Question about Sony KP-53XBR200 53" Rear Projection Television
Sony KP-53XBR200 My big picture is Black & White, if I press Freeze frame it is color, and then reverts back to B&W. I have tried my DVD to check the picture and its still B&W, freeze frame is color ???????
  • Reno1 Feb 01, 2008
    When I use the P&P at one time. One picture will be B&W and the other one Color? I don't know about he whacking method, will I knock out the alignment?
    President:
  • 4,402 Answers
Bad cable ground have cable company check
Posted on Feb 01, 2008
    Genius:
  • 3,422 Answers
First thing to do is the reset and the whacking test. I give this a 50/50 chance of clearing it up.
ONE: Disconnect the power cord for 4 hours. Then when you power it back up the internal soft codes will automatically reset to factory defaults.
TWO: The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
If these two procedures do nothing, then you will need servicing to solve the problem and expect t to pay over $100 for the repairs.
Goodluck,
Please don't forget to rate me as fixya..
    Genius:
  • 1,067 Answers
Cheak colers on cables make sure in all way try differt cable try resetting the tv and adjusting coler in
How do I stop from getting double pictures on my KP-53XBR200 53 in? And Stop the color green from going of center with the rest of the other colors?
Could be a convergence adjustment from your remote under MENU. (This can be done by you)
Could be a problem in the convergence circuitry. (This can be done a TV tech only)
N Sabre
Nov 07, 2009 | Sony KP-53XBR200 53" Rear Projection...
SONY rear projection TV - Whites have started looking "snowy"
This is your Picture tubes getting very weak.( low in emission ) You have three in there and I guarantee they are no longer available so I would start thinking about investing in a new set, but use that one until you can't stand it anymore.
May 28, 2009 | Sony KP-53XBR200 53" Rear Projection...
52 inch projection sony
Check settings on main screen go into menu to change settings///also you can try resetting it by unpluging for five min....replace plug ...now PUSH AND HOLD thepower button for 10 seconds
Dec 13, 2008 | Sony KP-53XBR200 53" Rear Projection...
The color on my sony model #KP-51WS510 stopped working
I would go to the setup and check the setting for returning to factory defaults
Let me know if this helps
Dec 13, 2008 | Sony SCREW +PS 2X5 (BLK) (762825310)
I have a sony 61HS10 rear projection tv. The small displays work, showing two or more pictures at the same time but when you want to display just one large full screen picture there is sound but no pi
As you told big picture freeze is working ,then there could the problem in the main processors which not to able pick video input signal ...If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:http://servicemanuals.vstore.ca/ which also contains the part number incase you need a new part...
Good luck.....
Dec 06, 2008 | Sony KP-53HS30 53" Rear Projection...
The picture is in black and white but menu is color
you might have the colorwheel checked to see if its bad
Nov 03, 2008 | Sony KP-51WS500 51" Rear Projection...
SONY REAR PROJECTOR TV
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
May 27, 2008 | Sony KP-53XBR200 53" Rear Projection...
Sony KP-53XBR200
check cable grounding, does it do it with a dvd?
Feb 01, 2008 | Televison & Video
Picture Problems
check for poor grounding of the input signal cable wire.
easy way to check this is put in a dvd and is that in color?
Feb 01, 2008 | Sony KP-53XBR200 53" Rear Projection...
Long time to power up video
My Sony KP-53XBR200 will not display any video (even from the tuner) except the internal display until it sees a video input on one of the video jacks on the back after a power hit.
I solved this by putting a video cable from Monitor out to Video 4 in (unused for other video). Voilla! Instant video on. This may not be your issue, but it fixed my set!
Oct 20, 2007 | Sony KP-53XBR200 53" Rear Projection...
Sony KP-53XBR200 53" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
