Linksys WRT300N Wireless Router Logo
Posted on Feb 01, 2008
Linksys wrt300n gaming wirelless lan problem
Hi and sorry for my bad english
I've trying to create a network to play cod4 whit this router, all the people connect to the network but when we strat the server on one pc the other player can't see the game
thanks in advance
Anonymous
Level 1:
  • Contributor 38 Answers
  • Posted on Feb 01, 2008
Anonymous
Contributor
Level 1:
Answers
38
Questions
Helped
35796
Points
68
Can I assume all the computers on the network are running the windows OS? You might want to double check that firewall is turned off PC acting as the server. Also try to ping the IP Address of the server (probably something like 192.168.1.1xx) from all the other computers on the network:
  1. Click Start -> Programs -> Accessories -> Command Prompt
  2. Type in "ping xxx" where 'xxx' is the IP of the PC acting as the server.
You can get the IP Address for your computer:
  1. Click Start -> Settings -> Control Panel -> Network
  2. Double click on the "Wireless Network Connection" (if you're connected wirelessly) or the "Local Network Connection" (if you're connected via an ethernet cable)
Hope this helps!
Unable to connect PS3 to linksys wrt300n, key exchange timed out, signal 100% and key is correct?
For instructions on setting up the PS3, Xbox, or Wii, for a wireless/Internet connection. please click on this link :- http://fixhomenetwork.com/xbox-play-station-wii.php
How to set up Linksys WRT300N Wireless Router
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security b>
Linksys 64bit passphrase
The passphrase is a phrase you create instead of using hex numbers (phrases are easier to remember than hex numbers) to setup the wireless encryption key.
To configure the Linksys wireless setting, connect a LAN cable from the Linksys LAN port to the computer's LAN port. Open a browser and enter the Linksys configuration URL
http://192.168.1.1
Then go to the wireless settings and configure the SSID and WPA or WPA2 encryption.
Use a passphrase to setup the encryption key
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Skinner marvell yukon 88E8001 and Mototola sb6120 linksys wrt300n router each time i connect the router my speed go's from 1.0gz down to 100mbps the link light changes from blue to amber?
1 Check QOS ( Quality of Service) per network devices in the\in the "game" support tab of the router GUI ( Graphical User Interface). this will affect the speed if the bandwidth is not managed here with several device running,
Check with your provide if you still have a speed issue.
I just rewired all my network connections, my wrt300n wireless indicator is not lit. The network is set up on a linksys broadband router on a cable modem and wrt300n was functioning properly when it was...
Try first resetting the router by pressing the reset button of the router fro 10 seconds while power is ON and then after that reconfigure the router.....
How do you connect the new PSP Go to Linksys WRT300N router?
On the PSP make sure the WLAN Switch is turned on. To connect to your router, go to System Settings > Network Settings > Infrastructure Mode then select the Network that you want to connect. If it's Linksys, select Linksys and press X. Select Scan and choose the wireless network and Enter. If it asks you for network key, type your wireless network key and connect. That should do it.
How to set my wrt300n router to use static ip,... i´ve have a problem whit my ps3, and want to use static ip, instead of dhcp(dynamic) should i do it before i do it on my pc and how to do it on the...
You may want to enable the DHCP reservation feature of the router.
What is DHCP Reservation and how do I configure it?
What is DHCP Reservation?
A DHCP reservation is a permanent IP address assignment. It is a specific IP address within a DHCP scope that is permanently reserved for leased use to a specific DHCP client.
You can configure a DHCP reservation in your DHCP server when you need to reserve a permanent IP address assignment. Use reservations for the DHCP enabled devices like print and file servers or other application servers which always have the fixed IP address on network.
Step 1: Access the router's web-based setup page. For instructions, click here
Step 2: When the router's web-based setup page appears, click Setup.
Step 3: Click on Basic Setup.
Step 4: Make sure that DHCP Server is Enabled. Then, click the DHCP Reservation button if you want to assign a fixed local IP address to a MAC address.
Problems with connecting to internet with Linksys WRT300N
Hi Beluis,
Go to Start>Run, type in CMD. In the black box that opens, type in IPCONFIG /ALL. Look at your IP, Gateway, and DNS settings.
IP should be 192.168.1.xxx, Gateway IIP should be 192.168.1.1
DNS should have numbers, but they may vary. If they are not in those parameters, you won't be able to access the router. Let us know if these are right.
The router wiill give you an IP, and Gateway, with no DNS, and that will stop your from accessing the internet.
Shut down that modem, router, and your PC, Make sure your ethernet cable goes from your modem to the WAN, (not LAN!) port. Power up the modem, wait a full 2 min, power up the router, wait a full 2 min, and start up your PC. Try the IPCONFIG again.
Good Luck.
6helpful
2answers
Need the driver for Linksys WRT300N V1 ... can't find the CD
The LINKSYS WRT300N is a standalone device, there are no software/driver needed on your PC for the router to work. However, there is an easy Setup Wizard that is in the CD that normally comes with the unit.
Unfortunately, Linksys did not make the specific Setup Wizard (Version 1.3) for the WRT300N available online. However, if you care to try the Setup Wizard for a WRT54GC, it may downloaded from the LINKSYS ftp site here. I used to have a WRT54G and I did make use of the Setup Wizard for that model. I upgraded to WRT300N. The setup wizard for the old WRT54G worked likewise on the new WRT300N.
Alternately, the WRT300N can still be configured without the CD or the Setup Wizard by logging into the Configuration Page (192.168.1.1). Remember to use LAN interface when setting the router (as shown in the connection diagram) and set your PC to an IP Address of 192.168.1.2, Subnet Mask of 255.255.255.0; Follow on screen instructions and enter settings/configurations manually.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information. Additionally, if you still prefer to have a copy of the original WRT300N Setup Wizard, pls include your email address that I may send it to you as an attachment.
Good luck and kind regards.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
