Question about InFocus LP290 1100 Lumen XGA LCD Projector Multimedia Projector
Projector light turns off
I am in a conference, the projector worked 2 days ago. Today at the main conference, it comes on for a few moments then shuts off the lights. The power light slowly flashes a dim green. I am desperate
718 203 3200 ext 147
  • 2,336 Answers
Check for a bad cable from the video source to the projector video input.
I would suggest to open the projector and check for a loose connection somewhere around where the light is connected. Also check if the cooling fans are working properly.
Check the number of hours on the projector light as well, If the number of light hours have been exceeded, It may be time to replace it.
Good Luck.
Posted on Feb 01, 2008
    Genius:
  • 3,422 Answers
if you have Enabled Auto-Shut Off Option. This May Happen. Try Disable Auto Shut-Off Option.
If u still get the same problem then reset the bulb life once..
finally even if the above method doesn't work then you need to replace the bulb, and then reset the bulb life after i replaced it.
Also do reply if u need the manual ill give it to you..
Goodluck,
Don't forget to rate me as fixya..
    Guru:
  • 1,894 Answers
Lamp problem
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
My epson EMP-S1 projector won't turn on. It worked fine two weeks ago but the power lights won't even come on now.
leave it plugged in for a few hours and see how it goes im talking like 4 hours... if still nothing then it could be the fuse on the main power board.... hope this is helpful :)
Feb 28, 2011 | Epson EMP S1 Multimedia Projector
My InFocus LP 600 won't turn on, nothing lights up, not even the LED lights. I've had this projector of 6 years and have changed the bulb once before (2007). The other day I was using the projector and...
If you have no LEDs then the projector is not getting power so the problem won't be the bulb.
First, check the mains power cable works. Try it in another appliance if you have one. Swap it of possible. If it has a fuse in the plug, change for a new one of the same amp rating.
Second, confirm that the wall socket you were using still works. Again use another appliance to verify it works.
Third, check the mains inlet on the device for a removeable fuse. I do not think that this model has a user serviceable however it would be worth disconnecting the mains power and checking carefully in the vicinity of the main inlet. It may be under a pop out panel, or a barrel type to be unscrewed.
You should replace this with one from a local hardware or electronics store, ensuring that you match the type very carefully to avoid any further damage.
If none of these steps help, you should contact Infocus service for help. It is likely that your power supply has failed. This projector last shipped in March 2007 with a 2 year warranty so it is unlikely to be covered for repair by this method. You may have purchased an extended warranty or other appliance insurance which could help cover the repair charges or spare parts.
Feb 21, 2011 | InFocus LP 600 Multimedia Projector
Sanyo plv z2000 warning led it shutdown
Check all the fans if its working or avoid anything that cover the exhaust fan, or the temperature of your room.
Oct 23, 2009 | Sanyo PLV-Z2000 Projector
The projector keeps shutting off during use. What may be the problem?
I make sure the air filter stay cleaned and no vents are blocked I have had my projector 2 years. I had to send it in last year. And, it went out again today. I hate this projector and would never buy another one. My other projectors lasted 4 years before I had to even change the bulb. I use it everyday all day. They didn't tell me if it was the bulb or the fan. But again today it just quit while I was using it.
Sep 02, 2009 | Sanyo PLC XU35 Multimedia Projector
Toshiba MT200 videoprojector won't start
if there are no leds lit on the top, the power supply is gone. if there are leds on the top, which ones, are they blinking, how many times, and what color?
Sep 01, 2009 | Toshiba TDP-MT200 Multimedia Projector
464 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
