Question about Toshiba Satellite A105 Notebook
Won't maintain Internet connection
My Satellite A105 S4104 can't seem to maintain an Internet connection more than a few minutes. Once it drops, the only way to reestablish it is to reboot. It does this under XP Media, XP Pro SP2, XP Pro SP3 beta, and under Vista Ultimate. I've tried reinstalling the operating system. I've swapped out drives (tried 3 different ones) and installed a clean OS. I've swapped out memory cards. Still does it. Any thoughts?
  • oldcrow74 Feb 01, 2008
    Oh, I should've mentioned that I've also tried 3 different modems with the same results. I don't have this problem with other PCs, so I'm sure it's not the modem or cable. I'm connecting via USB directly from the modem.
  • 58 Answers
Generally the modem connections have time setting. Check if there is anything on the settings.
Another possibility it might your modem doing that. I have seen that happening on a PC.
I think you have to give a little bit more details about too to give a better opinion.
Posted on Feb 01, 2008
How do you reset key board for normal typing
The instructions below are for Windows 7. If you have a different version of Windows, it should be similar, but some of the steps might be slightly different.
  • Go to Start - Control Panel
  • Go to Region and Language
  • Go to the Keyboards and Languages tab
  • Click the Change keyboards button
  • Change the default input language to English (United States) - US
  • Under Installed services, if you have any foreign language keyboards listed, remove them.
Oct 19, 2012 | Toshiba Satellite A100-ST3211 A105-S2719...
How to tell if a105-s4074 satellite battery is bad
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 28, 2012 | Toshiba Satellite A105-S4074 Notebook
I lost the main password to our computer. how would I fix this?
look on the net for a program called "Active password Changer". look for version 3. Burn the program to a cd. go into your bios and make the cd drive the 1st bootable drive. The progam is very easy to follow. When it finds the passwords tell it to remove them. Restart the laptop and it wont ask for any passwords. Just make a new one in the usual way and dont forget it!!!
May 27, 2011 | Toshiba Satellite A105-S4104...
When I first boot up my computer and click on either a program or internet explorer, the program seems to take a few minutes to appear on my screen. This continues every time I call up a program, until...
First go in and clean out cookies, and stuff that would be slowing down the computer. To do this click on the tools bar on your internet explorer, go down to options. When it is popped up you should be able to find cookies, web history ext. Go in clear this out see if it helps. It may also need to be updated or cleaned by a professional.
Jul 19, 2010 | Toshiba Satellite A105 Notebook
My toshiba a105s4384 will not connect to the internet using just my wi-fi. However my friend's acer laptop using only wi-fi will connect. Both laptops are on the same desk at a few feet away from each...
Hi there, try to perform system restore on your computer. Click on start menu then select all programs then click accessories then click system tools then click system restore. Once you are inside system restore software, select the date where your computer can connect to your wireless network then restore to that date.
May 16, 2010 | Toshiba Satellite A105-S4384 Notebook
External monitor connection problem
The problem is with the laptop. The femal VGA port is slodered to the motherboard. Once the laptop's MB has been removed you'll most likely find the solder holding the VGA in place is most likely cracked/loose. The fix would be to remove the old solider & apply new.
I can't guide you through disemble, its complex. I can include a site to help you with this.
http://www.laptopka.com/2006/03/18/removing-laptop-motherboard/
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
If you find this all a little too involved it might be worth taking it to a pro.
At this link you can order A105 parts if needed.
http://www.sparepartswarehouse.com/Toshiba,Satellite,A105,PSAA2U-01T018,Laptop,Parts.aspx
I hope this helps you kevinwaynewh!
Mike
Jan 29, 2009 | Toshiba VGA Board Graphic Card
Toshiba A215 bios password
This is a known bug on some Toshiba lappies - and one of the reasons I updated my A215 BIOS 4 times in the last few months!
Not sure if this is what happened to you, but...
