Question about Toshiba TDP-S8 Multimedia Projector
Large white vertical bar thru picture during projection
Large white, sometimes flickering, vertical bar, approximately 2 inches wide during image projection. Even before PC connection when "TOSHIBA" projects during warmup, part of the "O" is missing as if the graphic image cannot be projected via the video-to-light converstion.
Two reset attempts to factory settings seems to have been the fix.
Posted on Feb 06, 2008
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Toshiba 57H82 entire screen flickers. Not clear. mult images
Sounds like the Hyper board is needing replacement very common problem for toshibas.
Dec 27, 2008 | Toshiba 57H82 57" Rear Projection...
PIcture Flickering
you may have a convergence problem. need to replace the stk 392-040 2 eq..
Jul 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
White vertical line on left side of screen
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Jan 20, 2008 | InFocus IN72 Multimedia Projector
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Nov 12, 2007 | InFocus ScreenPlay 7205 Multimedia...
Toshiba TDP-S8 Multimedia Projector Logo
449 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
