Question about Kenmore 96422 / 96424 / 96429 Electric Kitchen Range
Kenmore range I'm having with an F1 problem. Steam comes out of the head of the range and not the vent.....Due to this all the inside of the head is all orange, even with ajax you c'ant get it off. Its seems like the vent is blocked?? How is this possible. I have a feeling it has been blocked for years since . I think all the steam is the problem for the F1, Now my oven is not working at all.....
  • 29 Answers
Ours did that too. Grease and smoke gets in under the plastic and corrodes the circuits in the controller. At first the F1 would show up every couple weeks, then it became permanent. We did have to replace the circuit assembly. Yes make sure the vents are working, and keep the front of the panel clean.
Posted on Feb 02, 2008
Water in dryer
usually due to bad venting or drum glides
Oct 11, 2014 | Kenmore HE5 Steam 7.5 cu. ft. Electric...
Getting an F1 code on my kenmore range
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad
Feb 28, 2012 | Kenmore Kitchen Ranges
I have purchased a 1960 house with a Kenmore 850 range hood. I want to install my Dacor 30" 4-gas-burner range (about 14 years old and brought from my former home) and need to know if the CFM of the...
No problem Be sure the duct coming from the range hood is the same size of the duct through the roof , Or it mat be a vent that don't vent to the outside, IF so throw it out , and get a vent that vents to the outside , Or get use to smelling the odors of all your cooking inside your home
Sep 28, 2017 | Kenmore Kitchen Ranges
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
E1-F1 error on Kenmore Range
A persistant F1 error code usually means that the oven has exceeded the safe maximum operating temperature for the oven.
This is usually due to a faulty oven thermostat unit.
If the error code reappears after using the oven you should get the thermostat replaced.
Jan 23, 2010 | Kenmore Ovens
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Stainless dis-colored where the oven vent is, wont come clean.
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Mar 29, 2009 | Kenmore 46123 Stainless Steel Electric...
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Steams
It could be a problem with your cooling fan or hood fan not venting the cavity enough.
To help you most effectively, it's better to post your full actual model number. But I'll give you the general info for now.
If this is a countertop model, you should feel strong air flow coming out from the back.
If it's an over the range model, you should hear the internal fan blowing when you hit Start and see the steam moving around while it's heating.
If the fan is not blowing and air is not blowing or if the next system is not working or blocked, you will get more steam than usual and the magnetron will likely end up being damaged.
Some steam buildup inside is normal, but not too much. It's kind of subjective, but it's dependent to a lagre degree on that air flow.
Most newer models don't have any gaskets to worry about, but older models may have deteriorated gaskets which limit the air flow.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer once we pose a final solution.
Nov 29, 2007 | Kenmore 62702 Microwave Oven
Kenmore 96422 / 96424 / 96429 Electric Kitchen Range Logo
124 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
