Question about CTX S761 17" LCD Monitor
New CTX x762 LCD Monitor
Posted by dndwaters on Feb 01, 2008 Report abuse
Base plate will not unfold. Is there a release or should I just force it?
Comment by dndwaters, posted on Feb 01, 2008 No, it's not a fixed joint. It's a pivot joint. The base plate is pivoted all the way over so it will fit into the box it comes in. But it doesn't seem to want to move. I'm afraid I will break it if I apply too much pressure.
Inside the round bit there is a bolt its very tight but you will have to dissasemble to get to it apart from the obvios ones there are 4 hidden behind rubber covers on the sides and then th fron frame unclips this i difficult to start off but by the power button on the side there is a square lump of plastic sticking out place a flat head skrewdriver between this and the front lip and gently twist and the first clip wil come undone and from there you can get the rest good luck
Posted on Oct 30, 2008
HP 2009m Monitor won't unfold
i know it is hard to move but believe me when i say just force it, it will be ok, i had same thought on mine also, but i used a little more pressure and it worked good
Apr 05, 2010 | HP 2009M Monitor
I have a ctx moniter says undectected mode
CTX 15"1024x768 TFT LCD-Black Monitor · i have a ctx moniter says ... Answer. i have a ctx moniter and wen i plugnitin to pc tower itsays undeceted mode watdoes this mean. Close Close. ASUS Eee PC 1000H
Dec 03, 2009 | CTX 15"1024x768 TFT LCD-Black Monitor
Attaching Samsung 2033 monitor to base
The solution is that you simply have to really force the monitor onto the base post. Thanks anyhow.
Jun 23, 2009 | Samsung 204T 20" LCD Monitor
Getting started
It was really stiff and I thought I may break it but with some force it unfolded ok.
Jun 13, 2009 | LG Flatron L1750S 17" LCD Monitor
Looking for AC power Adopter for CTX LCD monitor
Check it on Radio Shack maybe they got something
Jun 03, 2009 | CTX SV900MD 19" LCD Monitor
The monitor screen will not stay up on my HP f1905e monitor
Inside of the base support there is a spring mechanism. I have seen the spring come off from its support, or some parts of the mechanism itself go defective. In some cases I had to order a new support from the manufacture.
Jerry G.
Jan 02, 2009 | CTX S762A 17" LCD Monitor
Ctx pv 720 lcd monitor backlight drops post plus 30 seconds!
Hi...there,
The problems on the backlight inverter power supply. Open it up and check all the capacitors, it look like a tiny battery cap on the side had writing on it. (Example 1000uf 16v ) if you are lucky you can spot it right away...with a bulged on top of each caps. If not, just replaced all of the caps... Good luck!
Dec 06, 2008 | CTX PV 720 17" LCD Monitor
I cannot unfold the base of my HP w1707 LCD Monitor, i dont want to force it but i dont see a release lever either.
Here is a link to the setup poster that shows the base unfolding:
http://h10032.www1.hp.com/ctg/Manual/c01368612.pdf
The key is turning the monitor counter-clockwise on the base. Then you can tilt the screen up.
Jul 25, 2008 | Computers & Internet
Samsung PCL545R 54
hmmm...that's fine...but does this unit have a warranty?
Feb 20, 2008 | Samsung PCL545R 54" Rear Projection...
New CTX x761A Monitor
No way, it's fixed joint... that is due to the design that balances the screen avoiding it from falling or stumbling down.
Hope I gave you the idea... Fixya!
Feb 01, 2008 | CTX S761 17" LCD Monitor
CTX S761 17" LCD Monitor Logo
98 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
