Question about Fujinon Stabiscope S-1240 Binocular
Fujino Stabiscope S1240d/N
I have a pair of stabiscope d/n binoculars and want to use night vision . I am told some need exta eye pices that take the tubes and some are already fitted with tubes which you can switch to night vision but these are the later type then I dont see any additional switch However in the front there is an electrical connector 3 pin that has a rubber cover. Information is not very forthcoming up to now from dealers. Do you know what is required and what connects to the plug and what for.
Very best regds George
I don't know about the night vision bits but if it is the same as S-1240 then the 3-pin plug is a power input.
Regards,
Tony
Posted on Jun 17, 2008
Hello I have a nocb4 night owl and my problem is, last winter both eye piece's would intermidately work now this summer I can only get the right one to work, I have checked the battery and have a full...
Here is the problem with Night Owl Optics, ATN, Bushnell, Zenith, Night Vision, and many others US companies that uses foriegn companies to manufacture there cheaper NV devises.
Your Night Owl Binocular has two: ccfl inverters, voltage multipliers, controler and image intensifier tubes. They are manufactured in Russia. 80-90% problems are the image intensifier tubes, they are not the best in the world and they can't take a lot abuse.
Call Night Owl Optics in El Paso, TX. and ask them what will it cost to repair you binoculars.
Sorry. GB...stewbison
Sep 03, 2011 | Night Owl Optics NOCB4 Binocular
Binoculars power on, then immediately off NIGHT OWL OPTICS NIGHT VISION BINOCULARS NOXB5
Hello there. Are you pointing your NV binoculars at bright light, if so, please stop. Therefore, if you are not then possibly the iit (image intensifier tube) is bad, or the auto shut-off is also shorted. Night Owl Optics are in El Paso, TX. Call Night Owl up, they won't tell how to fix it. But they will tell where to send it. "It is proporitary" which mean, they are the one to fix it. Sorry, stewbison.
Jul 10, 2011 | Night Owl Optics Optics
I have a pair of Plastimo military binoculars which have been fine up to now, but suddenly, despite being able to focus using the two eye piece controls, I cannot get anything other than a double image, no...
Hello - I never had Plastimo before but I have had a similar problem with double vision on a very similar looking pair of binoculars.
The eye piece movement just re-aligns eye focus differences , a double image usually means one of the lenses has moved inside the main tube. (usually from a knock/fall etc)
Can you rotate either one of the tubes ? On my pair I had to rotate anti-clockwide and found a prism inside that had slipped after a fall -
Close one eye and try to gauge which side is the best side -- Ray
Feb 05, 2011 | Plastimo Optics
Need instruction manual on what I BELEIVE TO BE NIGHT VISION BINOCULARS
Here we go. Sorry that you waited 7 months or maybe not. Here Meade's Instrment/Optics owner manual for your Meade NightView NV Monocular. If you have two eye pieces to look through and two optic lens on the other end then you have a binocular. But if there is only one eye piece and one Optic on the other end it a Monocular Bi--2, Mo-- Here is Meade web site for your monocular.. http://www.meade.com/manuals/TelescopeManuals/binoculars/Meade%20Night%20View.pdf. GB....stewbison
Jan 26, 2011 | Meade NIghtView NIght Vision Monocular
Hi the ir is not working on my bushnell 26-0400,is there any way you can help (repair ?)
I had the same model, same problem. Bushnell replaced mine under warranty, If they needed to send it for repair it had to go to Russia. I guess it was cheaper to give me a new one. If its not under warranty Bushnell will send it off for you but it will cost quite a bit. My new pair lasted about 2 years with a lot of usage. Gen 1 night vision tubes do not have a very long life span. You may be better served buying a new pair of night vision binos.
Jul 08, 2009 | Bushnell 26-0400 Binocular
Focus knob problem
have repaired a few of these ...some whells have tiny set screws to tighten, some are a two piece wheel that loosens up sometimes, if not that then it is broken. if i can be of further help...15088331232
Apr 26, 2009 | Optics
Need battery
Check with; www.rugift.com they sell these russian NV and will probably have the batts or have a source. Good luck. :)
Dec 16, 2008 | Kalinka Baigish 21 Russian Night Vision...
Tasco nv 356 night binoculars
Check the HV to the tube and see if you can see any discolouration or spots on the tube - they often indicate tube failure. Many binoculars use the one power supply for both tubes as the current demand is very low. Often, one tube operation indicates tube failure, but a wire or connection could be at fault.
Nov 27, 2007 | NewCon Optik BN-5 Binocular
Fujinon Stabiscope S-1240 Binocular Logo
235 people viewed this question
Top Fuji Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
83bj60
Level 1 Expert
Are you a Fuji Optic Expert? Answer questions, earn points and help others
