Remote operates HDD DVD and DVD/VCR Combo Units
Hello, I recently bought an LG HDD/DVD player, but still wish to keep my old LG VCR/DVD combo unit too for playing old video tapes
Problem is - the new LG remote controls BOTH devices at once.
How can I reprogram something so that the new remote doesn't control the old unit too - can i program each to use a different code?
  • jmcnam Feb 03, 2008
    Anyone have any ideas on HOW I can actually program each DVD unit to have distinct codes. They are both LG - one is a DVD/VCR Combo V9210W, the other is a DVD HDD Recorder RH2T80.
Yes,you can use a different code.
Posted on Feb 01, 2008
I just bought a polaroid dvd. i have the codes and such. but im not sure how to program it. so i need the instructions to set up the remote control to my dvd.
Hello
Here are the proceedings to setup your remote with other devices.
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a
Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
Repeat steps 1 through 5 for each device you want to control
OK
Aug 24, 2011 | One For All URC-3021 Remote Control
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
I have One For All URC-4063 remote control. How do I program it to my orion TV
Hello
The codes for Orion TV with One for all URC-3021 are
0236, 0463
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to
Mar 20, 2011 | One For All URC-3021 Remote Control
Need coeds for sanyo
Hello
Setup code for Sanyo with One for all URC-3021 is
0154
CBL/SAT,or TV).
then release SET.
Use the Manufacturer's Codes to
5. Aim the remote control at the device and press POWER
6. Repeat steps 1 through 5 for each device you want to control.
Mar 07, 2011 | One For All URC-3021 Remote Control
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
I want the codes for my remote to control the vcr/dvd rather than just the tv
The Sony remote that came with your TV will not be able to code to your DVD / VCR combo unit, combo units have to be operated by their original type/style remote, because they operate on very specific frequencies.
Now you may be able to code the combo units remote to operate the TV, but usually not the other way around, it just won't work.
Good luck !
Jan 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My remote wont work my vcr/dvd combo. tried some codes but none worked. Both are made by Magnavox
I have found that most DVD/VCR combos operate on their own frequency bands and TV remotes and alot of the universal remotes will not code to these,try the original remote that came with your combo unit to operate the other units that you want to control. Good luck !
Nov 29, 2009 | Audio Players & Recorders
Remote code
Manufacturer Codes
LG/Goldstar 1, 2
Zenith 1, 3, 4
Samsung 6, 7
Sony 8, 9
Hitachi 4
That is the whole list from the manual
Dec 31, 2008 | LG RC897T DVD Recorder/VCR Combo
2 lg dvd players in same room,can I change remote frequency
I have new Panasonic DVD & Combo units stacked on top of each other and had the same problem, until last resort I read the manual and and easily changed the frequency on the DVD unit and remote, you can have up to 3 Panasonic units with different frequencys close to each other.
Dec 28, 2008 | Televison & Video
Sansui VRDVD4000
Universal remotes rarely fully work with these type of units. Call Orion customer service 800 289 0980 to price an original remote.
Oct 09, 2008 | Sansui VRDVD4000 DVD Player/VCR
Televison & Video Logo
311 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
