Question about Singer 7436 - INGENUITY
Singer 7430 I have a Singer 7430. I am trying to quilt and need to attach a walking foot. How do I attach it on this machine?
  • bjwillia Jun 03, 2008
    I can attach the walking foot okay. The problem is after I start to use the walking foot, the top thread keeps breaking. When I switch to another foot, the top thread is fine. What am I doing wrong?
I have a new machine. This is the second the first had the same problem so I exchanged it. It worked fine on 1 project on both machines the next the time it did the following. When sewing stich #8 which is a zig-zag stitch with a straight line on one side, I get the #8 stitch on one the bottom side and the #13 stitch on the top side. I have read the manual, also re-wound the bobbin twice re-threaded the machine twice and changed the needle none of these worked. Do you have any suggestions.
Posted on Apr 21, 2008
You go to the back edge of the presser foot (where it would be) there is a little button and a little slot and out the back of the presser foot toward the slot and it should click in
Posted on Mar 27, 2008
Does the singer 533 have either a walking foot, a patchwork foot, or a quilting foot
You should be able to find some, if not all, of the presser feet you mention. You just need to determine what shank your machine has and make sure the presser feet you purchase have that same shank. (You may even have a snap-on adapter for your machine, so you just need to order the snap-on feet you want.)
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
Singer 533 Stylist Parts
Free Motion Quilting Foot for ALL SINGER KENMORE
Apr 19, 2017 | Singer Sewing Machines
How do I attach the quilting bar to the walking foot on my Simplicity Quilters Classic? The manual doesn't show how to do it
There should be a hole across the back of the walking foot (penetrates the walking foot usually from right to left, although some feet will have 2 guides--one for left to right, the other left to right) where the bar mounts and a screw to tighten and hold it in place.
Quilting Bar Attachment
Oct 06, 2016 | Simplicity Quilter's Classic SW240...
Singer Quantum XL 3400. How do I adjust the presser foot to decrease pressure when quilting several layers?
The owner's manual would most likely have the information. If there is an adjustment is is most likely on the top left of the machine or on the left side of the cover (over the needlebar).
If you are sewing slick fabric that shifts under the presser foot, try using a walking foot or a roller foot.
SINGER Roller Presser Foot Tutorial
Sep 05, 2016 | Singer Sewing Machines
Machine well not work with the quilting foot what can I do
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? h
May 17, 2015 | Juki Sewing Machines
I have a singer 6202 sewing machine and I need to know how to attach the walking foot for quilting. thanks
You have to unscrew the presser foot, then attach the WF, using the same screw.
Make sure the lever on the WF rests on top of the needle bar clamp.
Some WF have a two prong lever and this fits around the needle clamp like a lobster claw.
May 22, 2010 | Singer 7436 - INGENUITY
How to attach a quilt guide
You have to unscrew the screw for the presser foot first. The walking foot will then fit. Use the same screw to attach the walking foot. Before you insert the screw, take the white handle on the walking foot and slide it on the screw arm for the needle. Now tighten the screw.
Mar 21, 2010 | Singer Sewing Machines
I WOULD LIKE TO TRY MACHINE QUILTING WITH MY ROSE MACHINE. DO I NEED A SPECIAL FOOT ATTACHMENT OR COMPUTER CARD?
If you want to piece quilts, I recommend a 1/4" piecing foot. Husqvarna make several different types that may be used on the Rose.
If you want a dual feed or walking foot, check out the new Interchangeable Dual Feed foot.
You only use card with the Rose for embroidery, which you can do on a quilt, but not necessary.
Feb 04, 2010 | Husqvarna Sewing Machines
Singer 7430
If you reach behing the foot holder there is a black lever. You can use this to remove and install each foot. Don't be afraid to play around with your machine, there's not much you can do to it that can't be fixed easily.
Apr 09, 2008 | Singer 7436 - INGENUITY
How do I attach a walking foot
Okay let's get started.
  • First let's look at the walking foot.
  • Turn the bulky body so that it's away from you.
  • On the left you see a groove that is going to be where you attach the foot to your machine.
  • On the right is a u-shaped arm which you can move up and down. It will go over the needle clamp
Now, let's remove your present foot from the machine and look at it.
  • Loosen the foot screw until it almost comes off. (if it does come off, screw it back on a bit.) The screw is on the left of the foot-bar.
  • On the right you'll see the needle bar with a needle clamp (what you tighten when you replace a needle) on the right of the needle-bar.
Okay the walking foot business.
  • slide the walking foot into position so that the foot screw is in the slot on the right and the u-shaped arm is over the needle clamp, with the needle clamp in the middle of the u-shaped opening.
  • Tighten the foot screw securely, it's going to be under more strain than normal.
  • While you're at it, check that the needle-clamp is nice and tight as well.
Okay, then! There you go... Happy sewing.
Are you happy? Than please vote
Here are a few helpful pictures.
Feb 01, 2008 | Singer 7436 - INGENUITY
Singer 7436 - INGENUITY Logo
133 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
