I have just purchased a DVD Recorder model DMR-EX77EB. Can I watch digital broadcasts after I have set the timer to record a programme and whilst the programme is being recorded?
Should be able to if the recorder is set to record a certain channel .. you will just have to try it
Posted on Feb 08, 2008
6ya staff
SOURCE:
I have the DVD/VHS recorder/player Panasonic Model DMR-E75V, I have connected the 2 scart cables to the digital decoder and TV set but I cannot record even if I can play the VHSs and DVDs normally. It's a...
First of all you have to connect only one SCART cable ( one end to TV and the other to DMR ).When you are watching a program on TV select the DMR source ( input selector ) to SCART. Just press the record button with a blank DVD inside and it will record. Some Digital broadcast might have copy protect content which will prevent the recording from happening.
Mar 10, 2011 | Panasonic DMR-E75V DVD Player/VCR
White colour displaying as pink on DVD recorder DMR-EX77EB, problem just started a few weeks ago.
Very similar problem with my DMR-EZ27. About 10 minutes into playing back a DVD the color starts going away until I only see a black/white movie. Sometimes color comes back in partially then back to b/w
Feb 13, 2011 | Panasonic DMR-EZ48VK DVD Recorder
Stop Substitles on a LG RHT497H 160G dvd recorder?
I have the LG DVD recorder DRT389H which has the same problem. You can't switch off the subtitles during timer recording from the Electronic Programme Guide. The only way I could stop this was to go to the main set-up menu then select the A icon. Select DTV Subtitle and choose a language that the TV programme isn't broadcast in. I chose Gaelic. The only disadvantage is that this stops any subtitles being recorded so you can't access them later.
Dec 26, 2009 | LG RH177 DVD Recorder/HDD Recorder
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
Panasonic DVD player shows EXT-L in its display.
You have switched machine onto external link mode
Either press external link on remote or find it under the flap.
Has a small child been playing with the remote?
Jan 30, 2009 | Panasonic DMR-EH57 HDD Recorder Player
Panasonic DVD Recorder DMR-EX77EB says no signal but no problem with aerial TV says signal strength 5 no problem for over a year since bought new until now
I restarted 'Auto setup' this deletes the channel settings (which had presumably been corrupted) and re-installed them from the incoming signal.
alexanderosb
Aug 30, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Dmr-es10 dvd recorder - cant get the machine to record digital channels form tv
Channels 1-5 are I believe for Analogue reception. To record from my digital Freeview box, I'm plugged into SCART port 2 (bottom most port on right hand side of machine as you look at it from the front). Use your remote to change the channel to A2 with the <CH> rocker button just above the video+ button on the controller. This will then record whatever channel your freeview box is set to - the only pain is you can't watch a separate channel whilste recording.
Kind Regards
Brad
Apr 01, 2008 | Panasonic DMR-ES10 DVD Recorder
Dmr-ex77eb-k
The Panasonics are very picky about the media ie brand and quality of the DVD blank. Try a different brand and see if that helps.
Nov 23, 2007 | Panasonic DMR-E80H DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
