Question about Vizio Gallevia GV42LF 42 in. LCD Television
Visio 42" Galeria Red lines accross the screen and red bleeding around corners
The display was great for a month then it started to display red wavy blotches accross the screen with red bleeding from a corner of the set. Any ideas on what's causing this?
  • Splashrap Apr 20, 2008
    i have a 37" Vizio and the same thing happened to me.
  • Anonymous Mar 30, 2009
    I have a 26" Samsung LCD TV with red lines bleeding across the screen. Most obvious in the white areas but it exists all over. I have HDTV with dish network antennas.
    Sergeant:
  • 261 Answers
Is the unit still under warranty? If it is i would go that route first if not, Maybe consider purchasing an extended warranty and then go from there. I hope this was helpful ... Sincerely Jay
Posted on Feb 01, 2008
Red lines across the screen and bleeding around corners
This is your LVDS cable. You could replace it yourself and find a replacement online.
1) flip the LCD screen down onto a soft blanket
2) remove all 30 - 40 screws on the back
3) pop the back off
4) look for the LVDS wire, it runs from the top of the LCD screen to under the power unit and into the Main Board.
Jan 05, 2010 | Vizio VW42LF 42 in. LCD HDTV
Wavy red lines accross screen
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 13, 2009 | Sony KP-51WS510 51" Rear Projection...
Hello, I've got red wavy lines across screen
There are two common problems with these sets.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 22, 2009 | Samsung HCM5525W 55" Rear Projection...
Red and Green wavy lines in the upper left hand corner?
*Screen Looks 3-D
*Colors wont align
Jul 25, 2009 | JVC AV-65WP74 Rear Projection Television
Wavy red lines or red pixelation, not sure what it is
Go to Vizio website and buy the extending warranty, you need to have your TV replaced since the problem is with the screen itself.
Dec 15, 2008 | Vizio L32 32 in. LCD HDTV
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Nov 24, 2007 | Televison & Video
Toshiba Rear Projection 42 "
Nov 23, 2007 | Toshiba 50H72 50" Rear Projection...
Lines on screen when first turned on
First, solder around flyback then solder ground points,you should also solder crt socket pins on all 3 tubes, also see if your focus and screen drive block is ok.Check anode buttons!
Sep 22, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Vizio Gallevia GV42LF 42 in. LCD Television Logo
521 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
