Question about Xerox DocuColor 12 Printer
Variation in copies
Some time the document backgrond is dark blue ,the copy appears to purple colour output or if i do photo repeat the image of a person come yellowish
    President:
  • 2,072 Answers
I would really recommend a service call.
There is a procedure called Max Setup that has to be run from a service laptop.
What it does is first adjust the white reference point on the machine, then used a test pattern to correct any color errors that are remaining.
The only other thing to do is power off and power in the machine and make the software reset and go through a startup setup
I highly suspect you need to have the proper setups done.
You may also have a bad imaging unit or transfer unit.
I doubt anything routene you can do will correct it.
Posted on Feb 01, 2008
Canon MF3110 - Copy problems When we try to copy a document it comes our blurry, yet if we send a document from computer software it comes out fine.
Try reinstalling the driver first. If that does not work, the issue is with the scanning hardware, which will have to be calibrated. Try doing a calibration of your scanner from the tool box first. If that doesnt work either, then it is definitely scanner hardware defect.
If your all in one is under warranty, I'd recommend you contact the point of sale of the manufacturer. Unfortunately, if your warranty has run out, you will either have to get it serviced or buy a new machine (whichever works out cheaper)
Hope that helps!
May 26, 2008 | Canon Office Equipment & Supplies
Tip
Troubleshooting MINOLTA DI 1611, DI 2011
The copy is too light. The copy density is set too
light.
Use the Auto/Photo
key to select a darker
copy density .
The copy paper is damp. Replace the paper.
The copy is too dark. The copy density is set too
dark.
Use the Auto/Photo
key to select a lighter
copy density .
The document was not
pressed close enough
against the Original Glass.
Position the document so
that it is pressed closely
The copy is blurry. The copy paper is damp. Replace the paper.
There are streaks through the
copy.
There are specks throughout
the entire copy.
The Original Glass is dirty. Wipe the glass with a soft
dry cloth.
The document pad is dirty. Clean the document pad
with a soft cloth dampened
with a mild detergent.
The original is highly
translucent, such as diazo
photosensitive paper or
OHP transparencies.
Place a blank sheet of
paper over the document.
A double-sided document is
being copied.
If a thin double-sided
document is being copied,
the information on the back
side may be reproduced in
the copy. Use the Auto/
Photo key to select a
lighter density for the
background.
The Imaging Unit has
reached the end of its
service life.
Contact your service
representative.
on Dec 18, 2009 | Office Equipment & Supplies
All my 8-1/2" x 11" copies are deeply streaked
Chang your UHR and LHR with stripper fingeres, if it is not available at your country change the fusr unit it will resolve your problem feel free to contact me if you have any difficulties and rate me
May 03, 2011 | Sharp Office Equipment & Supplies
Our printer is so unreliable. you can never print anything without either the colours printing wrong ir lines appear across the image. I have repeatedly tried cleaning the nozzles and deap cleaning but it...
  1. Lift the document cover to expose the platen glass.
  2. Wipe the platen glass (A), white areas (B), and transparent sheet (C) with a clean, soft, lint-free cloth moistened with water.
  3. Then wipe with a clean, soft, dry, lint-free cloth making sure there are no residues left, especially on the platen glass.
  4. Close the document cover and make a copy of a text document to confirm the black line has disappeared.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 20, 2010 | Canon I900D InkJet Photo Printer
I have recently bought new ink for my brother mfc 255cw. While it was running low ink, it would print out copies colored purple. even though I have already purchased and replaced all the ink cartridges, it...
I would suspect your inkjets are blocked Black and blue =purple so the other colors are blocked up Use the nozzle cleaning function to try and remove the clog Run nozzle check after cleaning mode till all colors print correctly
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | Office Equipment & Supplies
Lexmark X5100 printer. I copied a small item 3x3 and doubled its size. Now when I try to copy a full page only one small corner is reproduced. It appears I lost a default setting. How do I get a full page...
