Epson error messages
HOW CAN I GET RID OF THE MESSAGE ON MY EPSON PRINTER THAT TELLS ME IT NEEDS SERVICING ?
Stylus Photo R200 on XP/Vista os
    Brigadier General:
  • 6,966 Answers
If I may offer an alternative to map9966's post (with his indulgence)....
Download, install and run SSC Service Utility. It's a 3rd party software allowing the user access to more features/functions of most (but not all) Epson printers including reset to end of life or service request.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 01, 2008
    President:
  • 2,351 Answers
Go to the link provided below. When you get there look to the right side of the page & click Troubleshooting Guide. Another window will open. Answer the questions.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&foid=102450&oid=29081&infoType=FAQs&helpful=No
Without knowing what you were doing before you got the message & knowing what lights are flashing ect. Guessing would be a wast of your time & mine.
This should help.
please vote...
I have an epson stylus photo R200. It has stopped working and has alternate red flashing lights. Error message says serviceable parts are nearing end of life. How do I get it to carry on working?
I'm not sure about the servicable parts. You might want to contact Epson.
I have seen "parts are nearing the end of life" which applies to the ink pads that absorb excess ink. In that case, the printer needs to be replaced or serviced by Epson or an independent service provider. If you just get the ink pads serviced, it may still fail soon. Then you can run the resrt utility. For more information and the reset utility: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp?cookies=no&com.broadvision.session.new=Yes
I hope this helps.
Dec 15, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson r265 needs service
If the error says, parts inside your printer are at the end of their service life, the ink pad on your printer needs to be replaced. Then log on to epson.com/ipr to get the ink pad reset utility software. The software runs on win xp and win vista.
May 01, 2009 | Epson Stylus R265 InkJet Photo Printer
Can't download printer software
The Vista 64bit driver can be found here There's also specific installation notes - one states not to use the CD provided if it does not say Vista on it!
Apr 01, 2009 | Epson Stylus® R200 InkJet Photo Printer
Epson Photo R200 unrecognised cartridge message
Problem solved! I moved each cartridge up slightly to break contact and then snapped them back into place. Loaded a job up, pressed print and it started with no problem.
Jan 14, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 and R320 Status monitor in Vista
I was able to install the original XP status monitor from the CD, onto Windows Vista Home Premium.
On the install cd, you need to open the 'STM3' folder under whatever language you are installing, 'English' in my case. There are several .exe files in that folder:
E_S1LAC2.EXE
E_SCHK02.EXE
E_SIINS2.EXE
E_SPSU02.EXE
STMSETUP.EXE
For each of these, right click on the file, and choose 'Properties'. Under the 'Compaitbility' tab, choose 'Run this program in compatibility mode for:' - Windows XP (Service Pack 2).
Then run the 'STMSETUP.EXE' file, and it should install properly, and work. Although I cannot guarantee that it will work on your system, or that it will not have any negative effects on your computer.
So far, I have not had any trouble with it.
Aug 03, 2008 | Epson Stylus Photo R200 InkJet Printer
For the Epson R200 here's how I got it to work with Vista Business 32bit ...
#1 Disable AV software
#2 Open the CD for the printer software
#3 Find the launcher, right-click it and select Properties, then select the Compatibility tab
#4 Choose XP SP2 compatibility mode and Run As Administrator, then click OK.
#5 Double-click the launcher to start the program, select Custom then then choose only the Driver and Status Monitor applications.
Worked for me, hopefully will do too for you. :o)
Jul 05, 2008 | Epson Stylus Photo R220 InkJet Printer
HOW TO INSTALL MY EPSON STYLUS PHOTO R200 I DONT HAVE THE DISK OR CD AND I HAVE WINDOWS VISTA
Try visiting Epson website...look for support link for drivers...then find your printer and operating system...download drivers and install....install program should provide directions..generally it will direct you to make sure printer cable is not connected to pc until install program tells you to do so. You can also do a google search for "epson stylus photo r200 drivers for vista", chances are you'll find a site from the results...good luck
May 22, 2008 | Epson Stylus C46 InkJet Printer
No printer information
Follow these steps to set up your Epson product and install the built-in Windows Vista drivers:
  1. Set up your computer.
  2. Connect your Epson product to your computer.
  3. Follow the on-screen instructions that Windows Vista displays to guide you through product driver installation.
You need to use a program that can do printing multiple pictures in just one click.
Feb 05, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson R200
Does the error remain when you remove then restore power to the machine? Also reboot the PC.
Jun 14, 2007 | Epson Stylus Photo R200 InkJet Printer
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
