Question about RCA D52W19 52" Rear Projection Television
Rca d52w19 projection tv problem
TV start shutting off after being on just a short while, would have to wait 5or10 minutes for it to turn back on. finally notice smoke coming from the back, pulled off the covers and the only thing I noticed burnt was a capacitor, 2000vdc .0087uf. would this be the only problem or should I check other component
  • 1 more comment
  • JTown Mar 31, 2008
    same problem, only noticeable damage is the same capactior.
  • Proudman101 Apr 01, 2008
    I also have the same problem ,
    I have a 52 " RCA rear Projection TV, I can Turn the TV on and In a Matter of 1 minute the TV turns it self off.. And sometimes it goes on and off, But only when i turn it on Initialy
  • sitndownlow Dec 10, 2008
    SAME TV SAME PROBLEM STILL CANT FIND PART. SEEMS TO BE DISCONTINUED
Part number DF3R822K from American Capacitor Corp.
Posted on Mar 28, 2008
    President:
  • 4,402 Answers
I think you have more problems.
Posted on Feb 01, 2008
My rca d52w19 makes a noise when turned on.no picturet henshutsof
what kind of noise? is it like an electrical buzzing?
a rapid clicking?
Apr 29, 2010 | RCA D52W19 52" Rear Projection Television
D52W19 about 4yrs old. Recently after being on a short while, the screen will go erratic or black and then the tv will shut off. I can not get it to turn back on until about ten minutes. I removed the...
depending on what type of erratic video it is before shutdown it can be either the Small signal board or the Deflection board are what usually cause those type symptoms. You can get replacement parts from www.tvrepairworld.com
Mar 28, 2010 | RCA D52W19 52" Rear Projection Television
RCA D52W19 rear projection tv wont turn on
Try this. Change the channel of your TV to 3, do you see a picture, if not. Unplug your system for the TV. Turn off and unplug the TV. Leave it off for about 10 minutes so it can discharge. Turn back on the TV and see if it re-sets. If this does not work let me know. Give me a detailed report including any brand or models you are asking about. Hope this helps.
JimmyC
Oct 04, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
My RCA Bigscreen HDTV will not turn on.
Thats either the flyback or the HV splitter. If the sound is coming from the rear left side its the flyback. If its coming from the front of the set its the HV splitter. They are both easy to replace. I will post a link where you can get replacements with instructions if you would like.
May 06, 2009 | RCA D52W19 52" Rear Projection Television
52" RCA d52w19
About middle of the board you removed the flyback,there is a u shaped heat sink this is in the middle of the board,behind the heat sink is a blue cap 2200 uf ,if the top is pushed up the cap is bad.
Mar 11, 2008 | RCA D52W19 52" Rear Projection Television
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 power problem
these set is what i like to call VAlue sets.. you can get these for 800 at walmart. If you smell something theres a good chance its what is called a flyback transformer... i repair that averages about 300 to replace. Caution it may be more. DANGER, Do not attempt repair of set unless qualifed to do so tv generte high and leathal voltages.
Jan 01, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
162 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
