Question about HP PSC 2410 All-In-One InkJet Printer
Fax HP PSC 2410
I have a dedicated fax line for my HP PSC 2410. every once in a while the fax just won't work. I don't know if something gets "thrown off" when I plug the printer cable into my laptop to print or what. I've been trying to "reset" it by turning it off and then on again but it doesn't seem to be working. Any suggestions?
Thank you!
I HAVE PSC 2410 XI All-In-One AND Fax HP PSC 2410xi does not work PLEASE HELP
Posted on Feb 02, 2008
6ya staff
SOURCE:
Hp psc 2410 photosmart driver win7
HP no longer provides support for drivers for this printer. The newer Windows OS will support the printer natively, but sometimes it requires a little finesse from the user. Here is a link to an HP forum where folks tell how they worked out the communications issue for the print and scanning functions. Hope this helps!
adding hp psc 2410 printer to windows 7
Aug 01, 2016 | HP PSC-2410 PhotoSmart All-in-One Color...
Not faxing on 2410 all in one hp printer
make sure that youre using a regular line not dsl or voip line make sure youve connected it to the right port it should be line 1 connect the printer direct to the phoneline check settings "rings to answer" must be set to 3 ring you should have distinctive ring it must be set to all rings check fax speed it must medium then run a fax test all of these are under fax setting on your printer send fax tp 1800-hpfaxme,if recived a reply your good to go...otherwise call hp support...
Mar 30, 2011 | HP PSC 2410 All-In-One InkJet Printer
I keep getting an error 421 when i try to fax something and i am not able to recieve faxes... i have an hp psc 2410 aii in one printer
Have you DSL switch in place. you must plug printer into that then the switch into phone socket.
Uninstall then reinstall, being patient and following instructions when asked for information.
Nov 10, 2009 | HP PSC 2410 All-In-One InkJet Printer
Not recieving fax
Try This
Goto to Setup (on the printer) Fax settings Check The ECM(Error correction mode) : It should be off ; DRP(Distictive ring patern): ALL Rings; Rings to answer 2 (dedicated) ; 6 (Answering machine ); There should be no voice mail service activated otherwise you won't be able to recieve fax; Try getting fax it should work;
Regards
SOumajit
Aug 11, 2009 | HP PSC 2410 All-In-One InkJet Printer
My hp psc 2410 photosmart All-Inn-One is not allowing me to receive faxes. It goes through the process of connecting but then says fax failed. I am able to send faxes out and they are received. I am using...
try going into the advanced fax settings and turning off error correction mode. also if you have distinctive ring on the phone line make sure it is set to the right number of rings for the line. ex. fax line is second number set the answer ring type or distinctive rings to double
Aug 08, 2009 | HP PSC 2410 All-In-One InkJet Printer
We have one phone line for our house and want to get a fax but do not know how to set the printer for that
Please see this link and this link for setup instructions for faxing with the PSC 2410 printer. Then go here for detailed instructions on how to use the fax capability of your machine.
If you have any further questions, the online support page for your model here may be helpful.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
I cant get the fax to work on my hp psc 2410 all in one
Try going into the fax menu and setting preferences. Insure that you have a good telephone connection to the outside line. Try going to www.hp.com and troubleshoot. Good luck.
Jan 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
Error 232 receiving fax
fax error 232 indicates a communication failure between the sending and receiving units. I'd check for line noise on the phone (you can hear it as cracks and pops) If your fax line is not dedicated, any noise from another phone pickup or an answwering machine can cause the failure.
Jul 17, 2008 | HP PSC 2410 All-In-One InkJet Printer
Fax
error code 388 says :-
Unable to complete the handshake.
*Try to send the fax at a different time when telephone line conditions have improved.
Mar 06, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
326 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
