Question about Microsoft Wireless Optical Mouse USB Receiver 1010104281
Jumping mouse My Ms Wireless Optical Mouse pointer has started to jump, involuntarily, about an inch and a half in a south westerly direction. Clicking to open an email in the Inbox often makes the pointer jump to six or seven emails below the one chosen. Occasionally also the pointer grabs or highlights six or seven emails in one block rather than the chosen single one. All this is making navigation tedious. All the configuration data has been carefully checked and no apparent cause can be found - 'this device is working properly' is shown but obviously it is not. Any ideas please as to what might be causing this? Bryan Lillywhite.
    Sergeant:
  • 319 Answers
I would take canned air and blow out the optical sensor on the bottom of the mouse. You could also try changing out the mouse pad. Most times when this happens something is causing the optical sensor to sense the wrong movement...i.e. dust, dirt, crumbs. Make sure to give it a thorough cleaning. Maybe use a little Isopropyl Alcohol on the sensor with a foam swab.
Posted on Feb 01, 2008
Mouse cursor jumping problem, how to fix it?
A mouse is a vital component of your computer and allows you to control certain functions on the screen. When the mouse is not functioning correctly, it can be frustrating. There are a few different reasons why your mouse pointer may jump on the screen. You need to work through the possible causes and troubleshoot the problems to fix your mouse and get it working properly again.
1.
Examine the batteries if you have a wireless mouse and the cursor begins to jump. A low battery may be the cause. Change the batteries and check the mouse again. If it is still experiencing the same problems, proceed to the next steps to resolve the issue.
2.
Switch the wireless transmitter to a different USB port on another computer if possible. There could be problems with the port, causing the cursor to jump. This will resolve the problem if the issue is with the USB port. If the mouse is still jumping, move on to the next steps.
3.
Click on the "Start" menu in the bottom left corner of the screen. Right-click on the "My Computer" menu and click on "Properties." Click on the "Hardware" menu and click on "Device Manager." Locate the mouse entry in the list. Right-click on it and select "Update Driver" from the menu. Allow a few moments for the operating system to locate and install an updated driver for your mouse.
4. Remove dust or debris from the mouse pad and mouse with a soft cloth. Dust or debris could prevent the mouse from operating smoothly and cause the cursor to jump. Add a small amount of isopropyl alcohol to the cloth before you begin. Wait for the alcohol to dry on the pad and mouse prior to using.
5. Go to the "Start" menu and click on "Control Panel." Double-click on the "Mouse" icon and click on "Mouse Pointer." Decrease the speed of the mouse pointer. This could be causing the cursor to jump.
I hope you find it very helpful.
Thank you.
Aug 11, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Tip
Wireless Optical Mouse Cleaning
Optical Mouse Cleaning is a problem for many. The mouse cursor seems to randomly jumping around and uncontrolable, which is caused by dirt on the optical beam. To prevent this from happening, place a piece of clear scotch tap over the optical lens and it will prevent dirt from getting into the lens. Then you won't have problems caused by dirt.
on Dec 08, 2009 | Microsoft Wireless Laser Mouse 5000
Pointer on laptop jumps to a different line while typing.
This may be caused by weak batteries, or interference by some nearby appliance (the worst case is another wireless mouse, of course: happened all the time in an office with six identical workstations, even to the two that were beyond a wall. But also wireless - not cellular - phones may interfere). Also the positions of receiver and mouse may play a part. Once sure the batteries work, try placing the receiver and mouse in different positions and see if it helps.
Otherwise, the receiver antenna could be defective.
Nov 07, 2009 | Microsoft Wireless Notebook Optical Mouse...
The mouse keeps jumping can i fix that?
Reinstall the drivers and try using it on a matt surface. If you got any utility software with the mouse, do install it. If issue persist, you should replace it.
Regards,
Shrey
Oct 05, 2009 | Gear Head Mouse
Erratic behavior of MS wireless optical mouse
Your wireless mouse the battery might be low, change the battery and go to control panel and click the mouse icon, and adjust the right mouse speed setting.
hh
Jul 27, 2009 | Computers & Internet
Mouse Cursor Jumps to the right of the screen
Have you tried going into the control panel - mouse - pointer options - motion speed (slower) and experiment with pointer precision check box? Try it, see what that gets ya.
May 05, 2009 | Dynex Wireless Optical Laptop Mouse...
MY GE WIRELESS OPTICAL MINI MOUSE POINTER MOVES ON ITS OWN
I get the same thing from a optical with cord.
Change the pointer speed. Look in Start > Control Panel > Mouse > Pointer Options.
Nov 24, 2008 | GE Wireless Optical Mini Mouse 3087897985
Jumping mouse cursor
I think some where in the cable there is a broken wire, it is inside the cable, cause there is a certain position that it work properly. You can also test it by tyring other mouse if the problem still the same.
Oct 16, 2008 | HP Wireless Optical Mouse
Jumping cursor
sounds like its a optical mouse, and you are probably using it on a reflective surface ie plastic mousemat, glass or along that lines, you will probaby find out it works fine on wood, or a a solid surface that aint reflective or a gel mouse mat.. :-) all the best John
Mar 11, 2007 | HP OPTICAL SCROLL MOUSE (8131)
Microsoft Wireless Optical Mouse USB Receiver 1010104281 Logo
171 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
