I turned off my friends computer at the wall before it had shut down!
Now it won't turn on, there is a light on on the motherboard ( ABIT MGURU)
and when they press the power button it displays code 83. they have tried taking the battery out of the motherboard but this has not helped. any ideas?
thank you
  • koan May 11, 2010
    Are you sure it's not a "8.3" ?
    From what I have read it, it seems as though it could be several issues.
    Did you unplug from the wall by tripping over the cable? Many solutions suggest reseating the motherboard and heatsink. However if the computer was not bumped or jostled at all, it would seem to denote a bad Power Supply or motherboard damage.
  • 145 Answers
You may try resetting the cmos, there are some pins on the motherboard, usually arund the battery, if you install a jumper on the ones labeled reset and turn the unit on it should clear the bios and you can switch back the jumper to reconfigure the computer. This is just a bios restore, it shouldn't cause any data loss.
Posted on Feb 02, 2008
How to fi a phillips 20fp shuts off in 2 scs.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 29, 2014 | Philips Phillips 20" Color Monitors Model...
Gateway all in one touch screen model zx4931 turns on then shuts off before monitor can boot on.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 25, 2014 | Computers & Internet
Last night I cut my computer off and it froze on the shutting down screen so I held down the power button and it cut off. Now when I cut it on the light on the monitor is orange. It's Gateway 817GM. Help?
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Jun 27, 2014 | Computers & Internet
Custom build PC shuts down by itself
you are overheating.did you use enough termic paste ? your computer shuts down for so it not breaks the processor.se to at allways as few startup programs as possible.and invest in a new PSU.
May 28, 2013 | Abit KT7A Motherboard
I have problems with abit motherboard nf m2s purchased 12/06. Computer will shut down unexpectedly and have difficulty booting up without shutting down multiple times. The motherboard has at least 5...
unfortunately that is the problem. sooner or later it will just not boot up. If you are capable and want to get in to it, you can change the capacitors. if not look for a board. try ebay or pricewatch. they may still have one that would fit your processor. =)
Jun 19, 2010 | Abit NF-M2S Motherboard
Hi When I try shut down the pc Windows XP will close leaving the power supply, cpu,fans, usb still running To shut down the pC I have to turn off the power switch at the rear Please help
This issue also cause by a hard drive errors, check your hard drive for errors. In My Computer window, right click Local Disk C select Properties, go to Tools tab, click Check Now button, put check on Automatically Fix Errors and Recovery of Bad Sectors, then restart your computer to run the check disk operation.
Also read this solutions regarding about Windows XP Shutdown and Restart Troubleshooting
http://www.aumha.org/win5/a/shtdwnxp.php
Jan 26, 2010 | Abit IT7-MAX2 Motherboard
ABIT AB9 PRO WILL NOT POWER UP
Sounds like it's going to die or its gone faulty,
Might need to replace it or take it to a computer store and have them check it out.
Dec 28, 2008 | Abit AB9 Pro Motherboard
Computers & Internet Logo
729 people viewed this question
David Payne
David Payne
