Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Kenmore dishwasher blinking light
By cmgpokela on Feb 01, 2008
The washing light is blinking, and I cannot get it to reset. The buttons on the front are, High Temp, Heat Dry, Delay Hours, and Start/Cancel. The rest of the options are on a dial. I searched the problem, but the sequences listed for other models do not match the buttons on mine. The model number is 58715182400. Any help is much appreciated- Sears will not give out the code and the service call is really $$$.
Thanks!!
Same Problem
Mar 31, 2009
-   I found the service data sheet inside my front panel. Here is the sequence it says to use: Press the HEAT DRY and START/CANCEL pads at the same time, with the selector set to RINSE ONLY(my selector has quick rinse). The dishwasher will then step through the test cycle. Pushing the START/CANCEL pad will advance the dishwasher to the next step. I have tried this several times and it has not helped me but maybe it will help with your Kenmore 587. Good luck! -   amyaudas
Mar 31, 2009
-   I purchased my Kenmore 587 dishwasher in March 2007 also. I have always had to turn it to heavy wash and then back to normal before the start button would work. I went to start it today and the washing button blinks every time I push start. The dishwasher will not run. I am so frustrated and have read hundreds of problems similar to mine online. This is ridiculous and there should be a recall on several of Kenmore models. I will never buy a Kenmore again. No one seems to know how to solve this problem. Can anyone help? -   amyaudas
Feb 19, 2009
-   stops mid-cycle, wont reset. It seems to have a mind of it's own when it works!!!-   13dragons
Aug 14, 2008
-   same problem on model 587.1619... light blinks "washing" but does not engage in washing.... help-   gunnyski
May 16, 2008
-   I have model number 587.1525 or 587.1625. I purchased it March of 2007. It gave us problems from the beginning. My dishwasher will halt in the middle of a wash cycle and the bottom two lights will blink next to the start/cancel button. In the past, I would continue to put it on wash several times before it completed a cycle. I've had 2 Sears repairmen out. First guy said he didn' t know what was wrong but keep a record. Second guy said it was b/c water didn't get hot quick enough. I resolved that problem. Now, my dishwasher completely stopped working altogether. It never completed the last cycle, and there is water in the bottom. -   joizei
Best Solution
posted on May 16, 2008
Helpful)
joizei
Rank: Apprentice
Rating: 92%, 6 votes
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } I have model number 587.1525 or 587.1625. I purchased it March of 2007. It gave us problems from the beginning. My dishwasher will halt in the middle of a wash cycle and the bottom two lights will blink next to the start/cancel button. In the past, I would continue to put it on wash several times before it completed a cycle. I've had 2 Sears repairmen out. First guy said he didn' t know what was wrong but keep a record. Second guy said it was b/c water didn't get hot quick enough. I resolved that problem. Now, my dishwasher completely stopped working altogether. It never completed the last cycle, and there is water in the bottom.
Was this helpful?
Yes
No
Solution #2
posted on Nov 18, 2009
Not Rated)
mlsund
Rank: Apprentice
Rating: 0%, 0 votes
I have a solution. For Kenmore Dishwashers begining with model 587 and the flashing washing light.it will not start.
inside the front door there are two black and two white wires that lead to the handle. this connection is an on/off saftey for the door latch and if wet will short. The light is flashing because the machine thinks the door is open.
these connections on my machine are very loose. a needle nose pliers to tighten the crimps clean the prongs recconect hard reset at breaker box and you should be ready to go.
m
Comments:
Nov 18, 2009
- thank you. I love you. xoxoxo
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
kitchen aid model number kudco31vbs is it good
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
making noise, sounds like a fan scraping
Answer
Where do I find the curtain arrangment and placemant for Hobart c44A, C64A, C66A & C86A... (More)
Answer
i try to start it but the lights light up very light and doesnt turn on
8 Other Users Have The Same Problem - Continued
Comment by geener, posted on Mar 02, 2008
I have read many posting regarding the Kenmore 587. 15072200 going into some sort of mode where all the lights blink and even if you re-start it this doesn't help. I am having this problem also. Any help would be appreciated!
Comment by Guest, posted on Feb 16, 2008
I have the same problem.
Comment by lexilulu, posted on Feb 05, 2008
Mine is doing same thing. I've tried different button seq but got nothing. Tried turning off power still nothing
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in , OH
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
