Question about Dacor DMT2420 1200 Watts Microwave Oven
Froze and is non-responsive
This AM I used the unit on "reheat" then when I tried to use it again about 5 mins later, it was frozen and stuck on the time (I presume) it happened. Any thoughts on how to reboot it?
  • 2 more comments
  • Jeasevoli Feb 01, 2008
    It's built in - I am not sure how to unplug it because wherever the plug is, is behind the unit and I am not too handy so I am not sure what to do.. Thanks for the suggestions. If I can get to the plug I will try that.
    OK thank you!! I'll try it right now. Yes, it is in the kitchen, no it's not over the stove and by built-in I mean its actually installed with a cabinet around it and no plug to be seen so I hope the breaker method works!
    I reset the circuit breaker and that seemed to work. Thank you so much for all your useful comments. It's good to know there are still nice people in the world that don't want anything in exchange.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Did you try unplugging it for several minutes and then plugging it back in?
    Scholar:
  • 43 Answers
If it will not CLEAR, You can try Un-Plugging it from the wall, let it dis-charge for 10min., then try . If you still have the problem, I would think your Control Panel has failed. The Control Panel is like an Electronic Controlled Switch with Pre-Programmed sections and Timers. Replacement is the only option. Sorry!
Posted on Feb 01, 2008
  • Totalwreck Feb 01, 2008
    By "Built in" do you mean installed Over The Range? If so the plug should be in the cabinets above the Microwave. If not then go to your Circuit Breaker Panel. Are any of the Breakers labeled as Microwave? If yes, "flip" that Breaker OFF. This will cut the power to the Microwave. If no label, you will have to determine which breaker circuit the Microwave is on. Is the Microwave in the Kitchen? Try that Breaker. Remember to Re-Set the Breaker after you have made your test. 10 min Off is long enough.
    GOOD LUCK!!
    By-the-way. Was the Cabinet "Custom Made" for the Microwave? Any Cabinet that has a Microwave built into it HAS TO HAVE sufficient air space and air intake for the Microwave to BREATHE, and Exhaust Hot Air. Otherwise the Microwave can Over Heat which WILL lead to all kinds of problems. Just a "Heads Up" Thanks!
My 6 year old LG above stove microwave is giving me an error message E-4 when I try to use reheat.
try unplugging the unit for about 5 min..... for the microwave to reset. Plug back in and try a microwaveable safe bowl with a little water for 30 sec. This may take care of the error message.
F4 indicates an open sensor
Jan 05, 2018 | LG Microwave Ovens
How do I reheat frozen lasagna
Microwave ovens are not meant to cook food, except in a very few situations. If the lasagne has already been cooked before it was frozen, then you'll need to weigh and to reheat it in accordance with the manufacturer's instructions in order to ensure the dish is heated through, though it's better to use a food thermometer.
The temperature you should aim for throughout the dish is 83C. Only at that temperature can you be sure that any bacteria in the dish will have been severely depleted.
Feb 21, 2015 | Microwave Ovens
Daewoo KOR-6LOB microwave oven the keypad is frozen andthe display reads 0, then will change to AC1 and a couple minutes later AC2 what can I do to fix it
proceed with common sense tech. God bless you
Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 17, 2012 | Microwave Ovens
Gh9115xe went off completely sometime after a cup of coffee was reheated. Now, nothing works. The outlet is live.
probably not
there is a glass fuse under the outer case near the circuit board
if that is blown it is from a short so you may have to take it in for a diagnosis
Apr 28, 2017 | Whirlpool GH9115XEB / Q 850 Watts...
Let me know the functions of microwave?
Sorry to read about your problem, I hope this helps you out.
Display: This is used to show the time, cook time and options you chose during you use.
Cook: Use this feature to cook fresh vegetable, frozen vegetables, rice and cassroles.
Enter/Start: This is used to start and enter any option you choice while operating the unit.
Stop/Clear: Use this function to clear or stop the unit during cooking or choosing a feature.
Reheat: This is use to reheat dinner plates and left overs. Be sure that you do not use any plastic foam or metal plates/utensils this can cause damage to the unit and may cause injury.
Auto Defrost: This is used to defrost food by weight and type. EX: If you have 1 pound of chicken, meat or fish press in the food code by using 1,2,3 and then the weight in pounds (1 pound would be 1.0 enter.)
