Question about Sony KP-53XBR200 53" Rear Projection Television
Picture Problems My sony 53XBR200 shows a black and white picture, I can't get it to be color. If I hit Freeze Frame on the remote, the freeze frame is color. My multi screen will reduce the size of the picture and its color, but the perimeter picture channels are black and white. I have tried to play a DVD to check connections, but the screen picture is B&W? Any solutions that you know about? I have Auto Focused and read the manual 20 times and tried every function? thanks, RB
  • 48 Answers
How old is the tv . as it could well be the bulb on the way out as they only last 2-3 years or 4000 hours . when they are on the way out the light isnt so bright . take the bulb out and check the bar on the inside of the bulb if it is black in colour it is a good sign it is on it's way out. bearing in mind these bulbs do cost a small fortune (from £160 - £220 )depends on where you buy from.
Hope this is some help to you
Cheers
Adrian
Posted on Feb 01, 2008
    President:
  • 4,402 Answers
Check for poor grounding of the input signal cable wire.
easy way to check this is put in a dvd and is that in color?
Pictures not showing.
make sure the cards' slide button is in the unlock position..then check to see which size cards the frame can work with..mb sizes like 2/4/6/8/12 etc..
Jan 11, 2014 | Audiovox DPF700 Digital Picture Frame
Sony KP-53XBR200
cheak colers on cables make sure in all way try differt cable try resetting the tv and adjusting coler in
Feb 01, 2008 | Sony KP-53XBR200 53" Rear Projection...
Remote control for Smart Parts 11" digital frame (SKU SP11008) doesn't work. Have changed battery, but cannot get any type of connection between remote and frame. Received as gift over a year ago, but did...
We have to check the remote control first. After that check the digital picture frame.
Follow the instructions below please;
We must be sure the remote control is working;For this control:
1. Take a digital photo of this remote control while pressing the remote control button.
2. If it is working then the picture must shows the led lamp of remote control as firing.
3. If the picture does not show that it is firing, then, you should control batteries of the remote control.
4.Check the battery and the battery polarity of the remote control.
5.If it is firing. You should control Digital Picture Frame.
6. If the battery of the digital picture frame does have enough energy or not. If battery is low then you shoud use it from the closer distance.
7. I do not think that the Digital Picture Frame is out of order.
Regards.
Apr 21, 2010 | Smart Parts Digital Picture Frame
Picture frame freezes when playing from sd card or flash drive
I've never used a card in mine, but I've seen others mention that if they go beyond about 50 % of capacity on the card, the frame will freeze up.
so.... try reducing the size / number of pictures ?
Also, did you run them through the OptixPix optimizer ? It reduces size by over 90 %, probably makes it easier for the tiny processor in the frame to handle it.
Aug 14, 2009 | SmartParts (1DPFSP01) Digital Picture...
Black frame around picture
Toggle through the "Picture Format" settings from your tv remote.
Flip through cinema mode, too standard....etc
Jun 12, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
SONY rear projection TV - Whites have started looking "snowy"
This is your Picture tubes getting very weak.( low in emission ) You have three in there and I guarantee they are no longer available so I would start thinking about investing in a new set, but use that one until you can't stand it anymore.
May 28, 2009 | Sony KP-53XBR200 53" Rear Projection...
I have a sony 61HS10 rear projection tv. The small displays work, showing two or more pictures at the same time but when you want to display just one large full screen picture there is sound but no pi
As you told big picture freeze is working ,then there could the problem in the main processors which not to able pick video input signal ...If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:http://servicemanuals.vstore.ca/ which also contains the part number incase you need a new part...
Good luck.....
Dec 06, 2008 | Sony KP-53HS30 53" Rear Projection...
Picture Problems: Snow, color, lines
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 23, 2008 | Sony KP-53XBR200 53" Rear Projection...
Sony KP-53XBR200
check cable grounding, does it do it with a dvd?
Feb 01, 2008 | Televison & Video
Sony KP-53XBR200 53" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