Applicable Models: Satellite A100-ST8211, A100-SP471, A100-ST1042, A100-ST1041, A105-S4001, A105-S4002, A105-S4004, A105-S4014, A105-S4051, A105-S4094, A105-S4144, A105-S4034, A105-S4054, A105-S4102, A105-S4124, A105-S4114, A105-S4132, A105-S4134, A105-S4064, A105-S4024, A105-S4211, A105-S4201, A105-S4092, A105-S4084, A105-S4184, A105-S4194, A105-S4174, A105-S4164, A105-S4154, A105-S4342, A105-S4284, A105-S4274, A105-S4254, A105-S4244, A105-S4214, A105-S4204, A105-S4104, A105-S4074, A105-S4547, A105-S4334, A105-S4304, A105-S4294, A105-S4364, A105-S4344, A105-S4021, A105-S4031, A105-S4012, A105-S4011, A105-S4397, A105-S4374, A105-S4384, A105-S4022, A110-ST1111, A130-ST1311, A130-ST1312, A130-ST1313, A135-S2246, A135-S2256, A135-S2266, A135-S4499, A135-S4498, A135-S4488, A135-S4478, A135-S4507, A135-S4487, A135-S4477, A135-S4467, A135-S4457, A135-S2396, A135-S2386, A135-S4637, A135-S4527, A135-S2356, A135-S2346, A135-S2336, A135-S2376, A135-S2326, A135-S4517, A135-S2306, A135-S4727, A135-S4677, A135-S4666, A135-S4656, A135-S2426, A135-S4447, A135-S4437, A135-S4427, A135-S4417, A135-S4407, A135-S2296, A135-S2286, A135-S2276, A200-ST2041, A200-ST2042, A205-S4617, A205-S4639, A205-S4618, A205-S4567, A205-S4577, A205-S4587, A205-S4597, A205-S4629, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S7468, A205-S7466, A205-S7464, A205-S4607, A205-S4578, A205-S4557, A205-S4537, A205-S4638, L35-SP1011, L35-S2194, L35-S2174, L35-S2161, L35-S2316, L35-S2366, L35-S2206, L35-S2171, L35-S1054, L35-S2151, M200-ST2001, M200-ST2002, M205-S3207, M205-S3217, P100-ST7111, P100-ST1071, P100-ST9612, P100-ST9412, P100-ST7211, P105-S921, P105-S6002, P105-S6014, P105-S6054, P105-S6034, P105-S9337, P105-S6227, P105-S6217, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6134, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S6024, P105-S9312, P105-S6004, P105-S6012, P200-ST2071, P205-S6297, P205-S6298, P205-S6247, P205-S6287, P205-S6257, P205-S6267, P205-S6237
Tecra A7-S712, A7-S612, A7-ST7711, A7-ST7712, A7-ST5112
Issue
The computer models listed above may display a "Password =" prompt when the computer is turned on, even though no power-on password has been set. If this happens, there is no password that will satisfy the password request. If the computer is turned off and back on again, it is very likely that the same password prompt will appear. The computer will be unusable until this problem is fixed.
If the problem has not happened yet, you can prevent it from happening in the future by upgrading the BIOS to the newest version.
The occurrence of this problem on any particular computer is unpredictable -- it may never happen, but it could happen any time that the computer is turned on. If this problem does occur, it will be necessary to send the computer to a Toshiba Authorized Service Provider, who will fix the problem at no charge to you.
Resolution
If this problem has not yet occurred on your computer, then click the following link to download and install BIOS version 1.40. This BIOS displays a power-on password prompt only when a power-on password has actually been set via the BIOS Setup program.
You may also browse for a newer version of the computer's BIOS at pcsupport.toshiba.com.
For more help, see Support Bulletin 98081213 Obtaining downloads and support docs from the Toshiba Support website.
If the problem has already occurred on your computer, then please make arrangements with a Toshiba Authorized Service Provider to have this problem fixed at no charge. To locate a Toshiba Authorized Service Provider (ASP), please visit Toshiba's Global ASP Locator at http://pcrepair.toshiba.com
BTW, I've heard that this only happens when you boot up on battery power.
Maybe you can confirm this...
Aug 13, 2008 | Toshiba Satellite A215-S5822 Laptop
Update
Nice to know you fixed it, contact us if you need further help.
Thanks.
Jul 12, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
