Question about Vacuums
I can't get the power brush belt on tight. Am I missing something?
Model U6401-9 rm
  • Anonymous Feb 01, 2008
    I can't seem to get my belt on tight either. It appears that the belt is on when I look at it but when I turn the vacuum on it will not turn the wheel. Please help!!!!!!!!!!
I did put a new belt on and I always clean my roller. I also replaced the self-propelled belt also just to make sure.
Posted on Feb 02, 2008
  • 126 Answers
I don't know what brand of vacuum you have, but the belts on most vacuums should be changed approx. once a year. The belt can look fine, but is stretched and won't have the necessary tension to turn the roller. It is possible that the roller is in need of servicing. If the bearings in the roller are fouled with dirt and hair, they will not turn properly and a new belt will not solve your problem. Take the roller out of the machine and turn the end caps by hand. They should turn freely. Once you've determined that the roller is o.k., install a new belt, turn the roller by hand to make sure that nothing is jammed and then try the machine again.
After replacing belt it started making too much noise when you turn on. What could be the reason?
You missed something then.. look further back in the vacuum stream or belt drive area for debris or foreign objects.
Nov 11, 2015 | Bissell Bissel PowerGroom Pet Canister Bag...
Replacing a belt on the Riccar 8850...I see how the brush assembly will work with the new belt. But I don't see how a new belt will turn on the small rod extending from the motor. Is there a pully missing?
There is not a pulley missing, when the belt is tight the shaft will turn the belt but when the belt loses elasticity it will slip on the shaft when being used on the carpet. Replace the n
belt at least once or twice per year.
Apr 04, 2011 | Riccar 8850 Vacuum
Beater bar rotating but now making really loud almost buzzing sound???
It is probably a bad belt.That model uses a geared belt and you possibly have a few teeth missing on the belt.It could also be a bad brush or bad motor but less likley.Take the cover off of the power nozzle and inspect the belt.Disconnect it and look at it for missing teelh or a bad spot where they look different than the rest if this is the problem you can stop reading and just go buy a belt.Spin the brush by hand it should give very little resistance without a belt attached.If it spins freely then inspect the ends for a bad bearing.Check the plastic end caps for melting.If they look ok then try moving the brush back and forth slightly to see if the bearing has come apart.If the brush is spinning free and the ends are not showing any movement other than spinning around then inspect the area where the belt rides and make sure it is free of debris like hair and string.Finally plug in the machine with the power nozzle attached and the brush disconected and cover still off and listen to the motor in the power nozzle.If it still makes the noise it's the motor www.sewvac.com
Jan 28, 2011 | Kenmore 25512/ 25513 Progressive Canister...
Burshes will not spin, filter is clean
Drive belt missing or not properly installed on motor or brush/beater? Perhaps foreign matter caught in ends of beater brush that are holding the brush tightly in place. Clean the debris away and hit with a little WD40, but not much. Make sure it turns freely by hand prior to putting it back into place. If the belt is loose, make sure it is replaced with the proper belt and installed correctly.
Aug 28, 2010 | Hoover Vacuums
I replaced the belt with part# 40201 on my Hoover model# U5473-900; to only have it break again in 5 seconds! Is there something missing that holds it on that little bar?
Greetings,
When a brand new belt breaks in 5 seconds, this can only mean 1 of 2 things.
1. The roller brush itself may be bad and need replacing. If the roller brush's bearings lock up, and the brush can no longer spin freely, this will cause the belt to burn up immediately after you turn the vacuum on. You may test your roller brush by taking it out of the vacuum, and hold it on the very ends of the brush with your fingertips. Make sure you are only holding the bearing caps and not the brush itself. While holding the two bearing caps with your pointer fingers, try to spin the brush with your thumbs. Does the brush spin freely? If no, then you'll need to buy a new roller bush for your vacuum, unfortunately the bearings are not sold separately on Hoover vacuums. If the brush did spin freely (you should get at least 7 rotations out of one spin) then see reason number 2 below.
Your model uses Hoover Agitator Brush Part 48414132.
2. The belt was installed incorrectly. When a belt breaks immediately like this it can also be a result of it not being installed properly. When installing the next belt, after you have put the roller brush back into place, pull forward on the belt to make sure that the brush spins when you're pulling forward. Sometimes I pinch the belt underneath of the brush roller, and it will not spin freely, and will burn immediately if the belt is pinched.
It really can only be one of these two problems. I hope that this repair solution was helpful to you. If you need me to clarify something, please just request clarification here. If it did help, please be sure to rate my repair Helpful. Thank you so much!
Chris J.
Mar 13, 2010 | Hoover Vacuums
Small belt driving the brush...stretched out with hair accumulated in groove beneath belt. Is there a clutch or other means of tightening the belt. Went to store found belt...same size, therefore...
You do not by a belt by size, buy it by model only. A new Hoover belt will generally be very snug when installed. As heat builds from use it stretches and becomes worn sometimes as much as 30% oversize. Good that you have cleaned out the hair. Check the end caps of the brush as well. Go to a Hoover service center or retailer and buy the matching belt by model # on the package and you will be set.
Sep 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Trying to replace roller brush on DC07 model
Hi the dyson is a bit strange with this the dyson engineers use a hook to put under the belt and pull it out to allow the brush to be removed I used a metal coat hanger to make the hook after seeing the dyson engineer when ours was under warranty if you make the hook with the wire doubled up it works fine for me hope this is of help Fred
Jun 30, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Power brush on Green Bissell power steamer
Take off belt cover on the left side of the top cover, turn cleaner over, take out screw from red lock and remove, pull cap and brush roll out, unhook the cogged belt, then you can replace the pump thru that opening. Put belt over the pump pulley and stretched to go over the motor shaft. Then check the cogged belt and the cogged end of the pully to make sure that there are cogs, replace belt if there are cogss missing or belt is broke, if no cogs on the pulley, then you will have to replace the pump. Pulley only comes witht he pump.
Sep 24, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Hoover Vacuum
Our Hoover upright vacuum cleaner makes a very loud noise when it is running. What causes this?
Jun 28, 2006 | Hoover S3614 Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
