Question about Whirlpool AWM5125/1 Front Load Washer
Washing machine leak
My washing machine has started to leak from underneath whenever I use it. It is not a lor of water but enough to cause a puddle so I need to sort it. Any ideas what is causing it? and is it worth repairing as it must be getting on for 7 years old now??
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Quite possible the leak is from the point where your exit hose is inserted into the stand-pipe.
Rate me pl.....if helped.
Posted on Feb 02, 2008
6ya staff
SOURCE:
Water leaking on fast spin
hi Eamon.
this is what i found from the internet.
Washing machine leaks on spin Last updated on February 6th, 2017
Sometimes a washing machine leaks on spin, but not before. If this is the case, either it's going into spin with too much water inside, or something may only be leaking under the pressure and tub movement caused by spinning.
If you can see water running out of the soap drawer during spin it's probably gone into spin without pumping the water away properly. If it wasn't pumping water out at all it would not go into spin, but a partial obstruction can reduce the flow enough to allow a spin with the water unable to escape fast enough. This causes water to be forced up into the drawer or out of the steam vent at the back. If you suspect this check the last section of this article - Washer leaks from drawer
If water is coming from underneath when it spins then it's more likely to be caused by something leaking only under pressure. Check the door seal all around inside for slits and small holes, especially higher up, which may only open up and let water out when the washer is bouncing around on spin.
Other possible causes are hoses inside the machine which have small holes which open up during spin or which leak where they connect to the tub under spin conditions. These type of leaks often leave tell-tale rust or dry detergent marks. After that there could be a crack or small hole high up in the plastic outer tub which only gets exposed to water when it's forced around the tub during spin.
You are looking for something that is moving and allowing water out when the tub bounces around under load, or something high letting water out when it gets thrashed around the top half of the machine on spin. If you can't see anything obvious get a washing machine engineer
More articles about leaking washing machines Why does my washing machine leak only during the spin cycle
and if you want to read up on some more then try this link.
washing machine water leaking on fast spin cycle Google Search
Nov 23, 2017 | Washing Machines
My kenmore elite topload washer is leaking underneath washing machine leaving a puddle whats causing this?
depends. first and foremost, I would fill the unit up about halfway with water, with tub being empty of any clothing. Tilt the machine back where you can look underneath it real good. see if you see any leaks with it half full of water. If you don't see any leaks, put the unit back on all fours, and put it into drain/spin. After tub empties of water, tilt unit back again and check for leaks near the drain pump and hose. If you need any further assistance, look for me on 6ya
Nov 27, 2015 | Kenmore Washing Machines
Leaking hotpoint ultima washing machine
Hotpoint ultima wt965 washing machine This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 16, 2012 | Hotpoint Washing Machines
Waste water leaking from underneath my zanussi jetsystem ZWF16381
Could be slight hole in door boot seal / or circon pump suspect door boot seal
Jul 01, 2012 | Washing Machines
Washing machine leaking water from underneath
It is possible it is just a loose hose or it could mean your trmp or the tub itself is leaking. I would try going to the back of the machine and take off the bottom panel.and take off the back panel. After removal start it and observe where the leak is happening.
Jun 14, 2017 | Estate ETW4100SQ Top Load Washer
Small puddle of water underneath washer when wash cycle was completed.
That could be 1 of a couple things.
1) During the agitate cycle... some water could've made it out of tub.
2) Possible Tub Crack (or overflow line)
3) Check your inlet lines
I would run it again watching it very carefully to determine if any of these are the problem.
Dec 02, 2009 | Whirlpool LTE5243D Top Load Stacked...
Puddle under 1 yr old washing machine hours after it is finished
Sounds like either the gasket on the inlet is leaking or not tight or the solenoid housing is cracked causing the leak. When its in use the pressure from the line is realased when the solenoid is opened letting water in. When not in use the solenoid stays closed allowing pressure from the line to build causing the gasket to leak. Check your gaskets, and solenoid housing for leaks and then check to make sure your water pressure is not set too high.
Joe
May 19, 2009 | Kenmore 22422 Top Load Washer
Leakage of water from underneath when filling machine up
it's prabably your pump it has two metal strips that snap on from the motor to the pump un-snap them and undo your hoses and get yourself a new pump
Apr 03, 2009 | Washing Machines
My washing machine keeps leaking from the bottom
For me there is not enough information. What hose did you replace and when does the machine start to leak ?
Dec 26, 2007 | Kenmore 24032\24036 Top Load Washer
Aeg washing machine
you may have blockage in pipe from drawer to tub but more likely the soap drawer is clogged. take it right out and clean thoroughly
Mar 21, 2007 | AEG Lavamat W1050 Front Load Washer
Whirlpool AWM5125/1 Front Load Washer Logo
88 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
