Question about Tappan TGF363 Gas Kitchen Range
Oven will not lite
Older tappan Cook stove all 4 burners work the oven pilot works but can not get the oven to lite it just quit. what might be the problem? Oh yeh this burns l/p this is an old unit here is the model # 36-3246-00/01189-2670580 Please help .
  • 2 more comments
  • levice May 14, 2008
    burners work but stove will not come on cannot find pilot but see burners
  • tim94520 Jun 30, 2008
    hello,
    I turn the oven on and set to 400 and display defaults back to 100 with in a minute. I can not see a polit light, where is it? or what do you recomend, thanks, tim
  • davomatic Jul 10, 2008
    I have a 36" Tappan range with 5 burners. It's probably 10 years old. Everything works except the oven. It won't heat. Oddly enough, the broiler works as well as the "pre-heat" on the oven. Any suggestions?
  • bballardavon Oct 18, 2008
    Tappan Model TGF336BHWD
    Yes the igniter glows, do not hear or smell any gas - what controls gas flow? Should we smell or hear gas if the igniter is the problem?
  • 868 Answers
Older is BETTER !! Replace the igniter,even if it is glowing
REPLACE it !
note:there is a 2% chance the safety valve is the problem.And I'll bet you ,you are in the 98% side on this one.EVEN THOUGH YOU SEE IT GLOW -----IF ITS JUST GLOWING---------GLOWING--------GLOWING---------it's gone ! !
Please Rate This & Thank You ! !
Posted on Jun 12, 2008
I have a 6 yr old Tappan stove, model TGF657BFW5. the burners work fine, but the oven and/or broiler take 5 to 10 minutes to light. when the oven and/or broiler do light, the flame is only about 1/8 to 1/4...
that ignitor should lite the flame within 40 to 60 seconds if not the ignitor is bad.even though it glows red it doesn't mean it's good it works with amps change the ignitor
Nov 06, 2017 | Tappan Ovens
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
Oven not receiving any gas but pilot is working
Sounds like you have a weak ignitor (pilot lite) . The ignitor has to turn white hot , not red , orange , but white , to open the gas valve . Replace the electronic ignitor and that should get the oven working .
Aug 16, 2009 | Danby D9604 Refrigerator With Ice Box
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Tappan Stove 5 burner with Oven
does the pilot seem low?you can remove the pilot then clean it out,let me know.
Nov 10, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Jul 20, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan TGF363 Gas Kitchen Range Logo
431 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
