Question about Refrigerators
Ice maker not producing any ice
My ice maker is not producing any ice at all. I had a technician come out and he told me that he thought water was frozen in the line and to unplug the refrigerator and leave the freezer door open for at least 24 hours and then see if it worked. It didn't. I don't understand why there is no water in the ice tray at least. It seems that if the ice maker was broken I'd at least see water/ice in the ice tray. The tech did mention that one of the prongs in the ice maker was broken and that we probably needed a new ice maker. He said that the one remaining prong would probably not last long. Is it possible that the ice maker is broken and I just need to replace it? And if so, where does the water go inside the ice maker to make the ice. Can I just not see it but it's there?
  • michaelmcart Feb 16, 2009
    Thats the same with me - my family has GE profile fridge/freezer, and about two days ago it stopped producing ice! i've been searching the internet for a solution for about two hours now. SOMEONE PLEASE HELP ME!
  • 833 Answers
BG...I'd buy into what the tech is saying. There are a number of ways water gets in but usually, it is a solenoid valve which lets water into the tray. The valve is controlled by a float switch. Usually, these items are replaced as a unit. When you touch them, everything cracks. If no power, then none of the functions will work...no water flow, no auger action.
Posted on Feb 01, 2008
Why don't my ice maker work
Good Morning Friend,
I understand the ice maker is not working in your Frigidaire refrigerator, even though you have replaced the ice maker and the water valve. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the ice maker is not producing ice. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Refrigerators
Ice maker in Kitchen Aid stopped making ice
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Replaced icemaker with new one but still not working
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
LG refrigerator french door icemaker not working
Jan 16, 2009 | LG LRFC25750 Refrigerator French Door
I just changed the water filter and in my fridge and now my ice maker had no water flowing to it.
Jan 06, 2009 | Refrigerators
Ice maker won't quit dispensing ice cubes don't have ice skates!
Dec 11, 2008 | Amana Refrigerators
Ice maker stop making ice for kenmore 106.56352500
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker not making ice refrig.model#gsc23kswc ss
Check the following suggestions from repairclinic:
Oct 10, 2008 | GE Refrigerators
Ice maker does not work
I had the same problem and even called a technician only to be told they would come out for $70.00.
I got a tip and learned that nothing was ever wrong with the icemaker. What you must do is turn the temperature up to the maximum for a period of at least 8 hours. Especially after changing the water filter or unplugging, power failure, etc. Once the icemaker is producing you can then lower your temperature gauge.
Sep 13, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Amana SBS Water and Ice maker issues
The water solenoid on the back of the refrigerator at the bottom is becoming clogged. There is only a very small hole in the diaphram of the valve. I suspect you have very hard water, or at least a fair amount of sediment in the water.
This valve will most likely need to be replaced by a qualified technician.
They sometimes can be cleaned, but it doesn't always work.
Jun 02, 2008 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
236 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