Quick Frost: This is use with the Rapid defrosting method for 1.0 pound frozen food. If you have a pound of meat, chicken or fish press Quick Frost and it will defrost for that weight only.
Cook Time: This is to set the cook time for the food you are trying to heat or cook. Enter the time you wish to cook and press enter/start (EX: 7mins and 30 secs = 730/start.)
Clock: This is used to set the time of day. Press Clock the the time of day it is and clock again (EX: 11:00 would be 1100 then clock.)
Number: This is the key pad used to enter the cook time, clock or power level.
More: This feature is to add time to the cooking time only in ten second intervals. If you want to add time without restarting press this button to add ten seconds each time it is pressed.
Less: This is used to decrease the cooking time by ten second intervals. If you want to decrease time without restarting the time press this to decrease cooking time in ten second intervals.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Power Level: This is use to choose the power level in which to cook or heat food or beverages. To change the default setting of 100%, press the power level button and press the level you desire, if you desire only 50% then press power level the 5 and enter/start. Hint: Change the Power level before entering the time your setting to cook
EZ-ON: This is to quickly start the power level to 100%.
Vent High/Low/Off: This is to turn the vent located on the outside of the unit during use. You have the option of turning it off, on, high or low.
Light High/Low/Off: This controls the light on the bottom of the unit if you have a mounted range above your stove or under your top counter cabinets.
Hot Water: This is used to heat water for beverages such as coffee and hot chocolate. Use Extreme caution when removing baverages from your unit, they will be hot and could cause injury.
Popcorn: This is used to pop popping corn, when placing the popcorn in the microwave press the this feature and enter/start and it will automatically start the correct time for cooking. This feature is designed for the individual packaged popcorn use. Do not place any foil or loose popcorn in the unit this could cause damage or injury.
Kids Meals: This is used to REHEAT meals for children it works at a lower power level. This can be used to reheat hot dogs, oatmeal, baby food and soup. Do Not place any metal objects or objects than can melt this can cause damage or injury.
Warm Hold: This is to keep foods or drinks warm for any length of time up to 99 minutes and 99 seconds. Although it is not a recommended to run a unit at the maxium time limit.
Melt: This is used to melt butter, margarine, chocolate, cheese and marshmallows. Do not leave these items unattended during the duration of melting time to prevent any unwanted over heating.
Soften: This is used to soften ice cream, butter, cream cheese, and frozen drinks. Do not place anything in a container that is made of foam or metal this can cause damge or injury.
*Child Lock: If your model has this feature it is used to lock the unit to keep a child from pressing buttons or causing injury.
Open: This is the handle or button on the front of the unit to open the unit after the unit is done cooking or in use. Do not open the door during the use, always press the Stop/Clear button first. Also do not remove hot items without oven mits or waiting time food is at a safe handling temperature.
Jan 03, 2011 | LG LMVM2277ST Microwave Oven
Panasonic Microwave Genius 1200W stop working. I move a little bit electric cord and it went on again. Then I pressed one min quick reheating. It blinks and stop working. Any solution ?
Assuming that you mean the whole unit goes off as if you unplugged it then the problem sound like the incoming power//you say that if you moce the cable then it comes on untill you try to use it //replace the whole cable from plug into the machine
Dec 29, 2009 | Microwave Ovens
I have just purchased a Danby Mircowave DMG948SS and I am wondering if I am missing a manual. There is nothing in the manual about using the Reheat button and it doesn't really explain about the menu...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If you still need help, contact Danby Customer Service US / Canada.
Aug 08, 2009 | Danby Microwave Ovens
When starting to reheat a loud crack, explosion, sound occurred,
As long as the door latches correctly there should be no danger. Some items will cause loud "explosions" in a microwave, such as whole potatoes when the skin has not been pierced. If the food contains pickling spices for example, the seeds will explode with a very loud sound like a gun.
As long as the oven continues to heat, there may be no other problem. But I suggest you stay near the unit when using it. Watch for smoke and be alert for strange odors. You don't mention the age of your oven but if it is new you can call GE customer care at 800 432 2737.
Ray
Nov 25, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Dacor DMT2420 1200 Watts Microwave Oven Logo
63 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