If you are using your All-In-One without it being attached to a computer and scanning a document that is getting cut off on the edges:
1 Move the document to a different place on the glass.
2 On the operator panel, press the Reduce/Enlarge button
repeatedly until Fit to Page appears.
3 Press Select.
If you are using your All-In-One attached to a computer:
2 From the software, select a copy setting with autocrop on (Color Photo or Black and White Photo) to make sure that autocrop finds the object and prints it completely.
1 From your desktop, double-click the Lexmark X5100 Series
All-In-One Center
icon. The All-In-One Main Page appears.
2 Click Preview Now to see your scanned image.
3 Select a quantity and color for your copies.
Note: To choose a paper size or further customize your copy
job, click See More Copy Settings.
4 Click Copy Now.
Note: When autocrop is on, the object (wherever it is placed
on the glass) will be printed in the upper left corner of the
page. This might make your copy look different from the
original.
try the above and post back so I know if your issue is fixed or you need more assistance
Jul 12, 2008 | Office Equipment & Supplies
Oh, it's the colors you are having a problem with. Then you probably want to perform an Auto Gradation Adjustment. It's on pages 162-163 of the manual found here: http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Here is what it says:
Auto Gradation Adjustment is a color calibration for the copier and printer. An Auto Gradation Adjustment compensates for differences between the actual and the expected toner densities for each color. An Auto Gradation Adjustment should be performed whenever there is a noticeable change in the appearance (quality) of the output, particularly changes in color
tones or densities. Performing an Auto Gradation Adjustment on a regular basis will help to maintain consistent color quality over time.
NOTE: Since an Auto Gradation Adjustment can affect all jobs for all users, it is recommended that this procedure be performed only by the Machine Administrator.
Copy Job - Text Compensates tones when a text original is copied.
Copy Job - Photo Compensates tones when a photo original is copied.
Print Job Compensates tones when printing with controller line screen.
Network Controller - 1 Compensates tones when printing with Network Controller screen type 1.
Network Controller - 2 Compensates tones when printing with Network Controller screen type 2.
NOTE: Printing the chart for Auto Gradation does not increase the meter count.
NOTE: When gradation adjustment is executed, the following
changes will be made to default copy settings set in System Settings mode: Copy density = Normal or Auto, Color Shift = Normal, Saturation = Normal, Color Balance = 0, Sharpness = 0.
NOTE: When Print or Network Controller gradation adjustment is executed, the printer’s output profiles for the available screen types are compensated.
1 On the Image Quality Adjustment screen, select Auto Gradation Adjustment.
2 Load 8.5x11 inch or A4 paper into Tray 5 (Bypass). Move the paper guide to gently touch the edge of the paper.
3 Select the desired gradation adjustment screen:
• Copy Job - Text
• Copy Job - Photo
• Print Job
• Network Controller - 1
• Network Controller - 2
Press Start. The Adjustment Chart is output.
4 Place the Adjustment Chart face down on the Document Glass with both Magenta color patches against the left side of the glass.
5 Place 5 sheets of white paper on top of the Adjustment Chart and close the DADF. Select Start.
6 To continue Auto Gradation Adjustment with other screens, repeat steps 2 to 5. When you are finished, select Close until the System Settings screen is displayed.
7 Select Exit to exit the System Settings mode.
Jun 24, 2008 | Xerox DocuColor 3535 Copier
My printer will only print in blues pinks and purple and black and white
ur printer prints in blues pinks n purple: its very simple :there r three prime colours in ur colour cartridge that forms all the other colour variation they are cyan, magenta n yellow. ur yellow colour in ur cartridge is either dried or empty thats the reason its not printing the colour variations which requires yellow. the solution is to either get ur colour cartridge refilled or replace ur colour cartridge. rate this solution as fixya n encourage us to help u solve ur problems in future too.thanks 4 using fixya.
Jun 12, 2008 | Office Equipment & Supplies
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Xerox DocuColor 12 Printer Logo
79 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
