Question about Cameras
My camera I have a fuji digital camera and i droped and the lens will now not go back into the camera and on the screen it says zoom error. can it be fixed and if so where. many thanks Emma
  • OCEANIZM Feb 18, 2008
    I accidently dropped my camera and now whenever I turn it on to take a photo, the screen reads 'zoom error'. I was having problems with the lens cover getting stuck before but it's now become worse because it cannot open at all. Would you know an estimate price on getting it repaired in New Zealand? Thanks. Alisa.
  • JelloMellow Jun 17, 2008
    I have the same problem with my Fuji Finepix Z2. My friend dropped it accidentally and zoom error occured.. I had the same problem a month ago and another friend fixed it by closing the lens and reopening it again, I'm not too sure how he did it but I tried following how he did it but apparently, nothing happened. grrr... it's frustrating! anymore suggestions on how to fix it aside from taking it to an electronic electrician?
    Master:
    Sergeant:
  • 462 Answers
Dear Emma
I suggest you not to try putting back the lens inside, rather u can take it to the Fuji service centre but they will charge you a lot, instead you better go to a standard electronics repair shop, i am sure they will do it.
Thankyou
Posted on Feb 02, 2008
Getting an zoom error on my fuji film finepix z90, what can i do?
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 25, 2011 | Fuji FinePix S304 Digital Camera
On the screen the problem is ZOOM ERROR. The lens is out and will not go back in.
The zoom motor is your issue now what you can try is taking the batteries out then gently push the lens back in if the lens does not give any play then stop and take the camera to your nearest camera shop.
Thanks I hope this does help please do click on the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 17, 2010 | Fuji FinePix E510 Digital Camera
Zoom error lens won't open on Fuji A345
Charged your batteryfully if same result then follow the reason.
Location which may have damaged
207dc80.jpg Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 13, 2010 | Fuji FinePix A345 Digital Camera
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
Zoom error
The lens got out of track. Try to have them back by forcing gently the lens in ou out with your fingers. If they are bent, force them straight. Hope it helps.
Nov 21, 2008 | Fuji FinePix A600 Digital Camera
Zoom Lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2008 | Fuji FinePix A303 Digital Camera
Fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom button, the lens pushed out again and the camera worked normally for that time. I had to go through that procedure every time I turned the camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
Jan 02, 2008 | Fuji FinePix A600 Digital Camera
ZOOM ERROR
I used to get that error all the time with a earlier Fuji FinePix with the slide-over lens cover. If the cover wasn't pushed back completely, the lens would extend only so far and then give an error. Make sure that there's nothing (dirt, hair) on any of the lens surfaces and make sure the lens is fully extending when you do turn the zoom on. Don't let anything touch or bump the zoom while it's moving, either.
Not sure if this will help, since you have a different model. This is what worked for me, though.
Nov 16, 2007 | Fuji FinePix F470 Digital Camera
Camera lens cover wont open
Get onto Sony Tech Support team. This is a camera failure the will honour the warranty here I am sure.
Jul 06, 2007 | Fuji FinePix 6800 Zoom Digital Camera
Cameras Logo
318 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
