Question about RCA HD52W59 HDTV Projection Television
52 in RCA widescreen HDTV Monitor
It takes a long time to turn on and while its warming up it makes a high pitched squeeling noise. After you wait awhile you can turn the channel and the picture pops up, but its got a yellowish tint to it. During movies if something blows up, or theres a lot going on, the screen will go black and you have to turn the channel to get it back on. Its only about 4 years old and I dont want to go buy a new TV if its something in-expensive to fix. Any help would be most appreciated! Thanks.
  • 1 more comment
  • Anonymous Feb 03, 2008
    it takes awaile for the tv to come on
  • Anonymous Aug 19, 2008
    I can push the TV on switch, the TV will not come on it blinks three times. If I wait 1 to 2 minutes, it will do the same thing. Sometimes after following through for about 4 to 5 times it will finally come on. The last few times I tried to turn it on it has not worked.
  • Anonymous Sep 08, 2008
    when you turn tv on the off on button will not stay on
    President:
  • 4,402 Answers
High pitched squealing noise >> im thinking is the color wheel which will also give you the yellow color, don't know if that would also cause your screen to blank.
mcm carries RCA
Posted on Feb 01, 2008
Making high pitch whine or squeeling
Check the color wheel and any fans running on the unit. The color wheels make a high pitch whin right before they quit as well as the cooling fans.
Jul 01, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52 inch RCA HDTV is making a high pitch noise with no pitcure but the tv is on and i can hear sound PLLLEASE HELP!!!
your bulb is going out/ or the balast. and possibly the color boads on the inside as well. to figure out which it is take each one out on by one and turn it on. then try another till you determine which it is
Mar 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
High pitch noise, no picture. GE 52" projection, Model D52GW12
Ur high voltage FBT the flyback tranformer,a big black block of plastic with a gray wire connected to a board.The cap it dead.The FBT it useally it dead too,arching noise FBT not holding the high voltage.
Mar 30, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
High Pitched Squeel and turns on and off 3 times and stays off
This is most likely the death song of the main power supply. They normally operate at frequencies well above the audible range but certain components in the process of failing can cause their oscillating frequency to shift downward into normal hearing range.
The squealing you are hearing is from a dying 'switched mode' power supply and is normally caused by a ferrite-core transformer running at the wrong frequency and complaining about it.
The problem with them is almost certain to be caused by failed or failing electrolytic capacitors (cheap to replace) but continued attempted operation could cause further damage.
This problem is common enough that any half-way competent tech with a capacitance meter could weed out the culprits pretty quick.
I'm tempted to suggest you get these repaired if they were otherwise satisfactory since the our later sets too often seem to only survive the warranty.
If I was doing the repair, I would give you an estimate of under $75. US
Nov 20, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca dlp hdtv widescreen - terrrible noise/flashing light
if its a dlp its most likely the color wheel that is causing the problem. Post your model number and i will assist you.Please respond to this same post.
Jun 22, 2009 | RCA P52926 52" Rear Projection Television
Tv turns on and off three times
sounds like the flyback which is a 259296 flyback. You can get the replacement flyback at the following link with free instructions
http://servicemanuals.vstore.ca/
May 13, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 in. rca high def. rear proj. making high pitch noise
the set probably has lots of bad solder connection on the flyback and in the horizontal deflection circuit.
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV making high pitch sound
Hi, There are usually 1 or 2 fans inside the TV's. Could be worn bearings, or fan blade interference. Sorry, without my electric ear working, I can only guess.
Apr 21, 2008 | RCA HD52W56 52" Rear Projection HDTV
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
RCA HD52W59 HDTV Projection Television Logo
170 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
