted on Feb 10, 2008
  • 240 Answers
Hate to say it, but even if you can find a new tub, it would cost you more than the machine is worth. The plywood backing gave away the year of this model from the start, so it is an oldie. Even in the repair business, we rarely ever replaced a tub because GE only used a repair stick called "Slap Stick". This was like an epoxy type repair that you molded around the holes. Problem is this stuff will only fill a small type hole. If you are dead set in wanting to keep this washer going, you can run to Home Depot or Lowes and pick up a roll of what I call tar tape. It is a roll of flexable window flashing that is cutable. You cut a peice about three times the size of the hole, pell off the covering, then use force to stick it like tape. This doesnt always work, but worth a try. You can also stick the tape to the bottom around the same area, and have both peices of tape touch where the hole is. Give it a try,
Posted on Feb 02, 2008
Hello, my washing machine won't, but the motor is still running and its creating this burning rubber smell.
Posted on Jul 09, 2008
Tub will not engage during wash cycle
The drive belt must be loose or broken...if it's an older machine.
Some have a shifter mechanizm ( a solenoid)...may have to be adjusted or replaced.
Lots of other mechanical things could be the problem. It could even be the timer.
Remove the back cover and have a look inside. You can easily see if the belt is ok.
BE SURE TO UNPLUG THE MACHINE FIRST!
Jun 26, 2011 | Whirlpool Washing Machines
Washing machine will not spin or agitate
It sounds like it might be the belt. You should unplug the machine, take the bolts and screws off of the back and lift the cover off. Look for the belt and see if you notice any damage or anything wrong with the belt.
Hope this helps! Please rate my answer :) Thanks!
Jun 12, 2011 | GE WWSE5240G
How do I remove the agitator for my machine ? It is loose and spins fine, but makes a clanging noise when agitating counterclockwise during the wash cycle. It seems like I just need to tighten it down...
Anyone with loud scraping/clanging- we had that problem and saw that the large wheel the belt goes around is only an inch above the metal bottom.When we moved the washer with a 2wheeler it pushed the bottom up into the metal wheel. The racket it made was horrible. It left metal shavings ,too. You'll need to pull the bottom of the washer back out.Pull fromt panal off with putty knife.You'll need to lean or lay washer to one side.Put a pillow or cushion inside between the tub and housing side you'll be leaning towards. What I did was drill two little holes-one near the back center and one near the front center. I took a long piece of heavy string,put one end in one hole and the other end in the other hole-outside to inside.Tie the ends around each end of a 1x2,18inch board .Get the board to the back without damaging stuff inbetween-pulling on your back string for help. Make sure the board is against the bottom, get to where you can now pull your string 'handle' w/both hands,yanking and popping the bottom back out.Our washer now works beautifully and quietly.
Feb 12, 2011 | GE 3.2 cu. ft. Washer
Dishes not coming clean
Five common causes:-
1. The dishwasher hasn't got any salt in, or the salt dispenser control is set too low. Even if your tablets/powder have a salt function, it's often not enough in hard water areas and supplementary salt must be added to the salt dispenser.
2. There is no rinse aid in the machine or the dispenser control is set too low. Supplementary rinse aid may be needed even with tablets/powder which claim to include it.
3. The dishwasher is not reaching the correct operating temperature. This can be due to a faulty machine, or by using low temperature washes inappropriately. Low temperature washes are only suited to very lightly soiled loads which have not baked/dried on. There ARE special low temperature tablets/powders, but they're designed only for specialised domestic machines with low temperature overnight wash cycles or for commercial dishwashers.
4. The filters/debris traps at the bottom of the machine are not clean.
5. You're using the "wrong" brand tablets/powder. In this instance "wrong" simply means that your machine just doesn't get on with the brand you're currently using. price has little to do with it; I find with my current machine that the market leading expensive brand works poorly but the ultra-cheap supermarket basic value brand works perfectly. Also it can be down to using a genuinely wrong tablet/powder choice as per suggestion #3.
May 15, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
5 yr old GE Adora -- have it repaired or replace?
look in the back and make sure the drain hose is about 18 ins high if the hose falls it will not hold the water in the machine
Feb 10, 2010 | GE Adora GHDA656LSS Stainless Steel...
Washer will not pump amd spin
Check the belt. The belt connects the motor to the pump and transmission. Depending on the brand it's usually open on the bottom. Just tip the machine back and take a look on the underside. If you can't see it take the bottom cover off.
Sep 05, 2009 | Frigidaire ATF6000ES Front Load Washer
GE Spacemaker stackable washer/dryer
The front cover come off by removing two philips screws on the bottom of the panel. That will expose all the operating parts of the washer.
Sep 17, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Aug 06, 2008 | Washing Machines
Belt of pulley part of pulley in pan of machine
it sounds like a belt and or clutch problem. there is a retaining clip that holds the clutch onto the motor, this may have come off releasing the clutch bell and belt. if you only see a half of a pulley in the bottom then you need a whole new clutch assembly with a new belt.
Jun 29, 2008 | GE Washing Machines
Whirlpool washer won't spin even though motor is running
Sounds like the the motor belt is worn or off. Try a new belt, or check the drain pump filter for clogs.
If you've got a handy friend, it's easy to check these... remove the back of the washer (about 12 srews) and check for black dust inside, or a belt hanging or lying on the bottom.
To check the drain pump filer screen, look for the drain hose, follow it into the back of your washer and down to a plastic bow looking unit. There should be a round cover with a kind of handle on it. remove the cover, (water may run out... have a few towels handy) clean off lint etc. and put back together. Try again...
Feb 06, 2008 | Washing Machines
Washing Machines Logo
468 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
